Help: OME 885/Wheelers 3 Leaf Measurements.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by mx355, Aug 7, 2016.
  1. Aug 7, 2016 at 1:51 PM
    mx355
    mx355 [OP] Well-Known Member
    Trent
    TX
    2020 Trd Pro
    Kings, Method 316, Nitto Ridge Grappler
    Truck:
    2014 TRD Sport 4wd DCSB
    20,000 miles
    265/70-17 BFG AT
    TRD Pro Wheels
    Lift Components: 885/AAL - roughly on truck for 5,000 miles
    5100 set to 0 - on truck for 20,000 miles
    OME 885
    1/4" Spacer on Driver Side
    Wheelers 3-Leaf Progessive AAL - without Overload Installed.
    My truck is sitting at different heights at every corner.
    Measured from Ground - (HUB Measurments)
    Drivers Front: 37" - (22")
    Drivers Rear: 37 1/2" - (22.5")
    Passengers Front: 37 1/2" - (22.5")
    Passengers Rear: 38" - (23")
  2. Aug 7, 2016 at 1:52 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Measure from center of hub to fender for a more accurate number.
  3. Aug 7, 2016 at 1:56 PM
    mx355
    Trent
    TX
    2020 Trd Pro
    Yes I know, for some reason it didn't let me add what I had edited, wanted both numbers for a representation on the lift heights.
  4. Aug 9, 2016 at 5:41 AM
    mx355
    Trent
    TX
    2020 Trd Pro
    Bump
  5. Aug 9, 2016 at 8:31 AM
    Sub_Par
    Sub_Par Well-Known Member
    Buffalo NY
    2011 TRD Off Road
    Your rake front to back is consistent; however, you do have some lean on the driver side. Did you have a full tank of gas when you measured?
  6. Aug 9, 2016 at 9:01 AM
    mx355
    Trent
    TX
    2020 Trd Pro
    No sir was around half a tank. My truck has always had a little lean on driver rear. When I ran 883s I had 3/8" spacer drivers and 1/4" passenger and the truck was dead even up front. When I went to 885 is opted to just do the 1/4" on drivers and now it sits a 1/2" lower even with spacer which was odd to me.
  7. Aug 13, 2016 at 10:31 AM
    Sub_Par
    Buffalo NY
    2011 TRD Off Road
    Do you know what your pre lift measurements were hub to fender?
