HELP? Over torqued my fill and drain plugs
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Redtaco777, May 9, 2025.
  1. May 9, 2025 at 10:41 PM
    Redtaco777
    Redtaco777 [OP] Member
    Hey guys so I just recently changed the rear and front differential fluid..
    I just noticed that I might have been reading my torque wrench wrong and may have accidentally over torqued the fill and drain plugs over by 7ftps more than the specs…
    should I loosen them up and re-torque them?.. could I have caused any damage or am I totally fine and just overthinking this?
    thanks,
  2. May 9, 2025 at 10:47 PM
    TacoJoeBro
    TacoJoeBro Well-Known Member
    Not Joe
    Midwest
    12 DCSB OffRoad
    6112/5160 Icon RXT JBA KO2
    Only problem I can think of would be crush washers may leak at new lower torque value. Easy enough to replace fill plug washer. Obviously replacing drain plug washer would cost you your fluid…
    scocar likes this.
  3. May 9, 2025 at 10:47 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Don't worry about it
    lowmower and Extra Hard Taco like this.
  4. May 10, 2025 at 5:21 AM
    JAGCanada
    JAGCanada Well-Known Member
    Canada
    2010 TRD Sport V6 Auto Double Cab MGM
    I wouldn't worry about that. I'd leave it until the next time you change the fluid. Worst case would be you stripped the threads. Those parts are pretty beefy and you over torqued by about 20%, which isn't crazy. If you stripped the threads you'd know - the parts wouldn't tighten and it would leak. Your good, just leave it.
    I over tightened my drain plug on the transmission pan before. I stripped the threads and couldn't tignten the bolt correctly. I knew right away.
    lowmower likes this.
  5. May 10, 2025 at 5:37 AM
    Tacologist
    Tacologist Well-Known Member
    Bob
    Tenessee
    05 Double Cab Shortbed
    Rear leaf suspension. Home done tailgate re-inforcement.
    Your wrench could be off by 7 fps. Nothing to sweat over.
    lowmower and Jojee117 like this.
  6. May 10, 2025 at 5:46 AM
    ridefreak
    ridefreak Well-Known Member
    NM
    2006 DCSB TRD
    minor tweaks
    Torque wrenches often cause more problems then they solve. You're better off not using one then using it incorrectly.
    lowmower and 3JOH22A like this.
  7. May 10, 2025 at 5:50 AM
    Extra Hard Taco
    Extra Hard Taco Well-Known Member
    R.J.
    Devil's Island
    2012 Tacoma TRD OR, 2007 DC (sold), 2003 TRD OR (sold)
    ARB Bumper, SOS sliders, SOS rear bumper, SOS skid plate. OME Lift. Some other stuff.
    In all the fluid changes I've done I've never used a torque wrench.
  8. May 10, 2025 at 9:56 AM
    Waasheem
    Waasheem
    2007 xrunner
    I was tightening caliper bolts using a torque wrench. I kept tightening, it didn’t click, ended up bending a bolt. What seems to help prevent that is to tighten a little at a time letting off pulling each time.
    Now I very rarely use mine, exceptions being something critical like a head gasket, or something with a gasket and multiple fasteners. In that situation I get all fasteners in, then finger tight minus a quarter turn, then finger tight, then tight as I can get them without a tool, then somewhere 20-30% of the spec, then around 60%, then around 90%. Leave it sitting a few minutes, then final torque.
    Most torque wrenches have a +-4% or so. Most also should be backed down to zero when stored so you’re not leaving the spring compressed, my inch pound one is like that. My foot pound one is twin bar or something like that and doesn’t need to be zeroed.
    7 is very little, you’re probably ok to leave it. Possibly it’s hard to remove after multiple hot cold cycles. You could loosen & retorque if you want, I wouldn’t. It might create a leak.
  9. May 10, 2025 at 10:11 AM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    The plugs are 18mm diameter threading into steel. If they haven't stripped out at the time when you tightened them, then they're OK as-is.
    JAGCanada likes this.
  10. May 12, 2025 at 6:16 AM
    outdoorgb
    outdoorgb (.)(.)
    Burbs of Oregon
    2014 DCSB TRD Sport Silver Sky...
    I don't have the torque specs handy but your torque wrench is within +/-3% of the value shown on the wrench. You will be fine.
  11. May 12, 2025 at 6:28 AM
    Clearwater Bill
    Billy
    Largo Florida
    Yes.
    Peter603Taco and lowmower like this.
  12. May 13, 2025 at 9:59 AM
    offroad&ontap
    offroad&ontap Well-Known Member
    Ted
    San Diego, CA
    2015 MGM ACLB 4x4 V6 6MT
    Like all others are saying, you're good!
