Help on lift kit!
Discussion in '1st Gen. Tacomas (1995-2004)' started by jp2004taco, Jul 4, 2013.
  1. Jul 4, 2013 at 6:26 PM
    jp2004taco
    jp2004taco [OP] Well-Known Member
    justin
    nc
    fuel hostages ,with 35's
    cold air intake
    I currently have a 04 Tacoma extended cab , and it has a 3inch pro comp lift the previous owner put on it . It's not level the front sits lower than the back . I want it level and maybe 2 or 3inches taller . Post pics of your lifts or ideas for my truck . What would make my truck level a leveling kit or would a 3
    Inch body lift pick it up even ?
    It looks level in that pic but I can ensure u it's off 1-2 inches
  2. Jul 5, 2013 at 4:56 AM
    james
    james In over my head...
    Friday Harbor, WA: Fairbanks, AK
    '98 Tacoma V6
    First post, huh? Well, welcome to TacomaWorld!
    I wish I had an option for you, but our modus operandi is quite different. I installed an OME lift on my truck and just finished it last week, so I've got OME parts throughout. The Dakar leaf springs I installed raised my back end higher than my front, and I don't mind it so much really, as I don't really care what the truck looks like - well, that's not true - but I don't care *as much*. Since I'm going to put a bunch of weight in the thing for winter driving in Alaska, I suspect added weight will bring the rear end down. Might that be a possibility for you?
    On the other hand, if that's not something you're willing to do, would you be up for raising the front with some new coil springs? If your truck would benefit from new front coils, that's the direction I'd go.
  3. Jul 5, 2013 at 5:43 AM
    sirsaechao
    sirsaechao Well-Known Member
    Tim
    CA
    2002 Toyota Tacoma SR5 TRD 3.4L 4X4 V6
    A lift, some wheels, some tires, some performance, some cosmetic and then audio.
    Drop bracket lift kit like Fabtech if you want something more then your 3" lift you already have unless you want to add a 3" body lift to your 3" current suspension lift.
  4. Jul 5, 2013 at 5:57 AM
    tacomataco2
    tacomataco2 A dude
    Mass
    15’ ACLB
    Some of this Some of that
    Put bilstein 5100 with toytec eibach coils on them up front. Gives a full 3 inches of lift. Don't do a body lift, over one inch. After that they're kinda dangerous. Pics of suspension of truck? Idk what kind of lift you have
  5. Jul 5, 2013 at 6:02 AM
    newertoy
    newertoy Well-Known Member
    Kevin
    East Tn
    2003 4x4 extra cab
    2" lift AAL and Bilstiens-front-rear,front diff drop. main drive drop
    put a couple girls in the back--3 should do it.
  6. Jul 5, 2013 at 6:05 AM
    tacomataco2
    tacomataco2 A dude
    Mass
    15’ ACLB
    I changed my mind! ^this^^^
  7. Jul 5, 2013 at 6:11 AM
    Large
    Large Red
    Truck looks too nice to be wheeled, just put a 3" BL, you'll be okay.
  8. Jul 5, 2013 at 6:16 AM
    jp2004taco
    justin
    nc
    cold air intake
    It's got a 3 in h suspension lift , that's a pro comp now
  9. Jul 7, 2013 at 1:09 PM
    jp2004taco
    justin
    nc
    cold air intake
    Come on folks , I want it level and 2-3 inches higher . What should I do?
  10. Jul 7, 2013 at 1:10 PM
    sirsaechao
    Tim
    CA
    Drop bracket. 6" lift if you want it leveled and 3" taller then your 3" suspension now.
  11. Jul 7, 2013 at 1:13 PM
    jp2004taco
    justin
    nc
    cold air intake
    So take off what have a go with a 6inch bracket? Is there any way I can add any type of lift to it now
  12. Jul 7, 2013 at 1:16 PM
    sirsaechao
    Tim
    CA
    Can't stack lifts with your 3" suspension lift right now. Only thing is add a 3" body lift but I wouldn't do a body lift. People run them and never had a problem and some people have horror stories of 2" and 3" body lift.
  13. Jul 7, 2013 at 1:18 PM
    CHPTR11
    CHPTR11 Team Impulse Red
    Dan
    Pacific NW
    2004 TRD Tacoma
    OME, Hankook, ARB, SCS
    The only way you'll get 3" more lift with your current set-up will be:
    (a) - with a 3" body lift on top of your existing lift.
    (b) - take the pro comp lift off and install a 6" drop bracket lift from Fabtech.
    Both options are, for the most part, universally disliked on this forum.
  14. Jul 7, 2013 at 1:19 PM
    jp2004taco
    justin
    nc
    cold air intake
    Right I understand man , I'd have horror I bet cause I'm really really rough on my truck , it's my daily driver . And yeah I figured how much would a 6inch bracket go?
  15. Jul 7, 2013 at 1:25 PM
    CHPTR11
    Dan
    Pacific NW
    2004 TRD Tacoma
    I think they run about $2000
  16. Jul 7, 2013 at 1:25 PM
    sirsaechao
    Tim
    CA
    Personally taller is not always better. With drop bracket kit, if you are 4WD you need to cut the cross member off. Taller = loss in power, loss on MPG cause you want to run larger tires, regearing. Quite frankly, the drop bracket ride sucks cause of the huge rear blocks of Fabtech kit. Cutting the cross member is almost permanent. You have to reweld a new one if you decide to go back to stock or SAS. I would look into Eibach coils with Bilstein 5100's and new Dakars rear leafs or OME 881's with top plate paired with OME Nitros and Dakars myself.
  17. Jul 7, 2013 at 1:29 PM
    jp2004taco
    justin
    nc
    cold air intake
    Loss of power and miles per gallon is okay , I got a power stroke for that lol I just want my tacoma to look good cause its my daily driver and I'd like to sit above my 35s a good 2 inches or more
  18. Jul 7, 2013 at 1:33 PM
    sirsaechao
    Tim
    CA
    Go 6" drop bracket lift then. That will give you the look you want. Mall crawler stance.
  19. Jul 7, 2013 at 1:34 PM
    CHPTR11
    Dan
    Pacific NW
    2004 TRD Tacoma
    :cool: :rofl:
  20. Jul 7, 2013 at 1:39 PM
    jp2004taco
    justin
    nc
    cold air intake
    Trust me she's not a pavement queen . She's been balls deep in mud up to the door handle. I'll look into it thanks everyone
