Help on modifying my 4 banger
Discussion in '4 Cylinder' started by APreciado, Oct 5, 2012.
  1. Oct 5, 2012 at 7:03 PM
    APreciado
    APreciado [OP] New Member
    Alvaro Preciado
    South Gate Ca
    2011 Prerunner SR5
    Flomaster
    I have a 2011 crew cab Tacoma so far I've changed my stock exhaust and now have flow master,with a K&N air intake. Truck is pretty fast but I've also changed a lot on the exterior of it and ran out of ideas for mods performance wise any thoughts?
  2. Oct 6, 2012 at 6:02 PM
    Rackster
    Rackster Well-Known Member
    Kevin
    Connecticut
    '04 E/cab 4x4 2.7 Auto SR5
    If you are looking to improve your fuel economy, and if you aren't already running synthetic oil, you may want to convert over.
  3. Oct 6, 2012 at 6:49 PM
    Rackster
    Kevin
    Connecticut
    If you hadn't browsed this forum, here's a link to a thread on headers you might want to check out - http://www.tacomaworld.com/forum/4-cylinder/226435-lce-headers.html
    Do your research on performance items. Many aren't worth the pricetag you'll pay and many will actually reduce your vehicle/engine performance. From the reading I've done, wrapped headers may offer some benefit. However, it is important to note that the factory equipment is really very good and the gains might be marginal. If possible, try to find quantitative, objective evidence that supports the manufacturer's claims. Manufacturers don't always tell the truth. There is plenty of qualitative, anecdotal evidence out there, some better than others. Good luck!
