Help! Passenger window stopped working
Discussion in '2nd Gen. Tacomas (2005-2015)' started by tisher49, Mar 23, 2011.
  1. Mar 23, 2011 at 6:26 PM
    tisher49
    tisher49 [OP] Well-Known Member
    Alex
    Orange, Virginia
    '08 4.0L 4x4
    K&N Air Filter, Westin Bull Bar with PIAA fog lights, Retrax cover, Alpine Head unit with I-Pod interface, maglite mount, Color matched grill surround w/ Grillcraft mesh
    Went to get groceries today and had my windows down and when i tried to roll my windows up the driver side worked but passenger side did not. Previous to today the motor had shown no signs of slowing down or anything like that. I did recently have a sound system installed so my thinking (hoping really) is that a cord popped loose and the window motor isn't dead. Any way that I can check this?
    Also any good ideas on how to get my window up in the mean time without damaging the motor or the window? We got rain tonight so I have it taped up with a garbage bag but I feel like such a tool with my window like that. Thanks in advance for any help.
  2. Mar 23, 2011 at 6:33 PM
    ruslanus
    ruslanus Well-Known Member
    Rus
    Wasilla, AK
    I don't know any way to get the window up without actually taking the panel off. I would take the panel down and check all the wires and connections. I'm sure someone will have an idea.
  3. Mar 23, 2011 at 6:38 PM
    tisher49
    Alex
    Orange, Virginia
    '08 4.0L 4x4
    yeah I'm hoping to avoid taking the panel off if possible... neither the driver side switch or the passenger side switch work for the passenger window if that helps anyone with the troubleshooting.
  4. Mar 23, 2011 at 6:44 PM
    jandrews
    jandrews Carolina Alliance Southwest Region Ambassador
    '09 FourDubDee TRD OR
    Just pull the door panel...not exactly rocket surgery.
    If something's loose, plug it back in.
    More likely your regular shit the bed, in which case pray for warranty, because they're pricey little bastards.
  5. Mar 23, 2011 at 6:48 PM
    anethema
    anethema Well-Known Member
    J
    Dawson Creek,BC
    08 TRD OR Access cab 4x4
    ARB Bumper,OEM Roof rack modded for access cab, Allpro Rock Sliders,Icon Adjustable coilovers,More Tie Downs in bed, Firestone Airbags in rear,Block heater
    Make sure your lock out button is not pressed on the drivers side. If pressed you can't work the passenger window from either side. I have almost come to the point of disassembling the door the first time this happened before I thought to check it.
  6. Mar 23, 2011 at 8:53 PM
    tisher49
    Alex
    Orange, Virginia
    '08 4.0L 4x4
    i'm gonna cross my fingers and really, really, really hope that's the case because this happened to me when I first got the truck and I just remembered it.
  7. Mar 23, 2011 at 8:54 PM
    tisher49
    Alex
    Orange, Virginia
    '08 4.0L 4x4
    just wanted to see if there was another spot to check first...hopefully its just the window lock button
  8. Mar 23, 2011 at 9:01 PM
    tisher49
    Alex
    Orange, Virginia
    '08 4.0L 4x4
    ok ill have to check it in the morning cuz its pooring out now and its taped up tight enough for tonight.
  9. Mar 23, 2011 at 9:52 PM
    anethema
    J
    Dawson Creek,BC
    Hope it is that and I was able to save you a bunch of trouble! If you go press it on the drivers side door now could have your window sealed for the rain. Suck if the tape came off.
  10. Mar 23, 2011 at 11:01 PM
    ruslanus
    Rus
    Wasilla, AK
    this is gonna be funny if it was just the window lock button :). But it's always the little things that get overlooked
  11. Mar 23, 2011 at 11:06 PM
    NelsonTacoma
    NelsonTacoma This is my derpawayinator!!!!!
    Tucson, AZ
    06 PreRunner TRD Sport 03 4Runner Limited 4wd
    Bilstein 5100's , 6000k HID Hi/Low Kit, Magnaflow Muffler, 1.5 inch AP Wheel Spacers, Mudflap Delete
    One quick way to check it for window motor failure is to get in the truck turn the key on then while holding the switch for the window SLAM the door shut and sometimes it will jar the motor and make it work again. I use this method to diagnose window motor failures all the time.
  12. Mar 24, 2011 at 4:25 AM
    jandrews
    Pesky solenoids.
  13. Mar 24, 2011 at 7:13 AM
    anethema
    J
    Dawson Creek,BC
    It's true, I totally wont be laughing at the guy if it is. It happened to me and I was like 'fuuuuuuu' since I only had powertrain warranty at that point. So got my tools out opened the passenger door...then DING!...waiiit a second.
    Went over to drivers side door, sure enough button pressed.
    I didn't even think about it since I NEVER use this button. I imagine its for children or some such, but it didn't even enter my though process.
    Anyways, OP..what is it! The button??
  14. Mar 24, 2011 at 7:19 AM
    2000GTacoma
    2000GTacoma Well-Known Member
    Snow Hill NC
    00 Tacoma Ext. 3.4L SR5
    the contacts on my passenger switch got dirty just took it apart cleaned them and it went back to work. although i could work mine from the drivers side. so obviously its not that check button them wiring them so forth my advice
  15. Mar 24, 2011 at 7:58 AM
    tisher49
    Alex
    Orange, Virginia
    '08 4.0L 4x4
    stupid button. I can't even imagine when I would have hit it and since I never use it I didn't even think to look at it. What gets me is I've never seen or been in another car that when you use the window lock feature, it doesn't let the driver controls still adjust the windows. I'm not sure why you'd want to prevent yourself from opening a window...
    But I can't complain cuz I'm definitely the idiot here lol. Must say that I did do a nice job taping up the window. If anyone has to do this for real use duct tape. I did it once with painters tape cuz thats all I could find but once it started raining it just slid off.
    There should be some sticky thread with the title "Think you window is broken" or something and then have the button reminder on the thread so people don't do what I did and freak out and immediately start a thread lol.
    Thanks for the responses and for saving me the time and money I woulda spent bringing it to the dealer if yall hadn't reminded me of the button.
  16. Mar 24, 2011 at 4:43 PM
    anethema
    J
    Dawson Creek,BC
    Glad I could help!
  17. Mar 24, 2011 at 10:26 PM
    ruslanus
    Rus
    Wasilla, AK
    Lol, I'm glad it wasn't something major.
  18. Mar 24, 2011 at 10:33 PM
    Simon's Mom
    Judy or Jude :)
    SBurl Vermont
    13 TRD OR DC MGM
    Stock for now
    Simon hits that button all the time. I am glad it was an easy fix without having to tear anything apart or spend money. :)
