Help or Advice - BAMF Bolt On Sliders Installation for 2nd Gen Taco
Discussion in 'North West' started by arifleman, Nov 1, 2015.
  1. Nov 1, 2015 at 4:48 PM
    arifleman
    arifleman [OP] Well-Known Member
    Pacific NW
    2002 TRD 3.4L Ext Cab
    Hi all. My son, SeattleCoug, is currently deployed with USMC, and his wife is trying to get some BAMF bolt on sliders installed on his 2015 2nd gen Tacoma in the next couple weeks before he returns. Looking for some installation recommendations or advice.
    I spent a couple hours earlier this summer trying to install the sliders. I remember they were a royal pain - all kinds of bolts and nuts, some with pre welded nut/plates and no directions enclosed. On the drivers side I couldn't get the sliders to cinch up tight to the frame, there were brake lines that were going to rub on one of the install bolts, a front bolt/nut was near impossible to reach in the frame box, a rear hole did not line up; and then the passenger side had some kind of an electronic box in the way and maybe the catalytic convertor was tight too - my memory is foggy. I do remember thinking welded on may have been a simpler option for these.
    Has anybody on here dealt with these sliders, know somebody or a shop that can install or weld them on in a fairly short timeline, or be able to suggest something, etc? I don't mind doing work if it is fairly straight forward, but I tend to draw the line when it comes to bending brake lines and mickey mousing a solution on somebody else's brand new truck.
    His wife is currently living in the Milton area and I am in Shoreline so if a shop performs the install the southend would be most convenient. We are open to suggestions. Thanks all!
  2. Nov 1, 2015 at 4:56 PM
    VolcomTacoma
    VolcomTacoma Well-Known Member
    Jeff
    NorCal
    2015 TRD Sport 4x4 6 Speed Supercharged
    Front- Camburg 4x4 Long Travel 2.5" King Coilovers 2.5" King Triple Bypasses Wheelers Superbumps Rear- DMZ SUA 16" 3.0 King Triple Bypasses 3" 2.0 Fox bumps Wheels and Tires- 295/75/16 Toyo ATII XTREME SCS SR8 Dark Matte Bronze 16" Lighting- (2) 30" Combo light bars (4) Iggycorp diffused pods Tepui Ayer TRD Supercharger URD Mark III 3" Exhaust URD 4x4 Y Pipe URD CAI URD 2.85 Stealth Pulley Hurst Core Shifter with Hurst T URD Stage 3 clutch URD Lightweight flywheel URD Throw out bearing upgrade AEM Wideband AFR Gauge Speedhut Boost Gauge Craven Speed Flex Pod mount Weathertech Floor Liners BAMF Sliders Ultragauge sPod SE ARB CKMTA12 Hella Supertone horns Relentless Tailgate Reinforcement
    @JLee If I recall correctly they should have come with instructions for install. I know some of pieces have to be finagled in before you install and that black box can be moved or something.
  3. Nov 1, 2015 at 4:59 PM
    JLee
    JLee The Man! Vendor
    Jerry
    Grass valley CA
    02 Extra cab SAS Linked front and rear
    I lost track thousands of dollars ago.
    Are these the 100% true bolt on sliders or the older set that need to be drilled?
  4. Nov 1, 2015 at 5:27 PM
    arifleman
    Pacific NW
    I was told they are true bolt on. He bought them this year as I recall. The sliders are drilled in multiple locations.
  5. Nov 2, 2015 at 12:42 PM
    JLee
    Jerry
    Grass valley CA
    Here is a good write up that one of my customers did https://www.tacomaworld.com/threads/install-how-to-bamf-100-bolt-on-slider.372255/
    I have yet to get a truck in the shop to do my own instructions we will have some on the site as soon as we get a truck to do so.
  6. Nov 2, 2015 at 1:54 PM
    arifleman
    Pacific NW
    Thank you for the link. Yeah, I remember much of that from when I was under it, only I wasn't able to able to draw up the bracket snug with a C clamp, and didn't think much of that brake line clearance. I've pulled engines and transmissions, rebuilt a few motors, so I am not a stranger under the car. I just think these are requiring more mods than a straight bolt on option should. I still think weld on is the way to go on these. If all else fails, I will just wait for my son and do the job with him when he has time, and he can wield the grinder, bend the brake lines, and mickety mouse as he sees fit. Like I said, I just can't bring myself to do those mods to someone else's brand new truck.
    One last shout out in case someone on here knows somebody or a shop in the southend that can install or weld them on in a fairly short timeline.
