Help on differential
Discussion in '1st Gen. Tacomas (1995-2004)' started by Himiler, Dec 17, 2010.
  1. Dec 17, 2010 at 10:43 AM
    Himiler
    Himiler [OP] Active Member
    Skip
    Washington state
    02 prerunner2.7prndl
    Rocker,stocker
    I bought a 2.7with an automatic and need it for pulling my boats out of the river, yea primitive boat launches I would like to posi the differential for that reason. The only wrecking yards that have a e lock are the wrong gear ratio. Any experience with the changes? Also the springs on the rear flex excessively, I can put the truck in park and move the truck 6 inches forward and back with the only flex in the springs. I need to fix these!!! Please help!!!
  2. Dec 17, 2010 at 10:48 AM
    98tacoma27
    Ben
    Not Beech Creek
    Whats the gear code on the door? It will look like this.
    You will probably be fine if you want to pick up an e-locker, but you willl have to change the entire rear. The third won't fit in the non-TRD housing. You best bet would be to get a Power Trax or Detroit TruTrac
  3. Dec 17, 2010 at 10:49 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Detroit makes a Tru Track that works well in these trucks
  4. Dec 17, 2010 at 10:57 AM
    Himiler
    Skip
    Washington state
    Rocker,stocker
    What about the slop in the springs? When I stop the whole reared feels like it rolls forward. I've changed the carrier bearing and replaced the shocks and cannot make anything move but the springs when I rock it. VERY irritating. The springs were made in Mexico, has that been a problem. Thanks on the differential info tho experience is great teacher
  5. Dec 17, 2010 at 11:18 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    You could ad an Add A Leaf, but that will give a little lift too...
  6. Dec 17, 2010 at 11:28 AM
    Himiler
    Skip
    Washington state
    Rocker,stocker
    The truck was used a lot for moving as the original owner told me.That would probably make u correct. Would it be easier to replace all the springs with 4wd springs and add new bushings than adding just 1spring? The original owner bought a Ford bet he misses his Taco pre runner by now. My last ford had so many recalls half of my miles were for fixing things that should never been used
  7. Dec 17, 2010 at 11:36 AM
    Himiler
    Skip
    Washington state
    Rocker,stocker
    Where is Tenoe? I am in Washington state but was born in Tucson. I bought my latest Taco in Phx last summer
  8. Dec 17, 2010 at 11:39 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Its a joke about my spelling :eek: Its actually in Tempe.
  9. Dec 17, 2010 at 2:12 PM
    98tacoma27
    Ben
    Not Beech Creek
    :D
    :rofl:
