Help out in the search for Flight 370..
Discussion in 'Off-Topic Discussion' started by 169.254.255.201, Mar 10, 2014.
  1. Mar 17, 2014 at 11:29 PM
    #221
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
  2. Mar 18, 2014 at 6:20 AM
    #222
    TheGrayRider
    TheGrayRider MARANATHA !!!
    NW Florida
    2017 BBP DC 4X4 OR
    "If a pilot disables the transponder — which can easily be turned on and off — all the air traffic controller will see is a radar blip. That’s roughly the same amount of data a controller received tracking flights during World War II."
    "In this case the countries’ radar coverage likely didn’t overlap. So if the pilots failed to check in, turned off the transponder and pulled the circuit breaker to the ACARS, the airplane would be completely off the grid — taken off the air, so to speak."
    Quotes from article below
    http://www.nydailynews.com/news/wor...flight-gird-aviation-expert-article-1.1723111
  3. Mar 18, 2014 at 4:46 PM
    #223
    wileyC
    wileyC Well-Known Member
    Centerville, OH
    2012 PreRunner Double Cab TRD Sport
    my questions:
    1) do these ATC centers have "primary" radars?
    2) if "2", then i assume they scan 360 deg in azimuth, ...but what about elevation?... do they scan an elevation raster, either mechanically or electrically steered?... if they do scan an elevation raster, then they should be able to get "some" info about the slant range, including the elevation component... of course, you'd be limited by the cell resolution (in both az and el), which naturally decreases w/ range to aircraft...
  4. Mar 18, 2014 at 8:49 PM
    #224
    TheGrayRider
    NW Florida
    2017 BBP DC 4X4 OR
    http://www.livescience.com/44012-malaysian-airlines-mystery-radar-tracking.html
    The primary is limited to 60 miles max and probably wasn't on at that time of night. This article says primary has a 200 mile range but that would only give you a blip on the ATC screen, no matter the elevation. When the pilots turned off the transponder which tells Malaysian ATC who, what, where, and how high ... Then ATC only had a blip with no flight information from the secondary radar
    I have been to airports (in the Phillipines) where ATC says they have you on radar but you know they don't
    This thread I found doesn't paint a good picture to me
    http://www.pprune.org/south-asia-far-east/471129-kul-atc-system-upgrade.html
  5. Mar 18, 2014 at 8:57 PM
    #225
    wileyC
    Centerville, OH
    ...yes, but what about military radars??? have they established confidence in the supposed track crossing back across malaysia at least? i'd presume there's some reluctance on the part of these countries in this region to cooperate and share info here... probably a big reason for making this a big charlie-francis...
  6. Mar 18, 2014 at 9:43 PM
    #226
    TheGrayRider
    NW Florida
    2017 BBP DC 4X4 OR
    Military is 100 nm or approx 115 miles ... But it is just a blip
    The Thai military says they might have seen it
    http://www.dailymail.co.uk/news/art...70-followed-twisting-path-Strait-Malacca.html
  7. Mar 18, 2014 at 10:14 PM
    #227
    TheGrayRider
    NW Florida
    2017 BBP DC 4X4 OR
    http://www.news.com.au/world/maldiv...ffort-criticised/story-fndir2ev-1226858579129
    Witnesses in Maldives report seeing a 'low-flying jumbo jet' around 6:15am
    They said plane was white with red stripes like a Malaysia Airlines jet
    The Maldives are islands to the southwest of the southern tip of India
    Approx 4.5 hours from Kuala Lumpur
    this tells me that this plane might have made the east coast of Africa - Mogadishu is 8.5 hours from KUL
    It all depends on how much fuel the aircraft actually had on board which at this point we really don't know
  8. Mar 18, 2014 at 10:19 PM
    #228
    Navar
    Navar Well-Known Member
    Corona CA
    07 Tacoma TRD Sport 4x4
    Washed it, Icon suspension, Icon UCA
    You would think with everything being turned off it was still track able by radar
  9. Mar 19, 2014 at 6:33 AM
    #229
    TheGrayRider
    NW Florida
    2017 BBP DC 4X4 OR
    When your flying at 500+ knots you fly out of radar range quickly
    The radar is for keeping up with the aircraft in the area of the airport the radar services ... That's why ATC gives the pilots a 4 digit number code to squawk so the radar can interrogate the aircraft transponder and the ATC screen will show the aircraft's position and flight info
    If the transponder is turned off ... aircraft is just a blip on the screen
    as long as the blip didn't come near another aircraft that ATC was following... ATC probably ignored the blip that could have been MH370 since the aircraft was turned over to SAG ATC in Vietnamese airspace
  10. Mar 19, 2014 at 6:28 PM
    #230
    wileyC
    Centerville, OH
    question of the day: how is it that malaysia airlines doesn't know how much fuel was on the plane?...
  11. Mar 19, 2014 at 7:47 PM
    #231
    TheGrayRider
    NW Florida
    2017 BBP DC 4X4 OR
    There should been a standard fuel load for the Kuala Lumpur to Beijing route.
    The airline knows what that is ... also they aren't the only airline that flies that route ... for whatever reason nobody is talking
    I found this and this basically is what I think happened concerning the fuel loaded prior to takeoff... thoughts from a 777 captain ... British I'm guessing
    Our man in the cockpit tells us that it would be normal to have enough fuel to arrive at Beijing, then to divert to another airport (+1 hour) plus a further reserve (+30 minutes more, give or take). Thus the plane would normally have taken off carrying fuel for perhaps 7 hours 30 minutes in the air. If the captain wanted, "he could easily take another hour's fuel without the copilot becoming too suspicious, especially in such a vertical crew culture as the far eastern carriers have". (Normally a captain tries not to overload a plane with fuel as air-freighting fuel from airport to airport costs fuel - and thus money - in itself.)
    Our man adds: "IF they were both in on some type of plan they could have filled it up to whatever level of fuel they wanted, all the way to maximum tanks fuel which could give them 13-14 hours endurance at the limit". :eek:
    http://www.theregister.co.uk/2014/0...ery_the_iel_regi_pubdinnerparty_guide/?page=1
  12. Mar 19, 2014 at 8:25 PM
    #232
    RAT PRODUCTS
    RAT PRODUCTS Well-Known Member
    Farmington, MN
    Cummins Coal Roller
    Smokin with a smarty.
    They could fly at higher altitude and save fuel too. They made it to the moon.
  13. Mar 19, 2014 at 8:29 PM
    #233
    Ice Horse
    Ice Horse Stalking horse
    Lauren
    Colorado
    98 3.4L V6 TRD Ext. Cab 4x4 SR5
    ADS Racing Shocks 2.5" Extended Travel Coilovers with Reservoirs, 3 inch All Pro rear suspension kit, factory E-locker, Trail Gear sliders and front stinger bumper, CBI Offroad rear tube bumper, XRC8 Winch, 33 inch BFG KM2's, 16 inch Ivan Stewart Wheels, Uniden CB radio, flip up license plate, white tail lights, LED front signals, Tundra front brake upgrade, new radio, rock lights, sub woofer, remote start, satoshi grille with Prius emblem, Rigid DOT/SAE Fog Lights, 12" Light Bar
    They just found possible debris. Waiting to hear more
  14. Mar 19, 2014 at 8:39 PM
    #234
    Watari06V6
    Watari06V6 Faster than a speeding ticket
    Wounded Knee
    TRD-V6-SR5-06
    ....this is it- finally. they're combing the area west of down under.
  15. Mar 19, 2014 at 8:49 PM
    #235
    zopperman
    zopperman LED & HID positive
    Zak
    Arlington, VA
    03 4Runner
    Lift, 32" Duratracs, sliders, LED light bar, interior LEDs, sweet tunes & sub, OBA, sliders, TRD 16" 6 spoke wheels, CB, HID spotlights, electrical mods, etc.
  16. Mar 19, 2014 at 8:51 PM
    #236
    OZ-T
    Peter North
    British Columbia
  17. Mar 19, 2014 at 8:55 PM
    #237
    169.254.255.201
    169.254.255.201 [OP] Well-Known Member
    Interwebs
  18. Mar 19, 2014 at 8:57 PM
    #238
    Ice Horse
    Lauren
    Colorado
    Sending a plane out now actually since it's about noon there
  19. Mar 19, 2014 at 9:10 PM
    #239
    TheGrayRider
    NW Florida
    2017 BBP DC 4X4 OR
    Any satellite pics from tomnod ?
    They better drop at least one sonobuoy !!!
    If the aircraft is in the water there those ULBs on the CVR, FDR, & ELT will still be pinging
  20. Mar 20, 2014 at 12:39 PM
    #240
    01TacoBuz
    01TacoBuz Well-Known Member
    In the woods
    01 Tacoma SR5
    K&N drop in filter, URD rear simulator, Deck plate mod/home made CAI, No rear cat, MagnaFlow muffler
    If you like your commercial flight you can keep it.
    Im from the show me state, I will believe it when I see it and even then I wont believe very much that the news says about it, they lie too.
