help on tires/gearing effect on speedo and odometer
Discussion in 'Performance and Tuning' started by NYCO, Aug 11, 2011.
  1. Aug 11, 2011 at 8:24 AM
    NYCO
    NYCO [OP] go explore...
    bOb
    Colorado
    Blue Betty - '06 TRD OR
    dents & scratches
    question:
    how do our trucks tell the speed we're going?
    how do our trucks tell the distance we have traveled?
    ...my thoughts and my confusion
    when you move up in tire size, the speedo will read lower than actual speed due to the diameter of the tire being larger than stock causing you to travel a longer distance in the same amount of rotation. so in my case when i went from the stock to a 285/70/17, my speedo would read 60mph while i actually was going ~64mph. that all makes sense..
    tire calculator to figure change in speed from the change in tire size
    http://www.tacomaworld.com/forum/tirecalc.php
    the confusion sets in when you re-gear...
    so now i have 4.56 gears with my 285s...
    using the formula set forth by WhatThePho? in http://www.tacomaworld.com/forum/performance-tuning/155144-true-speed-after-regear-formula.html, my true speed is now .846 of my speedo reading...
    so now when my speedo reads 65mph i'm really going 55mph
    does this also mean that the mileage on my odometer will read higher than the actual mileage traveled? if it reads 100 miles, does it mean i really only went 84.6 miles?
    and this is where the question came up...how exactly do our trucks calculate the speedo and odometer readings?
    :rolleyes:
  2. Aug 11, 2011 at 8:42 AM
    Dark Knight
    Dark Knight Well-Known Member
    Jeff
    NC/SC
    4Runner Trail
    get a speedo calibrator from Hypertech
  3. Aug 11, 2011 at 8:45 AM
    Dark Knight
    Jeff
    NC/SC
    4Runner Trail
  4. Aug 11, 2011 at 8:57 AM
    David K
    David K Well-Known Member
    San Marcos, Alta California
    2010 4WD Off Road DC
    In simple talk: The stock tires (265/70-16) cause the speedo to read faster than you are really driving: When it says 65 mph, you are really doing about 62-63.
    With a 1" taller tire (265/75-16), my speedo was right on.
  5. Aug 11, 2011 at 9:01 AM
    Flagtown Taco
    Flagtown Taco Active Member
    Tucson
    09 Magnetic Grey DC Shortbed
    3" Toytec lift kit with Bilstein 5100 Coileovers, OME Dakar Leaf Pack, 17" KMC-XD Wheels, 285/70-17 BFG TKO2s, Masterflow Exhaust, CBI Air Intake
    Sub'd
    I too would like to know the answer to this.
  6. Aug 11, 2011 at 9:41 AM
    NYCO
    bOb
    Colorado
    dents & scratches
    $165 :eek:
  7. Aug 11, 2011 at 9:50 AM
    Fire931
    Fire931 Well-Known Member Vendor
    VA
    00 4Runner
    To answer your questions of how they get the readings.....
    If you have an automatic trans truck then the reading is sent from both rear ABS sensors to the ECU that then sends it to the cluster.
    If you have a 6 spd. trans then the reading is sent from a sensor in the rear output of the t-case to the ECU and then to the cluster.
    An easy and cost efficient way to get it reading spot on, Dakota Digital recalibrator. It's not as fancy as the hypertech and requires you to actually cut and splice wires but it works great. I've got it installed on mine and I can go 100 miles on the interstate and watch the odo trip each mile as I past the marker posts.
  8. Aug 11, 2011 at 10:15 AM
    Dark Knight
    Jeff
    NC/SC
    4Runner Trail
    Yes, but it's plug and play for the most part. I like Kevins idea also for a less expensive fix.
  9. Aug 11, 2011 at 10:24 AM
    NetMonkey
    NetMonkey Well-Known Member
    Geogetown, TX
    2010, 4x4, DC, off-road, shortbed, automatic
    Toytec Ultimate Lift @ 3", Mickey Thompson MTZ's 285/75/16, Moto Metal 955b, rear 2" ALL, Marlin Crawler sliders
    no. if the odometer shows that you went 100 miles, then you actually went about 103.5 miles.
    the circumference on the 265's is about 99.29 inches
    the circumference on the 285's is about 102.76 inches
    thats a 3.5% greater distance traveled in a single revolution of the tire.
    gearing will not effect the distance that the truck travels in a single revolution of the tire.
    however, gearing will effect the rate that the truck travels in a single revolution of the tire.
  10. Aug 11, 2011 at 10:30 AM
    NYCO
    bOb
    Colorado
    dents & scratches
    so the gearing effects the speedo but not the odo?
  11. Aug 11, 2011 at 10:45 AM
    NetMonkey
    Geogetown, TX
    from what Fire931 said:
    "If you have an automatic trans truck then the reading is sent from both rear ABS sensors to the ECU that then sends it to the cluster."
    the distance traveled is based on sensors at the wheel. i would assume that these sensors are reading each time the tire makes a single revolution rather than how long it takes to make a single revolution.
    so ya, i would say that gearing effects the speedo and not the odo.
  12. Aug 11, 2011 at 11:10 AM
    NYCO
    bOb
    Colorado
    dents & scratches
    but with the manual, it goes off the t-case output? so it will be off because my t-case output would be higher due to the gears spinning more to push me the same distance...
    why would autos read from the wheel and manual read from the t-case?
  13. Aug 11, 2011 at 11:11 AM
    NYCO
    bOb
    Colorado
    dents & scratches
    or is speedo from the t-case and the odo is from the wheel?
  14. Aug 11, 2011 at 12:43 PM
    Fire931
    VA
    00 4Runner
    No they both read off the same thing, the difference is the type of transmission you have. Why Toyota did that is unknown. But the speedo and odo should be affected the same being as though they both use the same signal.
    Due to my adding the Lefty t-case in my truck and the difference in speedo gears mine was way off. At 70 mph it would read about 45 mph, and the odo was way off as well. I added the Dakota Digital box and all is well with both of them now.
  15. Aug 11, 2011 at 12:45 PM
    Fire931
    VA
    00 4Runner
    Also the nice thing about these boxes is they are always adjustable. Right now mine is spot on for the setup I have (285's and stock gears) however if I change gearing or tire size it will be off again. To correct I simply pull out the box and click a button a few times to dial it back in to the new setup and I'm back in business.
  16. Aug 11, 2011 at 12:47 PM
    NYCO
    bOb
    Colorado
    dents & scratches
  17. Aug 11, 2011 at 12:50 PM
    Fire931
    VA
    00 4Runner
    That's it. I bought it off ebay from whoever was the cheapest place at the time. I think I got it for like $70-75 shipped. WAY cheaper than any speeding ticket that's for sure!!! :D
    I've also got a write up over on RST on the installation for my truck. It may differ a little with an auto trans however I can help figure out the wiring that needs to be done for whoever is the first to do it.
  18. Aug 11, 2011 at 12:51 PM
    NYCO
    bOb
    Colorado
    dents & scratches
    what's RST?
  19. Aug 11, 2011 at 2:08 PM
    NYCO
    bOb
    Colorado
    dents & scratches
    so what was the outcome of this?
    gears will also effect the odometer readings?
    i'll have to find a highway with mileage posted to see for myself...if it is off then i may go the dakota route and get things back in line with each other so i'm not racking up "miles" on the truck that aren't really there...
  20. Aug 11, 2011 at 2:12 PM
    Fire931
    VA
    00 4Runner
    Rock Solid Toys
