help... P1130 & P1133
Discussion in '1st Gen. Tacomas (1995-2004)' started by Rock Dog61, May 15, 2018.
  1. May 15, 2018 at 8:44 AM
    Rock Dog61
    Rock Dog61 [OP] New Member
    2001 Taco
    4 cyl with 380,000 miles... hoping to do V6 swap
    2001 Taco 3rz 4wd.. 350K Purchased as a project. Ive done a ton of work including and engine swap for same eng,,, 1/2 the miles. it runs good.
    Check eng comes on after cpl miles of driving... 2 drive cycles and its on every time. Codes are P1130 and P1133.
    This very well could be a wiring issue... I have so far found 2 broken wires in the main harness near drivers side firewall that were damaged by a drill mounting the inner fender. I pulled on every wire.. I think I got them all.
    I need to know what each of the 4 wires should be reading at the A/F sensor on the truck side of plug with sensor disconnected. Here is what I show currently.
    white/red Battery Voltage 12V
    White wire... 2.0V
    Pink 2.9
    Violet 2.9
    All reading are Key on Engine off... Are these correct??
    Thanks for the help.
