HELP:Passenger brake light not working after slider instal.
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Tacomakidatheart!, May 8, 2020.
  1. May 8, 2020 at 12:34 PM
    Tacomakidatheart!
    Tacomakidatheart! [OP] Member
    Long time lurker/student and have already searched the forms.
    Installed sliders last weekend and since then passenger side brake light not working. checked electrical connections drivers side box, bulb is good and even checked fuse. All other lighting works fine. Did the job solo which might be part of the problem?
    Trying to avoid taking it to the dealer since its still under warranty. 2020 OR
  2. May 8, 2020 at 12:40 PM
    Ronzio
    Ronzio Well-Known Member
    Pennsylvania
    17 DCSB TRDOR
    Bolt on or did you burn them on?
  3. May 8, 2020 at 12:42 PM
    Tacomike18
    Tacomike18 Well-Known Member
    J
    I was thinking the same thing. If you weld it on, make sure the ground is good and not near essential components.
  4. May 8, 2020 at 12:57 PM
    jmauvais
    jmauvais Received 2 votes in a poll one time.
    NorCal
    2018 TRD OR 4x4 DCSB
    ...stuff
    Or bolt on, make sure you didn’t pinch any wire harnesses
    Tacomakidatheart![OP] and over60 like this.
  5. May 8, 2020 at 1:25 PM
    Tacomakidatheart!
  6. May 8, 2020 at 1:28 PM
    Tacomakidatheart!
    Took all wire harnesses off checked brake light again and still not working. Ran my hand along the cable as far as possible both forward and backward. Then reattached.
  7. May 8, 2020 at 1:47 PM
    rob4092xx
    rob4092xx Well-Known Member
    Phoenix, AZ
    If you bolted them on remove them and take to dealer.
    Tacomakidatheart![OP] likes this.
  8. May 8, 2020 at 2:21 PM
    Tacomakidatheart!
    Was afraid of that.
    Thanks
