Help on tire and wheel sizing...again
Discussion in 'Wheels & Tires' started by se7en, Jan 30, 2010.
  1. Jan 30, 2010 at 7:34 PM
    se7en
    se7en [OP] Go Vols!
    East TN
    16 Limited 4x4
    Okay, please don't blast me. I swear I have searched and searched but I couldn't find EXACTLY what I was looking for. I have a stock 09 DC Sport 4x4 and don't plan on lifting. I want to run MM 951's in an 18x9. Those have a standard 4.5" backspace and -12mm offset. I'll, of course, run a 285/60/18 tire most likely a Nitto TG. I don't want them to stick out further than 1.5"-2" max past the fenders. Is this going to work or will they stick out even further? Will they rub or is trimming involved. I want to keep my front mud flaps if at all possible. Help from you guys is VERY much appreciated.
  2. Jan 30, 2010 at 8:09 PM
    AriZonaD54
    AriZonaD54 BANNED in 49 states...
    Andrew
    Valley of the Sun
    My wheels have the same specs as the ones you are looking at with the exception that they are 17" tall instead of 18".
    The tires are 295/70/17. You can see how they look here;
  3. Jan 30, 2010 at 8:10 PM
    AriZonaD54
    Andrew
    Valley of the Sun
    At 285+ you'll more than likely need a 3" lift and potentially some UCAs
  4. Jan 30, 2010 at 8:15 PM
    se7en
    se7en [OP] Go Vols!
    East TN
    16 Limited 4x4
    D54 - man that is one bad ass looking truck...seriously!
    I looked at chris4x4's and the size I want is the same size he has...except he has a lift. With a 4.5" backspace on the wheels I want compared to the stock 5.5", I'm gaining an inch of clearance on the inside to make room for the wider tires. In my mind, that should work...I think. It might rub a little on tight turns, but not a lot, again, I think.
  5. Jan 30, 2010 at 8:26 PM
    se7en
    se7en [OP] Go Vols!
    East TN
    16 Limited 4x4
    The largest stock tire on a stock rim I could go with is a 265/70/17. This tire has a diameter of 31.57" and a width of 10.79". The 285/60/18 has a diameter of 31.5" and a width of 11.5". That's only a differnce of .71" in width. Which when split (because half will be on the outside of the tire) is only adding .36" on the inside. The 1" of backspace (5.5-4.5) should take care of that nicely, right? I mean, am I crazy here or simply too much of a noob to not know of other things?
  6. Feb 1, 2010 at 7:40 PM
    ozmon420
    ozmon420 Well-Known Member
    miami, florida
    08 tacoma
    18x9 pro comp 7031 rims, alpine iva-d310 w/sirius sat radio, ipod connection, tv tuner, reverse camera, bug deflector, wet okole seat covers, tinted windows, running boards, toytec coilovers front set at 2.5'' , AAL rear,5100's rear, TC UCA, leer topper, bruteforce rear bumper, ARB rear locker.
    trust me with the 285's youll need to lift truck.
  7. Feb 2, 2010 at 5:43 AM
    se7en
    se7en [OP] Go Vols!
    East TN
    16 Limited 4x4
    Too late. Rims and tires are on order. Going with 18x9 XD Monsters and 285/60/18 Cooper Zeon LTZ's. My math says it won't rub with normal day-to-day driving...several others that I PM'd said I may have to do some slight trimming, but overall it would work.
    It has a much higher probability of rubbing if I go off roading and stuff the tire, but that's not in my near future.
    After searching this forum, PMing a half dozen members, I was surprised that very few had definitive answers. With a site as large as TW, with as many members, I would have thought I could have found someone somewhere that had the same thought I did and tried it...and subsequently posted their results. It seems EVERYONE wants to lift. I did too, until I did some in depth research and discovered that by lifting as little as three inches, it will put, on average, 30% more wear and tear on your suspension and 20% more on your driveline...not to mention voiding the warranty on those parts affected. I plan to keep this truck for several years and don't want to put that much abuse on it simply for looks.
    As a result, I'm going to take a lot of pictures and try and describe, to the best of my ability, what I experienced so that somebody else somewhere may find it useful.
  8. Feb 2, 2010 at 6:25 AM
    TacoSupreem
    TacoSupreem Dirty Trucker
    Hayden
    Kentucky
    2013 MGM DCSB 4x4 Sport
    Those wheels and tires will fit!
  9. Feb 2, 2010 at 6:28 AM
    TacoSupreem
    Hayden
    Kentucky
    Let us know how those Cooper tires hold up! I was considering those when I got my wheels but decided on the toyo open country a/t's.
  10. Feb 2, 2010 at 6:33 AM
    se7en
    se7en [OP] Go Vols!
    East TN
    16 Limited 4x4
    Absolutely!
    I decided on these based on the RAVING reviews from the full size crowd. If the tires can hold up to their heavier loads, our Taco's will have little effect on them. Should last a long time. Also, Chris4x4 has them and is reviewing them :http://www.tacomaworld.com/forum/wheels-tires/70441-cooper-zeon-ltz-preview.html
  11. Feb 2, 2010 at 6:37 AM
    Jigzor
    Jigzor Well-Known Member
    Pennsylvania
    17 DCSB Silver Sky
    I believe if you want 285s you'll end up needing to remove the front mud flaps.
  12. Feb 2, 2010 at 6:59 AM
    keithlandrum
    keithlandrum Well-Known Member
    Keith
    Saraland Alabama
    2010 chevrolet Z71 4x4
    tint, hid headlights,
    i think 285/60/18 will fit fine just a little widder i had a 05 f150 with 18"s and i put bfg/s 305/65/18 and they were only like 33.5 tall but if they were like 305/70/18 they would have been like 35s
  13. Feb 2, 2010 at 7:08 AM
    TacoSupreem
    Hayden
    Kentucky
    I'm not sure if they will rub the front mud flaps cause I took mine off the same day I drove it off the lot! But it will be close to your uca's. I have about a 1/4 inch between the tire and the uca. But it doesn't rub.
