Help: Overfilled transmission
Discussion in '3rd Gen. Tacomas (2016-2023)' started by krisc, Feb 12, 2017.
  1. Feb 12, 2017 at 2:14 PM
    krisc
    krisc [OP] Member
    I have a 2017 OR and thought the transmission fluid was low. Stupid me overfilled it. I removed the overflow (check) plug on the pan and drained out pretty much what I put in. Is the transmission full now? I just want to make sure and not destroy my transmission. Thanks
  2. Feb 12, 2017 at 2:20 PM
    Herniator
    Herniator Well-Known Member
    Edmonton
    2016 Toyota Tacoma TRD Sport
    chrome valve stems covers
    Was the temp of the transmission hot when you reopened it?
    Is has to be in a certain temp range when you check it.
  3. Feb 12, 2017 at 2:20 PM
    GPsevinSixx
    GPsevinSixx Well-Known Member
    Ros Angerus
    2015twoAX2.4techPAWS
    6112/5160AALfnCNTSTRyokG015
    Take it to Toyota and have them check it. You can do it on your own, but the process is lengthy and can be done without the techstream. It's a matter if setting the PCM into a diagnostic mode with a series of shifter positions going back/ forth and getting the trans fluid up to specified temp with engine running, but not to normal driving temps. There's threads on this with the TIS service manual explaining it in detail. Need to find the one that applies to your transmission too!
    From the way you've explained your method, I would highly suggest you take it into the dealer.
    George1441 likes this.
  4. Feb 12, 2017 at 2:27 PM
    krisc
    krisc [OP] Member
    It was maybe warm when I drained it the first time. That's when I got out what I had put in it. I drove it down the road about 2 miles and drained it again and got just a little out.
  5. Feb 12, 2017 at 2:28 PM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    Is it a manual or automatic?
  6. Feb 12, 2017 at 2:28 PM
    Herniator
    Edmonton
    The fluid expands when it is hot.
    shakerhood likes this.
  7. Feb 12, 2017 at 2:43 PM
    krisc
    krisc [OP] Member
    automatic
  8. Feb 12, 2017 at 2:45 PM
    Bishop84
    Bishop84 Well-Known Member
    You'll be fine, the overfill plug is just that, as long as you were under 40 degrees C it didn't evacuate critical fluid.
    That said it needs to be adjusted properly using a scan tool.
  9. Feb 12, 2017 at 3:17 PM
    kahanabob
    kahanabob Well-Known Member
    Maui
    16 TRD 2WD 4DR
    no worry's...as long as you did not do it when at running temp.
  10. Feb 12, 2017 at 5:16 PM
    Storman
    Storman Fukitol abuser
    South Western PA
    2017 SR AC 4x4 AT AC UP ->LONG BED<-
    Whole bunch of shit! $$$
    A scan tool for checking trans fluid?
    You mean getting it into temp mode, right?
    A scan tool doesnt check your trans fluid level.
  11. Feb 12, 2017 at 6:08 PM
    Bishop84
    Toyota has made it clear they want all trans checked with the high temp tool. It's double the D blinking light temps. You need a ATM temp tool.
  12. Feb 12, 2017 at 7:20 PM
    sathump
    sathump Member
    It's 95-113*F if it's warm and you can hold your hand on the case; it's not too hot.
    Storman likes this.
  13. Feb 12, 2017 at 7:27 PM
    Barcared
    Barcared Well-Known Member
    Philadelphia, PA
    2016 Barcelona Red TRDOR RIP. 2020 MGM TRD OR.
  14. Feb 12, 2017 at 7:28 PM
    Hobbs
    Hobbs Anti-Lander from way back…
    Yep…
    Rock Bangen', Desert Tamin', Gold Findin' Machine!
  15. Feb 12, 2017 at 7:28 PM
    Barcared
    Philadelphia, PA
    Or you can use this pdf
    GPsevinSixx likes this.
  16. Feb 12, 2017 at 7:35 PM
    GPsevinSixx
    Ros Angerus
    Those are the ones that worked for me! Thanks for reposting those.
