help on my toytec 3" lift,884's in front,aal's
Discussion in '2nd Gen. Tacomas (2005-2015)' started by tnj, Aug 30, 2010.
  1. Aug 30, 2010 at 5:07 PM
    tnj
    tnj [OP] Well-Known Member
    tom and jane
    CO
    2007 tacoma 4x4 off road 6speed
    13"antennax,black painted grill,hammered black paint on rims,debadged,3" toytec lift,aal,884 coils with top plate,diff. drop,custom grill,6 speed trans, painted engine cover
    when putting on the add a leaf,do i need to remove that 2" wide piece that holds the leafs together?rookie question
  2. Aug 30, 2010 at 5:52 PM
    Bsly862
    Bsly862 Well-Known Member
    Nate
    Denver, CO
    08 Off Road
    3in lift
    I didn't have to remove them when I did mine, so I cant see any reason why you would have to
  3. Aug 30, 2010 at 6:09 PM
    tnj
    tom and jane
    CO
    great,so just the center bolt and the u bolt will hold that on?iam going to put the lift on over the holiday,i need to find a garage for my springs,hopefully someone over the labor day weekend can do it
  4. Aug 30, 2010 at 6:47 PM
    Bsly862
    Nate
    Denver, CO
    08 Off Road
    3in lift
    In this picture you can see the AAL it is the one right about the overload leaf
    since the AAL is shorter it should not interfere with that clip you are referring too
    (note not my truck, belongs to outlaw7 found it in a quick search)
    see rest of the threat here http://www.tacomaworld.com/forum/suspension/98801-lift-here.html
  5. Aug 30, 2010 at 6:57 PM
    williegator
    williegator Well-Known Member
    atlantic beach florida
    trd sport 4x4
    toytec Ultimate kit set @ 3 inches, Light Racing UCA's, HELO HE791 17X8 WHEELS, BFG 285-70-17's, secondary air filter removed, ARI drop in filter, Scan Gauge, Roll N Lock
    Picture looks just like mine, no problem.
  6. Aug 30, 2010 at 7:08 PM
    tnj
    tom and jane
    CO
    thanks guys
  7. Aug 30, 2010 at 7:20 PM
    senna
    senna Well-Known Member
    San Jose CA.
    09 DBL CAB TRD-OR OME shocks 885 and AAL
    A C clamp helps control the spring pack while removing and installing the center pin. Also if you are not disconnecting the brake lines, cut the center pin to length before installing the drivers side.
