HELP! only high beams work
Discussion in '2nd Gen. Tacomas (2005-2015)' started by cgs2k2, May 2, 2010.
  1. May 2, 2010 at 8:26 PM
    cgs2k2
    cgs2k2 [OP] Ohio Member
    Nadeem
    2006 AC 4x4 OR
    everytime i turn the dial to "lights on" just the highs come on and the lows dont work whatever i do. when i pull it back or push it forward which normally makes the highs come on, nothing changes. my fogs wont turn on (because only the highs are working). What the hell is going on? i've had the truck for 2 weeks, its certified used, and already 4wd breaks and this haha, i am NOT having good luck right now.
    Any solutions? Anyone else had this problem? HELP!
  2. May 2, 2010 at 8:26 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    Are the bulbs burned out?
  3. May 2, 2010 at 8:30 PM
    cgs2k2
    Nadeem
    2006 AC 4x4 OR
    They shouldn't! I mean, the icon for the highs being on is just on ALL THE TIME when i turn the headlights on. Nothing will disengage the highs so i can't even test the lows. But i'm 99.9% sure they are not burnt out.
  4. May 2, 2010 at 8:40 PM
    cgs2k2
    Nadeem
    2006 AC 4x4 OR
    No sir. Just got the truck less than 2 weeks ago, have not done ANYTHING to it yet.
  5. May 2, 2010 at 8:46 PM
    cgs2k2
    Nadeem
    2006 AC 4x4 OR
    That's what I'm gonna do I suppose. Could be wiring, but all the plow stuff was on it before I bought it and the lights have worked up until only about an hour ago. Hopefully some miracle happens and it works tomorrow. Meh.
  6. May 2, 2010 at 8:46 PM
    Brunes
    Brunes abides.
    Rotorhead
    Yeah...I'd be super suspicious of the wiring. Take it back to the dealer and have them look at it.
  7. May 2, 2010 at 8:51 PM
    ktmrider
    ktmrider Senior Member
    07 DCLB 4x4 Sport S/C
    Junk
    If it worked an hour ago maybe you should try disconnecting the battery for a little while and see if the problem persists and go from there?
  8. May 2, 2010 at 9:04 PM
    cgs2k2
    Nadeem
    2006 AC 4x4 OR
    will definitely be trying this tomorrow when it's not raining. thanks for the suggestion!
  9. May 2, 2010 at 9:07 PM
    desertdude59
    desertdude59 CRAZY 4WHEELER
    From the Mojave desert now in Wild and Wonderful W
    1991 toyota 4x4 sr5-lost but not forgotten
    4" lift after market front bumper bed mount lightbar/roll bar (4)6" kc's on the roll bar (2) kc flat back bumper mounts f/r gears for the 33's
    Toyota is starting to make me sad. :( Are all the guys on the assembly line DRUNK?
  10. May 2, 2010 at 9:10 PM
    desertdude59
    I know. You have to blame the guy that isnt here. lol:D
  11. May 2, 2010 at 9:29 PM
    cgs2k2
    Nadeem
    2006 AC 4x4 OR
    Well the thing is, the plow stuff came already hooked up and it was certified used which means everything should function when they sell it.
  12. May 2, 2010 at 9:34 PM
    cgs2k2
    Nadeem
    2006 AC 4x4 OR
    Yeah, you're absolutely right. I'll give em a call tomorrow and see what they say if this battery-unhooking thing doesn't work.
  13. May 2, 2010 at 9:35 PM
    desertdude59
    Just to let you know I wasnt blaming Toyota. They just have been kinda letting their rep slip a little.:(
  14. May 2, 2010 at 9:42 PM
    cgs2k2
    Nadeem
    2006 AC 4x4 OR
    I'm literally gonna do that. I'll try anything haha
  15. May 2, 2010 at 9:56 PM
    joes06tacoma
    Joe
    Central Coast, CA
    The dimmer relay that switches from low to high beams is in the underhood fuse box. There is a possibility that the contacts inside it are stuck. Sometimes, a sharp tap with a screwdriver handle or similar will unstick a relay. You could also try swapping it with another relay of the same type in that box.
    Otherwise, the dimmer relay is switched by the body control module, which looks at the position of the dimmer switch and decides what signals to send to the relay. If your problem is there, I imagine you will just take it to the dealer and ask them to take care of it.
    Just trying to give you a little help with a potentially simple temporary fix.
  16. May 3, 2010 at 9:19 AM
    cgs2k2
    Nadeem
    2006 AC 4x4 OR
    Did this and it worked!!! I guess something must really have been stuck or bumped out of place for whatever reason. Thanks for the help!
  17. May 3, 2010 at 5:53 PM
    joes06tacoma
    Joe
    Central Coast, CA
    Glad you fixed it! Now you know what part to replace if it happens again.
