Help on replacing dash bulb
Discussion in 'Lighting' started by Rastamanty, Feb 13, 2012.
  1. Feb 13, 2012 at 1:36 PM
    Rastamanty
    Rastamanty [OP] Member
    Tyler
    Utah
    '03 4-Banger manual SR5
    New pina colada air freshener, de-badged, painted/modified and re-badged
    Hi, I'm new to this forum, looks awesome. I spent most of my work day today reading through some threads.
    I bought my second Tacoma yesterday, '03, 4x4, 4cyl, ext cab, sr5.
    (wrecked my last one into the back of a semi)
    It looks as if there is a bulb out in the speedo area because half of it is bright and half is dim.
    I was thinking about unscrewing some things to get to it but wanted to check here first. I found some threads on the matter but they were for the 2nd gen Taco's.
    Has anyone replaced a light on this model?
    Thanks!
  2. Feb 13, 2012 at 4:38 PM
    Fractured
    Fractured FPS-a-holic
    Corey
    NOR*Cal
    2012 MGM DCSB 4x4
    TRD wheels, TRD cat back exhaust, ScanGauge 2, Debadged, Avid sliders, UWS bed box w/automatic LED light, Led Interior/Reverse/Lic. Plate lights, Yellow Fogs, Flyzeye Light, Color matched grill, Rearview mirror relocate bracket, Power Sliding rear window, Plasti-dipped bumper/"T" emblem
    Yes I have. I don't have one in front of me though so I will do my best off knowledge.
    1. take out 2 screws in bezel around speedo (at top)
    2. There should be 3 to 5 screws holding the speedo assembly in
    3. wrestle speedo out a little, then disconnect connectors in back
    This is where things get foggy....
    the bulbs should screw out with half a turn counter clockwise.
    install and enjoy. If you take a pic of the speedo cluster I can help more.
