Help on how to paint rusted bed bolts.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by bcousins, Aug 16, 2011.
  1. Aug 16, 2011 at 4:04 PM
    bcousins
    bcousins [OP] Member
    2009 Tacoma Access Cab. 12,800 miles.
    Four of the 6 silver bed bolts in my truck have rusted. The truck is still under warranty, but the dealer and Toyota called it surface rust and will not replace. Not the best answer, but sometimes you just don't have the energy to argue.
    The bolts should be black anyway, so I am thinking cleaning them and painting them is the best long term solution anyway. New bolts would probably just rust again.
    Can I get some help on?
    1. The best way to clean the rust off. Product suggestions?
    2. Best paint to use to paint them black. Products?
    Thanks for anyone's help. This site is awesome.
    Homar2394 likes this.
  2. Aug 16, 2011 at 4:07 PM
    horwitzs
    horwitzs Well-Known Member
    Seth
    Dayton, WA
    TX Pro
    Supercharger, OME lift w/ LR UCAs, running boards, toolbox, extinguisher mount, skidplate, N-Fab light bar, 40" R.I. LED bar, WO seat covers, TRD intake, Weathertech mats and visors, stubby antenna, hood struts, LED interior lighting, Hella Supertones, and other stuff I'm forgetting.
    Pull em out, wire brush or wheel.
    As for the paint, not sure the best to use but be careful about getting in the bolt head. You want to be able to get the torx bit back in again.
  3. Aug 16, 2011 at 6:58 PM
    VanCity4x
    VanCity4x Well-Known Member
    AB
    05 Tacoma
    3link on tons
    I would just tape and paper around it, thoes things are a bugger to get off. Wire brush/steel wool, prime then I would use rustolem paint, has good fade resistance. use very light dusting coats, I would do about 5. That will give the longest lasting results. For extra protection add a lacquer top coat if you so desire.
  4. Aug 16, 2011 at 7:04 PM
    Chris(NJ)
    Chris(NJ) Well-Known Member
    Usually in Central Jersey
    08 Indigo 4x4 DC OR
    Mods are currently being changed .....
    Yep... just wire brush the shit out of them, then paint. You could probably hit it w/ a rust inhibitor first, then a coat of paint.
  5. Aug 16, 2011 at 7:16 PM
    t4daddy
    t4daddy Well-Known Member
    North Alabama
    2008 PreRunner Double Cab
    You can not put lacquer over enamel, you can go the other way, enamel over lacquer.
  6. Aug 16, 2011 at 8:46 PM
    VanCity4x
    AB
    05 Tacoma
    3link on tons
    ^^^^ If you use the rustolem line you can, im not sure if its an enamel, I just buy the paint color and the sheen of lacquer i want. Has worked well for me.
  7. Jan 10, 2017 at 7:26 AM
    GGinsd14
    GGinsd14 Member
    Jorge
    San Diego, CA
    2011 Taco w/ TRD Off road Pkg
    I have a 2011 taco and I pulled the bolts out to put some D-rings and 3 out of the 4 were badly rusted. I took a wire wheel to them and pieces were coming off!!! I need to order new ones for sure.
  8. Mar 31, 2017 at 4:23 PM
    Riksolo
    Riksolo Well-Known Member
    2017 Tacoma TRD Off-Road
    mines brand new and it's rusting. I don't know why they don't spring for stainless or at least anodize them I'll have to pull and paint I guess.
    Sidney Vicious likes this.
