Help on Purchasing Fully loaded Tacoma w/SuperCharger!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Bluelyfe, Nov 17, 2014.
  1. Nov 22, 2014 at 7:15 AM
    #101
    robssol
    robssol If it ain't broke, leave it the eff alone!
    Rob
    S. Wisconsin
    06 Tacoma, TRD Sport, SR5, 4X4, AC
    Frame 2.0, Fog lights anytime, Seatbelt reminder delete, Secondary air filter delete, LED bed lights, Running boards, 2017 Rims, Devil Horns by Andres, Ultra gauge, Cup holder/consol/glove compartment lights, Interior LED conversion, Blue Sea aux. fuse panel, fuse panel mounting plate by Yotamac, ProEFX heated towing mirrors, LED engine bay lights, Redline Quicklift Elite hood struts, Wet Okole Heated Seat Covers, Pop and Lock tailgate theft deterrent mod 2.0, Plasti-dip rear bumper. Decal free visors, Washable cabin air filter, Overhead consol auto dimming override switch, BulletProof Fabricating Skid plate, 2lo module.
    It better not! It might blow up your engine:burnrubber::mudding::burnrubber::mudding: :burnrubber: :mudding: :burnrubber:
  2. Nov 22, 2014 at 7:25 AM
    #102
    Eagle1
    Eagle1 Well-Known Member
    I've heard the supercharger is great.They are supposed to last until around 120000 miles.I was going to buy one but decided to buy the truck without it first.The supercharger is put on not at the factory but over here either at the port of entry or the dealership. This was my understanding. I would find out if it comes with its own extended warranty. Warranties are sometimes tricky and you have to read the fine print. But like I said I never buy warranties on anything I buy They are a very profitable business.All the money I've saved over the years now it's easy for me to say no especially when the salesman puts the pressure on because I know I'm ahead of the game.
  3. Nov 22, 2014 at 8:00 AM
    #103
    SabMotocross
    SabMotocross Well-Known Member
    Bobby
    Santa Fe, Texas
    2014 Tacoma PreRunner SR5 DCSB V6 TRD S/C
    TRD BAJA Suspension...Rims and tires, blackout badging, TRD oil filler cap, front skid plate, N-Fab step bars, GrillCraft custom upper and lower grills. K&N air filter, TRD Supercharger.
    The supercharger turns the Tacoma into a real street or dirt fighter, whichever your choice! The power delivery is smooth and at low RPM's, you or your passengers will never know what lies beneath the hood. When you floor the accelerator pedal, there are about 304 horses and 340+ ft/lbs of torque coming alive! The TRD supercharger can be purchased through your dealership of choice. To honor your FULL warranty, the S/C must be installed by your local Toyota dealer! There is a card you can fill-out after the device is installed and you are happy with it.....it officially warrants your TRD supercharger!
  4. Nov 22, 2014 at 8:03 AM
    #104
    Conumdrum
    Conumdrum Well-Known Member
    Las Vegas
    2014 Tacoma
    2WD Sport Nav SC V-6 Mall crawler Home Depot truck
  5. Nov 22, 2014 at 8:17 AM
    #105
    ThomasMore66
    Dallas/Fort Worth & Durango
    It puts the "Whee" in wheeling!
  6. Nov 22, 2014 at 9:04 AM
    #106
    josh0351
    josh0351 Californication
    Josh
    VA
    Supercharged '13 TRD OR | '96 4X4 Reg Cab (RIP)
    Some stuff...
    This is interesting. I've always been leery of the extended warranty because I've heard horror stories about friends having to fight with the stealerships to have warranty work done. But maybe that's dependent on the dealership, I dunno.
  7. Nov 22, 2014 at 10:21 AM
    #107
    ThomasMore66
    NOOO, not another Solstice guy!
  8. Nov 22, 2014 at 11:49 AM
    #108
    robssol
    Rob
    S. Wisconsin
    Yessss it is! :burnrubber: :thumbsup: :yes:
  9. Nov 22, 2014 at 12:46 PM
    #109
    Bluelyfe
    Bluelyfe [OP] Well-Known Member
    8 years 120k for only 2k isn't that bad and I'll have the blower in already so it might be a good safety net just in case?...
  10. Nov 22, 2014 at 12:52 PM
    #110
    el tardo
    el tardo Well-Known Member
    OP-
    its your money and spend it how you like
    this is the biggest pitfall from a sales point of view-
    no one pays the same price as someone else and then you feel like you got fucked. if you like it and can afford it ,your a adult,go for it!
  11. Nov 22, 2014 at 2:23 PM
    #111
    ThomasMore66
    Just don't buy a Solstice.
  12. Nov 22, 2014 at 3:40 PM
    #112
    Lord Helmet
    Lord Helmet Prepare To Attack
    Nick
    '24 X3 M40i
    :rofl:
  13. Nov 23, 2014 at 5:49 AM
    #113
    GrandMasterChooch
    GrandMasterChooch Well-Known Member
    east coast
    snow tires
    Why not buy a solstice GXP or add a supercharger to a stock one?
    Either way if you feel you need that extra power, go for it. Warranties...meh. Read the fine print, they will find away of not covering something. probably best to pocket the money you would have saved :playball:for a rainy day.
  14. Nov 23, 2014 at 7:05 AM
    #114
    dm1215al
    dm1215al Well-Known Member
    Dan
    Fl
    2014 TRD Offroad 4x4
    Step tubes,Window tint, HomelinK rear view mirror, changed the entune image screen Rear Differential Breather Relocation Extended AC condensate hose KB Voodoo tailgate cap Redline Tuning QuickLIFT ELITE hood lift system.
    That seems very high for the SS.
    I had a dealer here that offered a lifetime powertrain warranty with the purchase.
  15. Nov 23, 2014 at 10:50 PM
    #115
    robssol
    Rob
    S. Wisconsin
    There are shops out there that will drop a V8 in a solstice:thumbsup:
  16. Nov 24, 2014 at 5:18 AM
    #116
    ThomasMore66
    Stop this guy!
    I seem to remember Hot Rod magazine had a story a few years ago where an LS7 went in a Solstice. You might have to dip into that retirement money to fund it.
  17. Nov 24, 2014 at 6:38 AM
    #117
    robssol
    Rob
    S. Wisconsin
    Yeah, that was infamous and almost a fail. Process has been perfected. It starts at $20000 goes up to $50000+ and you supply the car:eek: Have fun:yes:
  18. Nov 24, 2014 at 7:17 AM
    #118
    ThomasMore66
    That's the only way a Solstice gets cool. Do it.
  19. Dec 17, 2014 at 6:31 PM
    #119
    ROMYER8313
    ROMYER8313 Active Member
    robert
    medford oregon
    08 sport package
    supercharger, 3inch lift, Doug thorley long tube headers and Magnaflow pro series off road exhaust. urd 2.55 pulley, ucon ems, upgraded urd fuel pump, urd seventh injector system, 61lb mulit-fuel fuel injectors, and AFE cai.
    Toyota also does price match so you could find a place that is selling the trd supercharger for a killer price and Toyota will try to match that price as best they can. they did this for me when i bought mine through Toyota here in medford Oregon. i agree 7k is way to much for that trd supercharger, shit for that much you should go for the urd supercharger and get a shit load more horsepower out of the urd set up.
