Help on a fix
Discussion in '1st Gen. Tacomas (1995-2004)' started by Nastyray, Aug 22, 2022.
  1. Aug 24, 2022 at 1:09 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Follow this advice
    Cland75 likes this.
  2. Aug 24, 2022 at 1:10 PM
    Cland75
    Cland75 Well-Known Member
    Kevin
    Piedmont NC
    99 Tacoma SR5 4x4
    Just take your time for me because here in NC I was working in 90 to 95 degree heat was to soak it in whatever penetrating fluid your using let it set. You just got the extractor in there it created heat so again use a hammer and give it some hard taps. Then walk away an cool off get a drink and try to find a way to add length to whatever your are using to remove the bit.
    Nastyray[OP] likes this.
  3. Aug 24, 2022 at 1:12 PM
    Das it mang
    Das it mang Well-Known Member
    Az
    1996 T100 SR5 MT
    Stock again- rip slug
    yeah u can't use a crescent on that extractor. Before you give the bolt a go I'd smack the casting a couple times with a hammer and heat treat it to make sure it breaks lose.
  4. Aug 24, 2022 at 1:12 PM
    tirediron
    tirediron Well-Known Member
    Victoria, BC< Canada
    2022 4x4 Sport, Auto, BCM
    Ehhh… I would be VERY careful apply too much leverage to that extractor. They are harder than the hubs of hell and twice as brittle. I would not use anything but a regular ratchet; no snipe or "cheater" extension on it. What I would get is heat. LOTS of heat. Heat is your friend in situations like this. At minimum a propane or better yet MAPP gas torch, ideally, if you know someone with an oxy-acetylene set-up. On the plus side, you've got a good hole, pretty much centered. I would make that hole as big as you can (even if means buying a larger extractor), and drilling it right through... the less metal in the threads, the easier it will come out.
    This is all about patience. Patience and a LOT of profanity are the keys to stuck bolt removal. You've got this!
  5. Aug 24, 2022 at 1:15 PM
    Cryptictoy
    Cryptictoy Well-Known Member
    Esperance, N.Y
    Another thing to keep in mind with extractors is the bigger the hole you drill the less strength the bolt has, the extractor works by pulling itself into the bolt and can cause it to expand and make it tighter yet.
  6. Aug 24, 2022 at 1:16 PM
    Cland75
    Kevin
    Piedmont NC
    99 Tacoma SR5 4x4
    The piece of pipe I used was steel pipe from Tractor Supply it was 6.99 you guys are west coast so dont know if you have those out there or not. But that extra 2 feet made it happen. I had an impact but avoided it after about 3 or 4 taps didnt budge mine. They are a major PIA but thankfully you dont have the rust like we do out here or at least as much of it.
  7. Aug 24, 2022 at 1:20 PM
    Seagull233
    Seagull233 Well-Known Member
    Tom
    Upstate New York
    2004 DC 4x4 V6
    BMW seats, OME Suspension, CBI and NWTI plates front and rear, 13,000 winch, LED light bars, Ham Radio, topper with roof rack added, stainless exhaust, 2nd battery, inverter, sound deadener
    Lots of heat, and a dose or two of Kroil, or poor man's version ATF and acetone, 50/50 mix. Then lots more heat!!!
  8. Aug 24, 2022 at 1:29 PM
    Cland75
    Kevin
    Piedmont NC
    99 Tacoma SR5 4x4
    I dont think he has heat he stated couple times he doesnt deal with car stuff that much. Heck I dont even have a torch yet myself.
  9. Aug 24, 2022 at 1:29 PM
    Cland75
    Kevin
    Piedmont NC
    99 Tacoma SR5 4x4
    This this this
  10. Aug 24, 2022 at 1:35 PM
    tirediron
    MAPP gas torch is $20 at any hardware store...
  11. Aug 24, 2022 at 1:38 PM
    Cland75
    Kevin
    Piedmont NC
    99 Tacoma SR5 4x4
    What hardware store has them for 20$
    nagorb and Kwikvette like this.
  12. Aug 24, 2022 at 1:44 PM
    Cland75
    Kevin
    Piedmont NC
    99 Tacoma SR5 4x4
    Yes lots of patience an you will get it. You have heard alot of different opinions amd advice take your time an little bits an pieces of the things from the folks on here an you will get it! If ya find yourself frustrated soak it down again an walk away an come back to it.
  13. Aug 24, 2022 at 1:44 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    o_O
  14. Aug 24, 2022 at 1:49 PM
    Cland75
    Kevin
    Piedmont NC
    99 Tacoma SR5 4x4
    Ahhhhhhh that may be what you all can get them for in Canada they are much more expensive here sadly.
  15. Aug 24, 2022 at 1:58 PM
    #35
    tirediron
    Okay, the heads have gone up a bit... $40 for a cylinder and inexpensive torch head, so a touch over $30 US.
  16. Aug 24, 2022 at 2:04 PM
    #36
    CrustyTaco
    CrustyTaco Well-Known Member
    Todd
    Louisville, KY
    04 Ext Cab V6 5MT 4X4 185k
    881/5100/Dakars 4R wheels / TBU / New frame
    Good luck OP. My experience is that bolt extraction is never easy. I'm probably 50/50 in lifetime attempts. You'll feel like a champion if you get that thing out though.
    Kwikvette and Cland75 like this.
  17. Aug 24, 2022 at 2:09 PM
    #37
    Cland75
    Kevin
    Piedmont NC
    99 Tacoma SR5 4x4
    Man its literally like you have just won the lottery when you hear that sweet creak then pop an see it moving!! You get it out then stand over your truck an say "Thats what I thought....B!+c$!!! And crack a cold beer
  18. Aug 24, 2022 at 2:13 PM
    #38
    Cland75
    Kevin
    Piedmont NC
    99 Tacoma SR5 4x4
    Just make sure once you get it fixed (AND YOU WILL) that when you see your buddies you just lean against your truck casually and say "Yeah had a bolt break on my truck....fixed it in 30 minutes! No big deal"
    Nastyray[OP] and Kwikvette like this.
  19. Aug 24, 2022 at 2:28 PM
    #39
    Rambofirstblood
    Rambofirstblood Active Member
    2015 TRD Sport
    Propane torch heat is better than nothing.
    You should be able to get one pretty cheap.
    You go crazy on that extractor and it will snap!
    Good luck
    tirediron and Nastyray[OP] like this.
  20. Aug 24, 2022 at 2:49 PM
    #40
    yotadude520
    yotadude520 Well-Known Member
    Will
    The Dirty T
    1986 Toyota Land Cruiser
    OME Lift - FJ62 Axles - 33x10.50 BFGs
    x3 Hit it with some PB Blaster, it's a lubricant that can be found at any auto parts store. Buy a torch and give it some heat!
    If you can't get it out with the extractor, drill all the way through it and you may be able to pull it out in pieces.
