Quick Links:Picking up cap - what prep?
Add Variable-speed wiper to base Tacoma - missing wires?
Crank Pulley Bolt Removal - Easy Way!
LCA Cam bolts $$$$ !!!!!
Need to ID part numbers: Rubber seal and clips on top of OEM grille
How many u joints when removing propeller shaft to do carrier bearing replacement?
help passing smog
Discussion in '2nd Gen. Tacomas (2005-2015)' started by fiestee23, Mar 11, 2014.
