Help! Oil Filter Question
Discussion in '3rd Gen. Tacomas (2016-2023)' started by docsg, Jan 14, 2016.
  1. Jan 14, 2016 at 9:35 PM
    docsg
    docsg [OP] Well-Known Member
    South Alabama
    2020 White TRD OR SBDC
    Raptor 4" oval rails, OEM door sill protectors, totally debadged, OEM mud guards, OEM bed mat, OEM S/S tail pipe extension, BDT tailgate letters, Weather Tech sun screen.
    I'm may be stupid as hell as the information is probably somewhere on this forum but I have search the net and my owner manual and I can't find the answer.
    I recently bought a 2016 Tacoma V6 and am going to get the oil changed by a "indy" soon. I supply my own oil (Mobil Synthetic 0-20W) and filters. My wife has a 3.5L V6 Lexus and I buy filters in packs of 6. The filter the Lexus 3.5 V6 engine takes is the Toyota 04152-YZZA1. I was told (by a Toyota parts man) that filter can also be used on the 2016 Tacoma V6 but then someone else said it takes a different part number. I looked all through the manual and it simply said 6.2 qts. but no info on the filter (unless I overlooked it). A search of Toyota on-line parts lists only the filters up to 2015 which I believe had a 4.0 V6. I would sincerely appreciate help with this..i.e..is this the right filter? Many on this forum have forgotten more about the Tacoma than I will ever know. My previous truck was a 4.6L Tundra and I used the TRD filters for it but gave them to the guy that bought it when I got the Tacoma.
  2. Jan 14, 2016 at 9:38 PM
    Bishop84
    Bishop84 Well-Known Member
    A1 oil filter as well, they are both 2GR's in different orientations.
  3. Jan 14, 2016 at 9:49 PM
    docsg
    South Alabama
    Thanks for your reply-Bishop84. So does that mean I can use the filters I have? I'm assuming from your comment I can.
  4. Jan 14, 2016 at 9:50 PM
    Bishop84
    It sure does, they both use the same oil as well. The Taco has a much longer interval though.
  5. Jan 14, 2016 at 10:44 PM
    docsg
    South Alabama
    Thanks!!!!
  6. Mar 13, 2016 at 6:28 AM
    VinTaco
    VinTaco Well-Known Member
    Burnaby bc
    2016 Black Tacoma TRD OR
    Why is it that when I type in the oil filter # on ebay then ask if it fits a 2016 Tacoma it says not compatible.??
