Help ordering correct wheel width
Discussion in 'Wheels & Tires' started by Thomas2335, Mar 6, 2021.
  1. Mar 6, 2021 at 2:21 PM
    Thomas2335
    Thomas2335 [OP] Well-Known Member
    want to order new wheels for my ‘15 Tacoma. I think the factory wheels are 16 x 7. I’m not sure of the size I’m gonna buy yet (16 or 17). But I know I want to go to a 8” wide. My question is how do I order them so that the extra 1” is on the outside (front) of the wheel?
    TIA
  2. Mar 7, 2021 at 1:35 PM
    Pinion
    Pinion Well-Known Member
    Drew
    Brookings Oregon
    2020 DCSB limited 4x4
    Offset or ET, you will need to compare wheel offset with stock off set
    whatstcp likes this.
  3. Mar 7, 2021 at 2:03 PM
    6 gearT444E
    Deep South
    Herculiner Hootus
    find the factory backspacing, order new wheel with 1" wider with appropriate backspacing so that the extra width is on the outside of the hub.
  4. Mar 7, 2021 at 2:18 PM
    Pinion
    Drew
    Brookings Oregon
    ET 30 on stock 2nd gen, so if you match that, the extra will go out
  5. Mar 7, 2021 at 2:56 PM
    gotoman1969
    gotoman1969 Well-Known Member
    San Antonio, TX United States
    2015 Silver Tacoma PreRunner
    8 wide 0 offset is always a good choice. But knowing exactly what you have would help.
  6. Mar 7, 2021 at 3:38 PM
    Wattapunk
    Wattapunk Stay lifted my friends !
    Uncle K
    TX
    2005 DCLB 4WD
    OEM wheels 16x7 usually have a backspacing of 5.2". Go with an 8" wide wheel with a backspacing of 4.25"- 4.5" and you are good.
    6 gearT444E likes this.
  7. Mar 7, 2021 at 6:34 PM
    shift957
    shift957 Well-Known Member
    Cacapon River, WV
    11 AC OR
    This is a valuable tool. Great visual reference and you can change the values to see how it affects fit.
    badger likes this.
  8. Mar 7, 2021 at 6:55 PM
    DavesTaco68
    DavesTaco68 Well-Known Member
    North Thompson, BC
    2013 Tacoma TRD
    - ICON UCAs, BP51/Kings, SCS wheels, 285s, Leer 100XR canopy. Greenlane aluminum winch bumper, Smittybilt X20 winch. Trying Falken AT3w now, Really like BF KO2s.
    Check out SCS wheels, I have 17 x 8 Ray 10s with -10 offset and the tire sits outside the wheel well even if it’s a 265.
    They post the wheel specs on their website.
    https://www.stealthcustomseries.com/collections/toyota
  9. Mar 8, 2021 at 2:12 AM
    Pinion
    Drew
    Brookings Oregon
    They are always sold out
