Help on Tune Up questions what to do?1997
Discussion in '1st Gen. Tacomas (1995-2004)' started by raiderred01, Nov 23, 2010.
  1. Nov 23, 2010 at 7:29 AM
    raiderred01
    raiderred01 [OP] New Member
    pleasanton
    97 SR5 4x4
    I just bought my 3rd tacoma. It is a 97 2.7L 4x4 xtra cab. It has a 174000 miles on it. I am wondering what kind of tune up I should do? Looks like it has the original wiring harness. Pretty much stock from the ground up. I don't think the owners 2 of them did anything to the truck. What should be done and what do you think it should cost?
    thank you
  2. Nov 23, 2010 at 7:33 AM
    98tacoma27
    Ben
    Not Beech Creek
    Welcome to TW. I would change the plugs, oil and filter, air filter, fuel filter and inspect the antifreeze. A good greasing and brake inspection would be good too. Look for exhaust leaks and inspect the frame. Tend to accordingly. If I missed something someone will chime in.
  3. Nov 23, 2010 at 6:45 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
  4. Nov 23, 2010 at 6:56 PM
    crazyasu45
    crazyasu45 Well-Known Member
    Canada
    2013 MGM DCLB 4X4 TRD SPORT
    3" SUSPENSION LIFT
    Front/Rear Diff & Transfer case fluids...Power Steering flush...
  5. Nov 23, 2010 at 7:03 PM
    devilsalmostfree
    devilsalmostfree Well-Known Member
    Carl
    Loudon, Tn
    99 Tacoma 4X4, 5 spd, 2.7 ltr
    Deck plate mod, intake silencer removed, AFE Pro Dry S Air Filter, debadged, Goodyear Duratracs 265/75R16. Flowmaster knock-off muffler!
    spark plug wires also, unless u know they have been changed!
  6. Nov 24, 2010 at 2:31 AM
    WASTE MANAGEMENT
    WASTE MANAGEMENT Well-Known Member
    Travis
    Umatilla Florida
    97 tacoma 4x4 3.4 w/5 speed
    new 31x10.5 tires, mag wheels, drilled rotors, new sound, and a cb.
    A new pcv valve will keep the crank case pressure in check.
  7. Nov 24, 2010 at 5:00 AM
    TacoMan709
    TacoMan709 Well-Known Member
    Newfoundland (the Rock)
    03 Tacoma Xtra cab 4x4
    285 km2s, 2.5" lift, mashed pinch weld, Flowmaster, wicked piss
    All excellent and very essential advice so far in this thread.
    As for spark plug wires, I swapped mine out in my old '95 Pickup and holy crap did it make a difference with only 160,000 kilometres on it!
    I also Seafoamed it fully (gas tank, case and vacuum line), which I found worked very well but have had reservations about doing it with my "new" 03 Taco.
    But a Seafoam debate is another thread.
