HELP ON FINDING A AMP FOR A 12' SUB!
Discussion in 'Audio & Video' started by hoodratstormtroop, Apr 4, 2011.
  1. Apr 4, 2011 at 8:51 PM
    hoodratstormtroop
    hoodratstormtroop [OP] Well-Known Member
    santa cruz
    2006 4x4 tacoma TRD debadged
    GPS/dvd player in dash, tires, rims, window tint, tail lights, and sub.
    I have a JBL GT and the max is 1100 watts. I was thinking about the alpine 500 watt v type amp. Would that amp give the sub enough power to make it hit?
  2. Apr 4, 2011 at 8:53 PM
    hoodratstormtroop
    santa cruz
  3. Apr 4, 2011 at 8:55 PM
    Detective_Dan
    Detective_Dan "Place original and witty user title here"
    Colorado Springs
    2014 DCSB Beast / 2016 Yamaha FZ-07
    Pelfreybilt Front Plate Bumper, Brute Force Fab High Clearance Rear Bumper, Pelfreybilt Sliders, OME 886/Dakars, SCS F5's, 33" Ko2's, Cobra 75WXST/3' Firestik, oil catch can, aero turbine 2525, rear differential breather extension, bedmat, weathertech digital fit front/rear, BHLM, custom shiftknob (made by me),
    your best bet would be to get a JBL GT amp if they make one for that sub. i had 4 memphis pr 12's and 2 memphis pr amps. you get the best SQ with amps made specifically for a certian subwoofer
  4. Apr 4, 2011 at 8:56 PM
    snowgod06
    snowgod06 UG legend wannabe
    Rob
    A farm field, OREGON
    06 Access Cab
    crap bolted and welded together....
    look for an amp that the RMS output matches the RMS power of the sub. Then make sure the amp has a bit more power MAX wise and your set.
  5. Apr 5, 2011 at 6:56 AM
    mattg43
    mattg43 Well-Known Member
    Texas
    08 Prerunner SR5 DC
    SwingCase, driver side. PVC Bike rack. Aftermarket stereo.
    No, you dont. Neither the sub, nor the amp, are people, have feelings, or in any way have any idea what they are hooked up to.
    Listen to this:
    This is the safest way to pick out a sub amp. Then dont get crazy with the gain knob - IT IS NOT A VOLUME KNOB.
    Repeat it again:
    It is used to set the gains to match the output of the head unit sub output.
    Good luck!
  6. Apr 5, 2011 at 8:15 AM
    Detective_Dan
    Colorado Springs
    ok so what your telling me is go pick a random ass POS amp up from walmart because it "says" 1200 rms. well they match so im gonna buy it.
    they wouldnt make an amp that matches the sub if it wasnt meant for it.
    IMO thats where yo will get the best SQ from. you CAN match it with a cheap amp, but its like putting plastic hubcaps on your truck, stupid
  7. Apr 5, 2011 at 8:20 AM
    woodygg
    woodygg Well-Known Member
    So Cal
    04 DC Tacoma 4x4
    no, that's not even close to what he said. but that was an excellent strawman you built.
  8. Apr 5, 2011 at 9:02 AM
    mattg43
    Texas
    08 Prerunner SR5 DC
    I think this pretty much covers this portion:
    Thanks Woody!
    They made it to sell for a profit. Does not make it best, does not affect Essque, and generally makes no difference at all.
    I also fail to see how purchasing an amplifier equates to running steel wheels with or without a wheel cover....
    What I said was, pick an amp with a similar or matching RMS power rating (at the given impedance that you will be running the sub) and learn how to use a gain knob, cause it is not a volume knob.
    And for the record, just because Walmart is selling it does not make it a piece of junk. A quick look on my phone shows they carry Infinity Reference series amps, as well as the Pioneer FD 4 channel and class D amps, which would be great.
  9. Apr 5, 2011 at 9:11 AM
    snowgod06
    Rob
    06 Access Cab
    From this statement you have no IDEA what RMS is, a decent amp that puts out 750watss RMS is around $500. Most amps that walmart sells are amps that say their 1200wats PEAK, not RMS. Most are only 200-350RMS. RMS is the running output under normal load that it puts out. Thats why subs say the RMS is say..500, but PEAK is 1000. Power required to operate is 500RMS but it can handle up to 1000watts PEAK before damage. I have a kicker true power amp, a zx750.1 The RMS output is 750 watts, but it can put out PEAK a max of over 1000watts.
  10. Apr 5, 2011 at 1:09 PM
    Detective_Dan
    Colorado Springs
    i know exactly what RMS is rob, and i know the difference between RMS and peak power
    im giving my opinion because thats what the OP is asking for
  11. Apr 5, 2011 at 4:45 PM
    snowgod06
    Rob
    06 Access Cab
    my bad, it just seemed like you didnt. I apologize.. :cool:
  12. Apr 5, 2011 at 9:20 PM
    Detective_Dan
    Colorado Springs
    its ok dude, i just hate getting "bashed/flamed" for an opinion. thats what 85% of this site is anyways, opinions
