Help on the BHLM
Discussion in '2nd Gen. Tacomas (2005-2015)' started by CristianTRD, Feb 1, 2011.
  1. Feb 1, 2011 at 5:05 PM
    CristianTRD
    CristianTRD [OP] Well-Known Member
    Cristian
    Texas
    08 PreRunner TRD
    Ok I started this afternoon. Now I'm a little stuck on this mod. I have taken the headlights out and know I'm not sure what rubber parts to take off before I put it in the oven. Also how to take the things off would help. Like the technique to removing the part. Thanks.
  2. Feb 1, 2011 at 5:13 PM
    jdkeller
    jdkeller How many words can be fit in this s
    Jonathan
    Inland Empire, Ca
    2008 Tacoma Prerunner TRD Offroad
    Dome light LED, 6000k HID Headlights and fogs, Grillcraft black mesh, rear 5100's, Total Chaos UCA's, 285/75/16 BFG KM2's, Spidertrax spacers, Blacked out emblems, cb,kenwood tm270 ham radio, All Pro 3" leaf pack, Fox 2.0 coilovers, Revenge Fab Sliders, u bolt flip kit, Pioneer avh4200, bed bar with light and antenna, Wet Okoles, Weathertech Mats, Wet Okole Armrests, Rear KR Fab bumper, bed mat, N-Fab spare tire carrier with full size spare on 16" TRD rim, Bedlinered flares and grille. Camburg Spindles, All Pro front fenders.
    Did you read the how to thread?
  3. Feb 1, 2011 at 5:18 PM
    SmilingMark
    SmilingMark Well-Known Member
    Mark
    Ogden, UT
    2010 Access Cab
    Color matched grill w/ grillcraft. BHLM and Morimoto Mini HID's Debadged.
    take off ALL the rubber parts !
  4. Feb 1, 2011 at 5:19 PM
    CristianTRD
    Cristian
    Texas
    08 PreRunner TRD
    Yes, but I couldn't find one that was specific on what to remove and how to remove them. Trust me I wouldn't have started without looking at a write-up. Ha.
  5. Feb 1, 2011 at 5:21 PM
    CristianTRD
    Cristian
    Texas
    08 PreRunner TRD
    Yea I know that much... Sorry that I'm not as mechanically inclined as you other folks. Ha. I'm only 16 so I'm still learning some things.
  6. Feb 1, 2011 at 5:23 PM
    AK27
    AK27 Well-Known Member
    post a pic of what you have now. that way we can tell what else needs to come off
  7. Feb 1, 2011 at 5:24 PM
    jdkeller
    Jonathan
    Inland Empire, Ca
    Take off everything you can. The little plastic stuff and the rubber. You know you need to put them in the oven right?
  8. Feb 1, 2011 at 5:24 PM
    SmilingMark
    Mark
    Ogden, UT
    2010 Access Cab
    Basically, if it's black, it comes off. If I recall, nearly everything either pops right off or will pry off with a screwdriver with a little force.
  9. Feb 1, 2011 at 5:26 PM
    AK27
    the only thing that didnt come off of mine was the rubber weatherstripping along the top of the light. it was glued on
  10. Feb 1, 2011 at 5:28 PM
    SmilingMark
    Mark
    Ogden, UT
    2010 Access Cab
    Yeah, don't take that off, sorry, forgot about the weather strip.
  11. Feb 1, 2011 at 5:33 PM
    CristianTRD
    Cristian
    Texas
    08 PreRunner TRD
  12. Feb 1, 2011 at 5:35 PM
    AK27
    the big rubber boot comes off, just pull straight back and it will pop off
  13. Feb 1, 2011 at 5:36 PM
    CristianTRD
    Cristian
    Texas
    08 PreRunner TRD
  14. Feb 1, 2011 at 5:36 PM
    SmilingMark
    Mark
    Ogden, UT
    2010 Access Cab
    3 things left... that big rubber thing in the middle and your bulb. (careful though, don't touch the bulb, set it somewhere safe) then the two black plastic things will pop off. You may need to pry some. Oh, and there is a black thing on one of the mounting arms that comes off too.
  15. Feb 1, 2011 at 5:38 PM
    SmilingMark
    Mark
    Ogden, UT
    2010 Access Cab
    Okay, not trying to scare you off or anything, but if you mess it up, know that OEM headlight assemblies are around $325 each. (don't ask me how I know this)
  16. Feb 1, 2011 at 5:42 PM
    AK27
    lol
    try at a lower temp first and work up from there. and put a piece of cardboard on the oven rack since a lot of people seem to be melting their lights on the rack
  17. Feb 1, 2011 at 5:46 PM
    Pugga
    Massachusetts
    '18 Ford F-250 SCREW
    F-250 Land Yacht Mod
  18. Feb 1, 2011 at 5:47 PM
    SmilingMark
    Mark
    Ogden, UT
    2010 Access Cab
    Definetely use the cardboard! It wasn't the temp that messed me up, it was a small drip of the grey adhesive that I got smack in the middle of the inside of the lens. Rather than being patient and letting it cool and peeling it off, I though industrial strength 3M adhesive remover would do the trick. Note: DO NOT use 3M adhesive remover on an acrylic lens. :crapstorm:
  19. Feb 1, 2011 at 5:51 PM
    AK27
    how hot did you have your oven set at?? mine did not drip any adhesive, it was still really tacky and stretchy when i pulled them apart
  20. Feb 1, 2011 at 5:52 PM
    CristianTRD
    Cristian
    Texas
    08 PreRunner TRD
    Does it look ready for the oven.? And is that the little plastic thing the thing you were talking about on the mounting arms Mark.?
