Help! One wheel not spinning in 4 wheel drive!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Ceddingermtb, Dec 25, 2020.
  1. Dec 29, 2020 at 1:01 PM
    #61
    Ceddingermtb
    Ceddingermtb [OP] Well-Known Member
    Caleb
    Lake Arrowhead CA
    05 trd off-road dscsb
    Sorry for confusion, I'm horrible at explaining things fully through text
    SR-71A likes this.
  2. Dec 29, 2020 at 1:02 PM
    #62
    Too Stroked
    Too Stroked Well-Known Member
    Tom
    South shore of Lake Ontario
    2021 4Runner SR5 Premium
    Ok, not driveline bind then.
  3. Dec 29, 2020 at 1:03 PM
    #63
    eon_blue
    Azusa, CA
    From what I can make out my money is still on different gear ratios front/back, need confirmation on what they are but sounds like you'll have to test them to determine.
    Ceddingermtb[OP] likes this.
  4. Dec 29, 2020 at 1:26 PM
    #64
    SR-71A
    SR-71A Define "Well-Known Member"
    Zack
    Southern Maine
    2012 DCSB, TX Baja Edition. Barcelona Red
    255/85/R16 Falken Wildpeak MTs, Mobtown sliders, ARB bar, SOS front skid, Icon RXT leafs, extended & adjustable Kings, JBA UCAs, OVS wedge RTT, dual AGM batteries, Gen2 xrc9.5 winch, CB, GMRS, S1 ditch lights...
    100% OP still needs to confirm ratios match. Not convinced on driveline bind though. "slushy" isnt exactly a high friction scenario haha
    Could be as simple as real shitty conditions. Sometimes driving over slush or snow is just enough to compact it and turn it into pure ice. Makes turning difficult regardless of 4x4 operation.
    OP, did you ever actually see the wheel bind, or are you basing that on the fact the turning was difficult and non responsive in this scenario?
  5. Dec 29, 2020 at 1:35 PM
    #65
    Ceddingermtb
    Caleb
    Lake Arrowhead CA
    I've seen it bind, yes
  6. Jan 6, 2021 at 8:38 PM
    #66
    Ceddingermtb
    Caleb
    Lake Arrowhead CA
    Just now tried, no luck, and no video, but got the old diff taken apart right now
  7. Jan 6, 2021 at 9:05 PM
    #67
    Ceddingermtb
    Caleb
    Lake Arrowhead CA
    Counted the gears, I got 41 on the ring, and 11 on the pinion which I believe is 3.73. So my guess is that diff might be a reg can diff or a manual
  8. Jan 6, 2021 at 10:08 PM
    #68
    ShimStack
    ShimStack Well-Known Member
    Ben
    NC
    '91 Truggy, '98 Project, '16 DC OR M/T Locked F/R
    I hope you didn't do all that just to determine the gear ratio. You could put in in 4wd, transmission in neutral, jack up one whole side of the truck only, spin the front tire twice, and count the revolutions of the driveshaft. Whatever you count is your gear ratio. Then spin the rear tire twice and count the rear drive shaft revolutions. Question answered in 5 minutes.
  9. Jan 6, 2021 at 10:11 PM
    #69
    ShimStack
    Ben
    NC
    In 2wd with ADD the ring gear, carrier, pinion, and front driveshaft are not going to be spinning. The driver side CV will be spinning the differential (side and spider gears) inside the carrier and the passenger side wheel will be spinning everything up to the ADD.
    SR-71A[QUOTED] and 6 gearT444E like this.
  10. Jan 7, 2021 at 1:40 AM
    #70
    6 gearT444E
    Deep South
    Herculiner Hootus
    3.73 is stock ratio for 6cyl manual or automatic trucks, regardless of trim level. Regular cabs have 4.10 or 3.58 depending on drivetrain. So anything else abnormal in the diff to cause binding? Did you look at the clutch hub in the ADD?
  11. Jan 7, 2021 at 3:36 AM
    #71
    kodiakisland
    kodiakisland Well-Known Member
    NW Arkansas
    12 AC 4x4 2.7L 5MT
    5100s/1.6in eibachs, wheelers AAL, OME N182 rear shocks, 4.56s, Detroit truetrac, 255/75/17, SOSConcepts sliders
    If this thread is any indication, I would expect he took it apart to see what was causing it to bind up.
    SR-71A likes this.
  12. Jan 7, 2021 at 8:31 AM
    #72
    ShimStack
    Ben
    NC
    Yes, but if mismatched gear ratios were a theory, it didn't need to be disassembled at all to determine that. Once that was determined to not be the issue then disassembly may make sense.
    Honestly, you could trouble shoot this whole thing with fairly high certainty of locating any problem with just jack stands and a jack. But the hard way sounds fun too.
  13. Jan 7, 2021 at 2:12 PM
    #73
    Ceddingermtb
    Caleb
    Lake Arrowhead CA
    I took apart my old diff that was sitting on my deck, took like 5 minutes. So I'm assuming I have Mis matched gear ratios.
  14. Jan 7, 2021 at 6:03 PM
    #74
    ShimStack
    Ben
    NC
    Pretty sure the old diff sitting on the deck isn't causing your binding. What's the ratio of the one in the truck? No need to assume, be sure.
  15. Jan 7, 2021 at 6:23 PM
    #75
    Sharpish
    Sharpish Well-Known Member
    Brian
    Victoria, British Columbia, Canada
    2012 Tacoma TRD OR 4x4
    You could also get the entire truck off the ground and see if it all spins in 4hi. Pay a tire shop $20 to put it in the air.
  16. Jan 16, 2021 at 3:03 PM
    #76
    Ceddingermtb
    Caleb
    Lake Arrowhead CA
    Well I know it's most likely the wrong ratio after finding out what's in the old one that used to match the rear
  17. Jan 16, 2021 at 3:06 PM
    #77
    Boyk1182
    Boyk1182 Well-Known Member
    Northern Colorado
    Too many posts to read, but you could try putting it in 4HI and going in reverse to see what happens.
  18. Jan 16, 2021 at 3:32 PM
    #78
    Sharpish
    Brian
    Tell me more ...
  19. Jan 16, 2021 at 3:32 PM
    #79
    Boyk1182
    Northern Colorado
    Not much more to tell, I just remember unlocking the old hubs that way. I try lots of shit before I start taking things apart.
  20. Jan 16, 2021 at 3:43 PM
    #80
    6 gearT444E
    Deep South
    Herculiner Hootus
    that doesn’t work on these systems.
