Help! Oil on spark plug threads...
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Gincoma, Feb 7, 2011.
  1. Feb 10, 2012 at 2:44 PM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    Every pent roof design engine made will at some point leak oil into the spark plug wells some get so bad they cover the plugs with oil older 426 hemi's were famous for it and so was the 3TC Toyota engine it won't misfire because oil is a dielectric. It's normal and no big deal except for a little smoke after you change the plugs.
  2. Feb 10, 2012 at 8:21 PM
    myname150
    myname150 Well-Known Member
    this ^
    I changed mine at 60K and this is how they looked.
    Denso
    NGK:
  3. Feb 10, 2012 at 8:27 PM
    Fractured
    Fractured FPS-a-holic
    Corey
    NOR*Cal
    2012 MGM DCSB 4x4
    TRD wheels, TRD cat back exhaust, ScanGauge 2, Debadged, Avid sliders, UWS bed box w/automatic LED light, Led Interior/Reverse/Lic. Plate lights, Yellow Fogs, Flyzeye Light, Color matched grill, Rearview mirror relocate bracket, Power Sliding rear window, Plasti-dipped bumper/"T" emblem
    There spark plug tube seals where the tube meets the valve cover. The tube themselves are sealed by silicon where they meet the cylinder head. It could be leaking there, it's very common.
    Rambo54 likes this.
  4. Feb 10, 2012 at 8:32 PM
    Fractured
    Corey
    NOR*Cal
    2012 MGM DCSB 4x4
    Sorry buddy, but you are wrong. Fuel Oil(conventional or crude oil) has a conductivity value of 0, it's even used to insulate coils in transformers. It is not a dielectric. http://www.smartmeasurement.com/en/wizards/flowmeter/flmtr_mag_conductivity.asp
    Oil commonly causes vehicles to misfire.
  5. Feb 10, 2012 at 8:33 PM
    DOUBLLD
    DOUBLLD Well-Known Member
    Daniel
    Bluemont, VA
    05 Tacoma LS Swap Twin Turbo
    Alot
    Tube seals if u ever have oil in the spark plug tube it's the tube seals trust me I see it all the time mechanic
    Rambo54 likes this.
  6. Feb 10, 2012 at 8:58 PM
    myname150
    That was oil on those threads right? My truck has never misfired in it's life :confused:
    The check engine light flashes i think when it misfires and I have yet to see that
  7. Feb 10, 2012 at 9:14 PM
    BUZZCUT
    BUZZCUT Well-Known Member
    Georgia
    2021 TRD OFFROAD 4x4
    Normal ops. All a byproduct of combustion. Pull a plug on a lawn mover it does it also. Unless there is any oily deposits on the plug porcelain just drive it like you stole it.
  8. Feb 10, 2012 at 9:19 PM
    S.B.
    S.B. Well-Known Member
    Sean
    San Diego
    15 Taco
    LT, Glass, CBI Front bumper, NWTI Rear bumper, 35s
    ya, those look normal.
  9. Feb 10, 2012 at 10:05 PM
    Fractured
    Corey
    NOR*Cal
    2012 MGM DCSB 4x4
    Threads is not the same as the electrode.
    The cel flashes when a condition exists that can damage the catalytic converter, be it a misfire, or lean/high temp condition.
    Large amounts of oil in the combustion chamber will cause a miss i.e. Leaking valve stem seals, blown head gasket, etc. Just because you don't have a miss doesn't mean there isn't oil there however they are not mutually exclusive.
  10. Feb 11, 2012 at 3:29 AM
    Foxer
    Foxer Well-Known Member
    U.S.A.
    Access Cab PreRunner
    The PCV valve is located above that particular spark plug hole. When I recently replaced my PCV is noticed an oil drip mark on the valve cover leading directly into the hole. The oil leaks from the PCV threads into there.
  11. Feb 11, 2012 at 4:02 AM
    maineah
    Tim
    Maine
    4X4 SR5 V6 6spd
  12. Jul 22, 2019 at 5:07 AM
    127.0.0.1
    127.0.0.1 AKA ::1
    /etc/hosts
    2013 NBM AC 4.0 4x4 Auto OR
    necrothread
    update, just did my third sparkplug change on my 2013 v6 and yup, the two plugs closest to firewall had slight oil on the threads,
    nothing excessive (except any oil is technically excessive) all plugs looked nice and clean (used and tan) as they should on the hot side
