Help-Oil Filter too tight!
Discussion in '3rd Gen. Tacomas (2016-2023)' started by HMA, Jul 11, 2023.
  1. Jul 12, 2023 at 10:02 AM
    #41
    OnHartung'sRoad
    OnHartung'sRoad -So glad I didn't take the other...
    Somewhere in the Mojave Desert...
    2017 Tacoma OR 4x4 (formerly a 1998 SR5 PU, 2002 OR 4x4, 1995 4x4 4Runner, 1985 4x4 Toy PU) ... and RIP’s (rust in pieces) to a Bronco II 4x4 & S10 Blazer 4x4
    A buddy and my first real jobs after high school were at U-Haul. Poor U-Haul! :rofl:
  2. Jul 12, 2023 at 3:50 PM
    #42
    boston23
    boston23 Well-Known Member
    Adam
    Eastie
    2019 SR5 DCSB 4x4
    Link to a good metal filter housing?
  3. Jul 12, 2023 at 4:08 PM
    #43
    clownkillerloaf
    clownkillerloaf Well-Known Member
    Logan
    2025 SR 4X4 DCSB
  4. Jul 12, 2023 at 4:56 PM
    #44
    2022mgmtrdsport
    2022mgmtrdsport Well-Known Member
    22 TRD SPORT 4X4 DC/LB
    5% tint all around, Raptor grill lights, ProComp 17x8.5 Rockwell wheels, Maxxis 265 / 65 / 17 AT tires, TRD skid plate
    Same thing happened to my 22 TRD Sport. The service tech tightened it so much I had to use a breaker bar to undo it. It seriously felt like 60-70 ft lbs torqued on. :der:
  5. Apr 10, 2024 at 2:54 PM
    #45
    manul4Runner
    manul4Runner New Member
    Ohler
    Old thread, same old story... 2022 Tacoma TRD Sport, dealership changed the oil at ~20,000 miles as per the factory recommendation. Now that I'm out of warranty, it was my turn. Changing the oil should be easy, right? Well, the mechanic must've gotten pissed at my TRD Pro skid plate and decide to get revenge by tightening the plastic flange. Even with the right oil 'wrench', it was tighter than a cylinder head bolt: 1/2 inch ratchet, no go, 18" breaker bar, nada, massive torque wrench set at max (240 ft. lbs.), no joy. At this point, I relinquish myself to catastrophic failure or an afternoon with the Dremel. In one last desperate longshot, I bring out the impact gun. Geez, the force applied, let me count the seconds, attempt #2, #3, The plastic fins cracked, meaning the flange cracked through, but it came loose on that third try.
    Below, I wanted to show that you should never have to use an impact gun at full setting on a plastic oil filter flange. :ballchain:
    I'm glad that I listened to this thread, and got the aluminum flange beforehand (thanks @clownkillerloaf for the link). The purchase was a just in case; well proper planning prevent poor performance today. And I note, there is a dot on the aluminum flange that aligned perfectly with that little clip on the oil filter housing:
    [​IMG] [​IMG]
    gr8-wrx, Barsoom and Phlogiston like this.
  6. Apr 10, 2024 at 4:36 PM
    #46
    Crown1976
    Crown1976 Member
    Louisiana
    2016 sr5 Tacoma
    None
    Is there a spin on conversion kit for the 3.5?
  7. Apr 10, 2024 at 5:00 PM
    #47
    OldSchlPunk
    OldSchlPunk I'm not sick, but I'm not well
    Rich
    East Central Wisco
    '17 AC OffRoad Silver Sky Metallic
    Small lift, slightly oversized tires, well...
  8. Apr 10, 2024 at 5:53 PM
    #48
    Crown1976
    Crown1976 Member
    Louisiana
    2016 sr5 Tacoma
    None
    Wow, yeah I’ll stay with my Mobil 1 elements,lol, thanks for the link, I appreciate it
  9. Apr 10, 2024 at 7:16 PM
    #49
    boston23
    Adam
    Eastie
    2019 SR5 DCSB 4x4
  10. Apr 10, 2024 at 7:19 PM
    #50
    OldSchlPunk
    Rich
    East Central Wisco
    Converts the cartridge filter to spin-on. They also have one that has a remote upside-down filter kinda like a 2G.
    boston23[QUOTED] likes this.
  11. Apr 11, 2024 at 6:33 AM
    #51
    Off Topic Guy
    Off Topic Guy 2023 Trophy Points - Runner Up
    Same experience I had exactly. No amount of force was making it budge; took the 1/2" impact and buzzed it off. Thought everything was okay, and quickly found out after a refill and crank to check for leaks, that one of the fins had cracked and come off, leaving a small hole in the housing. Only took a second to see and hear oil spraying everywhere. Took just a few seconds to dump multiple quarts through that pinhole, so needless to say, my system's pressurization is great lol.
    Side note, had another failure with one of the replacement aluminum housings a couple oil changes after that. No issues of it being too tight, but there was somehow a microscopic crack/hole in the very corner of the housing drain plug piece. Thought maybe the gasket had split or something causing the leak, but I was able to pinpoint the leak to a teeny tiny crack in the plug itself. The crack was so small, you can't even see it; I just noticed an oil drip and eventually traced where it originated. It would only drip after the oil had warmed up; I guess the hole was so small, cold oil wouldn't seep through. So because I've had so many issues with this trucks oil filter housing, I just remove the entire housing without draining it first. Its the same amount of mess either way for me and less tools/parts to fool with.
  12. Apr 11, 2024 at 7:07 AM
    #52
    Barsoom
    Barsoom Well-Known Member
    NW GA OTP
  13. Apr 11, 2024 at 7:18 AM
    #53
    Barsoom
    NW GA OTP
    Sounds like a crack in the square indentation for the wrench? Remember to replace the O-ring under that plug occasionally.
    Your story is a good reminder for me not to over tighten that cap. I started using a 1/4' ratchet with an adapter and holding it right by the head, to minimize the torque I apply. Maybe I should break out the torque wrench next time.
    Off Topic Guy[QUOTED] likes this.
  14. Apr 11, 2024 at 10:14 AM
    #54
    Off Topic Guy
    Exactly, just a hairline/pinhole crack in one of the corners of the square indentation; couldn't even see it, but oil would accumulate there. Figured I'd just be through with even taking that piece off ever again to access the hole for plastic drain piece. If the O-ring ever decides to fail, I've now got a whole box full of them as extras lol.
    Barsoom[QUOTED] likes this.
  15. Apr 11, 2024 at 10:38 AM
    #55
    Barsoom
    NW GA OTP
  16. Apr 11, 2024 at 12:28 PM
    #56
    Off Topic Guy
  17. Apr 11, 2024 at 1:22 PM
    #57
    BigCountry762x39
    BigCountry762x39 Well-Known Member
    TL
    PNW, Oregon!
    2009 Tacoma, with the cool white paint peel
    Arb Deluxe bull bar Front Bumper Ironman4x4 12k winch synth line AFE Intake OME 2.75in Dakar Leaf springs (R) Fox 2.0 bypass shocks (R) Bilstein 6112 (F) 33's on KMC wheels off road lighting comfort mods Redrock HD roof rack Retevis rt95 Radio Slotted Rotors and HD pads
    what is the spec on these they use to be like some super small newton meters, or torque on the plastic ones, which when I actually did the math to figure out FT LB/Tq wasn't much tighter then snug and a bit more for me at least
    boston23 and Barsoom like this.
  18. Apr 11, 2024 at 1:26 PM
    #58
    Shellshock
    Iowa
    30 ft/lbs drain plug
    20 ft/lbs filter housing
    10 ft/lbs filter drain
  19. Apr 11, 2024 at 4:21 PM
    #59
    kahanabob
    kahanabob Well-Known Member
    Maui
    16 TRD 2WD 4DR
    18ft lbs
    important to spread oil on the threads and O ring with you finger before screwing it on
    Vlady and Barsoom[QUOTED] like this.
  20. Apr 11, 2024 at 4:37 PM
    #60
    Vlady
    Vlady Well-Known Member
    Issy, WA
    2017 White SR5 DCSB V6 4x4
    That's the key. Gotta put generous amount of oil on the o-ring and the threads.
