help on evap system
Discussion in '1st Gen. Tacomas (1995-2004)' started by tkperea, Aug 29, 2011.
  1. Aug 29, 2011 at 6:56 PM
    tkperea
    tkperea [OP] New Member
    utah
    2002 toyota tocoma 4 door
    i have replaced the fuel cap replaced the vsv valve that was not working also replaced the three hundred dollar evap canester and still getting a P0440 check engine light this is on a 2002 tacoma four door 4x4 with a 3.4 v6 any body have any ideas
  2. Aug 29, 2011 at 8:21 PM
    jberry813
    jberry813 Making TW Great Again Moderator
    Lake Tahoe
    2012 DCSB Sport
    ...too much shit to list.
    Which VSV did you replace? There's 3.
    I'd suggest you pull each of the VSV's and bench test them.
    http://www.ncttora.com/fsm/2003/Repair_Manual/03tacoma/sf5vzfe/vfccv/insp.pdf
    http://www.ncttora.com/fsm/2003/Repair_Manual/03tacoma/sf5vzfe/vfee/insp.pdf
    http://www.ncttora.com/fsm/2003/Repair_Manual/03tacoma/sf5vzfe/vfpsv/insp.pdf
    If you already replaced the cap and charcoal canister, it has to be either a bunk VSV or one of the lines is clogged or has a leak.
