Help! One wheel not spinning in 4 wheel drive!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Ceddingermtb, Dec 25, 2020.
  1. Dec 25, 2020 at 5:25 PM
    Ceddingermtb
    Ceddingermtb [OP] Well-Known Member
    Caleb
    Lake Arrowhead CA
    05 trd off-road dscsb
    I put my truck into 4 wheel for the first time in a while because of snow, and my front passenger side is locked up and won't move past a certain point. It drives fine in 2wd and everything looks normal, cvs are still inside the diff. Anyone every have this?
  2. Dec 25, 2020 at 5:39 PM
    jake72
    jake72 Well-Known Member
    Jake
    N.E. PA
    2019 trd off-road dcsb mt
    Sounds normal
  3. Dec 25, 2020 at 5:40 PM
    Ceddingermtb
    Caleb
    Lake Arrowhead CA
    I mean the wheel locks up when I'm in 4wd and I can't even drive the truck
  4. Dec 25, 2020 at 5:43 PM
    0xDEADBEEF
    2000 reg cab 4x4 flatbed MT
    Does the other front wheel spin?
  5. Dec 25, 2020 at 5:44 PM
    Ceddingermtb
    Caleb
    Lake Arrowhead CA
    It seems like it does, I just hear the passenger side skidding and not the drive side
  6. Dec 25, 2020 at 5:48 PM
    ecgreen
    ecgreen overeducated redneck
    Sean
    2015 4x4 4-banger Access
    4 is 2 and 2 is 1
  7. Dec 25, 2020 at 5:49 PM
    Ceddingermtb
    Caleb
    Lake Arrowhead CA
    Yes but the truck will barely move if in 4wd
  8. Dec 25, 2020 at 5:49 PM
    ecgreen
    Sean
  9. Dec 25, 2020 at 5:49 PM
    0xDEADBEEF
    If it spins alright in 2wd, that points to something wonky in the front differential. If I weren't on a phone I'd google around a bit.
  10. Dec 25, 2020 at 5:51 PM
    ecgreen
    Sean
    Do you mean on open flat ground with no obstructions? Iif thats the case then you have a big problem for sure. In a normal offroad type situation, If one wheel is losing traction, all the power will go to that wheel and the other wheel will get zero power (unless you have a diff lock)
  11. Dec 25, 2020 at 5:52 PM
    Ceddingermtb
    Caleb
    Lake Arrowhead CA
    Yes on open flat ground going straight, I replaced my old diff earlier this year, but I'm thinking something might be real bad with the new one
    SR-71A likes this.
  12. Dec 25, 2020 at 5:53 PM
    ecgreen
    Sean
    Ouch, yep something is wrong for sure in that diff. Someone will chime in with the answer...
  13. Dec 25, 2020 at 5:54 PM
    0xDEADBEEF
    I think I'd drain the diff oil and see what comes out.
    I kind of wonder if it's just locked up due to lack of use and might free up with driving, but that would be a scary thing to test.
  14. Dec 25, 2020 at 6:09 PM
    Ceddingermtb
    Caleb
    Lake Arrowhead CA
    Yeah I guess I'll have to try that and see, and if not try to find a new one again. It's a pain in the a** job to do
  15. Dec 25, 2020 at 6:10 PM
    Bishop84
    Bishop84 Well-Known Member
    I've seen seized calipers cause this as well.
    landphil and 0xDEADBEEF like this.
  16. Dec 25, 2020 at 6:14 PM
    kodiakisland
    kodiakisland Well-Known Member
    NW Arkansas
    12 AC 4x4 2.7L 5MT
    5100s/1.6in eibachs, wheelers AAL, OME N182 rear shocks, 4.56s, Detroit truetrac, 255/75/17, SOSConcepts sliders
    That only seize in 4wd but not in 2wd? Seems odd.
    My guess would be an issue in the center axle disconnect system binding that one side. Not sure exactly how the system works though. Think it might actually connect/disconnect the drivers side, and if so then the problem may be in the diff.
  17. Dec 25, 2020 at 6:26 PM
    Sig45
    Sig45 Well-Known Member
    Mark
    Maine
    Same thing happened to me a few years back. Front Diff seized up and had to be replaced. Had changed the fluid every 30K miles too and exercised the 4WD system as recommended (at minimum).
    Edit: Both my front wheels wouldn't move in 4WD. Had to remove front drive shaft to get by and troubleshoot.
    Ceddingermtb[OP] likes this.
  18. Dec 26, 2020 at 8:28 PM
    6 gearT444E
    Deep South
    Herculiner Hootus
    Take off your front actuator and jack up the truck to spin the wheel, manuall engage the collar and see if something is binding up in there. If it's all clear, then likely broken R&P or a seized bearing in the front diff.
  19. Dec 26, 2020 at 9:41 PM
    Sharpish
    Sharpish Well-Known Member
    Brian
    Victoria, British Columbia, Canada
    2012 Tacoma TRD OR 4x4
    Maybe when you replaced your front diff, the new one has a different ratio that doesn’t match the rear. It will lock up and hop/skip if they don’t match.
  20. Dec 27, 2020 at 1:17 PM
    Ceddingermtb
    Caleb
    Lake Arrowhead CA
    Yeah I bought the truck from a deal ship so I Don't know if it had stock gears, I'm assuming it did because it only had 31's when I bought it
