Help!!! Nut size of center bearing yolk joint thing?????
Discussion in '2nd Gen. Tacomas (2005-2015)' started by GreggyG, May 3, 2022.
  1. May 3, 2022 at 3:57 PM
    GreggyG
    GreggyG [OP] Well-Known Member
    I'm changing the center bearing and tightening down the center nut on the U part that has a spline that holds the bearing and needs to be torqued down to 134ft lbs The nut got messed up but the I think the shaft threads are okay. It's a 24mm size nut, what is the part number and can I get it a lowes maybe?
  2. May 3, 2022 at 4:02 PM
    Barcelona21Taco
    Barcelona21Taco Well-Known Member
    21 OR
    I have purchased metric bolts and nuts at Lowe’s and I have never seen anything that big there. Maybe Google it or try Amazon unless you live in a large city where there’s some sort of a mechanical supply house.
  3. May 3, 2022 at 5:08 PM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    Curious how you screw up such a big nut!
    Also, make sure you are following the right procedure, I believe its an initial (higher) torque to seat everything, back all the way off then a final (lower) torque value.
    TnShooter likes this.
  4. May 3, 2022 at 5:50 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    b_r_o likes this.
  5. May 3, 2022 at 6:32 PM
    Barcelona21Taco
    21 OR
    Now that nut you probably would find at Lowes. Thanks for the info.
  6. May 3, 2022 at 6:37 PM
    TnShooter
    Deogee
    STOCK
    I doubt it.
    I believe you need to stake the nut.
    Never seen a stake nut at lowes.
    6 gearT444E likes this.
  7. May 3, 2022 at 6:59 PM
    6 gearT444E
    Deep South
    Herculiner Hootus
    One of them is probably beneficial to be had at the dealer.
  8. May 3, 2022 at 7:12 PM
    GreggyG
    Thank you all, I found a solution.
