Help P0420 and P0430
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Huntfish53, Jul 25, 2013.
  1. Jul 25, 2013 at 6:58 AM
    Huntfish53
    Huntfish53 [OP] Member
    Chantry
    Adairsville
    '06 Access Cab TRD Off-Road Prerunner 6spd
    Check engine light came on and both of those codes came on at the same time.
    "Catalytic system efficiency below threshold (Bank 1)"
    "Catalytic system efficiency below threshold (Bank 2)"
  2. Jul 25, 2013 at 7:47 AM
    Azntrutek
    Azntrutek Well-Known Member
    ATL
    08 TRDsport -Towpackage
    2".5 lift, HID head lamp and HID lights, color match tonneau cover and running board.
    Upstream and down stream Oxygen sensor.
  3. Jul 25, 2013 at 10:14 AM
    Huntfish53
    Chantry
    Adairsville
    Aren't there 4 sensors? Which ones exactly?
  4. Jul 25, 2013 at 10:16 AM
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
    What's your mileage? If under 80,000 take it to the dealership now!! Cats are covered until 80,000... I missed out on that and had to buy new manifolds.
  5. Jul 25, 2013 at 12:27 PM
    Azntrutek
    ATL
    Well wipe out your multimeter to check the current each sensor ... That's how you find out .
  6. Jul 25, 2013 at 2:27 PM
    Huntfish53
    Chantry
    Adairsville
    I'm at 116k on mileage
  7. Mar 12, 2014 at 4:55 PM
    Bigdog
    Bigdog Member
    Indiana
    2005 DoubleCab SR5 4x4
    I got the check engine light several weeks ago, read the codes, reset the codes and they came back real quick. I was just about to flip the switch on new cats, but ordered new OEM O2 sensors, then I read about running 87 oc gas. So I fill up with 89 oc gas and in one day of about 50 miles driving the check engine light goes out. So what to think, was cheap gas my problem? Time will tell. I think I will reset the codes in the cpu tomorrow and see what happens.
  8. Apr 21, 2014 at 5:52 AM
    Leaky
    Leaky Active Member
    How did you make out with switching gas? No more codes?
  9. Oct 6, 2014 at 8:40 AM
    Bosser
    Bosser New Member
    P0420 Code 04 Tacoma
    Hello,
    I've been fighting the P0420 code since June (it is now october). CEL came on and brought it in. First they changed the front cat, fine for a 2 days then light came back on. Then they swapped out the rear cat. Same thing, fine for a week or so then the light came back on. They said they changed out the sensors and cleared the code but then it came back again. Finally after talking to the manager, they did a complete change out of everything, both cats and sensors. The sensors are the densos but the cat i believe is still an aftermarket cat from napa. This kept the light off for about 3 weeks, but boom...light came... (btw, the truck is an '04 tacoma with 320K miles...) any suggestions? Do i bite the bullet and get the OEM cat?
