HELP! Passenger HID fail
Discussion in 'Lighting' started by BenJammn5, Sep 3, 2010.
  1. Sep 3, 2010 at 11:57 PM
    BenJammn5
    BenJammn5 [OP] RN
    San Jose
    09 TRD-Off Road PreRunner
    TRD cat-back with Spintech prostreet muffler, AFE Pro dry S intake, 16" SCS F-5, 3.5 BS, 305/70 GT Radial MT, King extended travel front/rear, 2" add-a-leaf, Maxtrack Spindles, Sway bar delete, DSM UCA, All Pro IFS skid, Cab mount chop, bed cab locks, Black badges, cali raised amber LED fogs, 6K FX-R Morimoto projectors with 55watt ballast, fog mod, cheap rear dust lamp from autozone, Hellas 500 behind grill, Color match Satoshi Grill, Hood scoop, rear bumper by BTF, color matched Glassworks bed caps, Wet Okole seat covers
    Girlfriend got me an Xtreme HID kit from xenondepot.http://www.kbcarstuff.com/HID-Kits-s/216.htm
    for our anniversary.
    6500K Hi/low beam
    3000K Fog
    I got everything hooked up, but the passenger side refuses to shine!
    Connection to ballast-check
    Connection to factory plug-check
    I don't need to ground the passenger side right? Only the driver side with the battery (obviously driver side cause it works..)
    I performed identical procedure on the passenger side as I did the driver side, only thing I didn't do was connect to the postive battery terminal and ground to the body, cause well, there just aint a battery on my passenger side... do I need to make a connection from passenger side to driver side?
    Ran out of time today but could switching the ballast's do the trick? They're both the same, negative and postive battery connections on each ballast/relay connection. Maybe a bad bulb? Bad ballast? Maybe the bulb isn't fully connected? Psh... I dunno... just wanted to know what you guys thought. Sorry for the hasal
  2. Sep 4, 2010 at 6:59 AM
    IamTacO
    IamTacO red balls got me!
    adam
    QC az
    01 Prerunner SR5 TRD-Offroad
    4x2 Prerunner. Hankook Dynapro ATM rf10 265-65-16, e-locker FTW! Morimoto d2s bi-xenon HID projectors, Philips 85122+ 4300K, Cobra 75 w/ 3' firefly, Kenwood KDC-MP342U w/ SIRIUS, Line-x bed liner, 4' coretrax(black)
    Both sides need a ground
  3. Sep 4, 2010 at 10:47 PM
    yosh2000
    yosh2000 Well-Known Member
    CO
    '17 Tundra CM 5.7
    find a new girlfriend...good girlfriends dont give their boys a HID kit....a good girl would give him a retro....:D
    other than that...^ post is right...think about it, you are giving the ballast power, but now grounding it to anything...;)
