Help picking some equipment?
Discussion in 'Audio & Video' started by bradu81, May 31, 2009.
  1. May 31, 2009 at 6:28 PM
    bradu81
    bradu81 [OP] Well-Known Member
    N. California
    Silver Dbl Cab 4x4
    Hello all, been looking at finding a sub for my tacoma double cab. My friend gave me an old school rockford fosgate punch 75.2 which got me started on this. I am totally new to car stereos and don't really know which way to go as far as subwoofers, head units, etc...some quick questions...i am currently in the process of building a sub enclosure...thanks for the pictures of mrmarv's work!
    Here are the specs on the sub
    • [SIZE=-2]2-channel "Punch" Amplifier.[/SIZE]
    • [SIZE=-2]Output Power (4 ohms) 37.5W x 2.[/SIZE]
    • [SIZE=-2]Output Power (2 ohms) 75W x 2.[/SIZE]
    • [SIZE=-2]Output Power Bridged(4 ohms) 150W x 1.[/SIZE]
    • [SIZE=-2]Distortion Max (4 ohms) 0.05%.[/SIZE]
    • [SIZE=-2]Frequency Response (+/- 0.5dB) 20Hz - 20kHz.[/SIZE]
    • [SIZE=-2]Signal to Noise (A-weighted) >100dB.[/SIZE]
    • [SIZE=-2]Input Sensitivity (+0dB gain overlap) 150mV - 3.0V.[/SIZE]
    • Bridgeable.
    • Punch EQ (45 Hz / 20kHz).
    • Crossover 80Hz.
    • Xcard Crossover.
    looking for a 10IN sub which one? JL and rockford fosgate both make a slim one...any opinions on them
    2 ohm or 4 ohm? why...why not?
    Also, head unit...i have a pioneer premier in my wrx but i hate the ipod interface on it. I was leaning towards a sony CDX-GT930UI
    http://www.sonystyle.com/webapp/wcs...10151&langId=-1&productId=8198552921665801140
    thanks for the help guys!
  2. May 31, 2009 at 6:35 PM
    tacoholic
    tacoholic 09 but I drive a 012 Expedition...
    Jeff...I'm pretty sure
    East Bay, CA
    Quite possibly, someday...
    X2! I always need info on stereo systems...
  3. May 31, 2009 at 7:07 PM
    commtrd
    commtrd commtrd
    Corpus Christi TX
    09 Access Cab 4wd V6
    X3...clueless about stereo equipment for my '09 access cab. I am really disappointed with the stereo in this truck. The one in my '07 was much much better than this one. Any recs between the Alpine or Pioneer? Also front door speakers and a possible amplifier unit which can be hidden? Been researching on crutchfield etc. Not interrsted in winning any loud stereo contests but would like clean clear punchy audio with good tonal reproduction. Also do not care about mp3 / ipod interface.
    Any help / insights on this greatly appreciated.
  4. May 31, 2009 at 7:43 PM
    commtrd
    commtrd commtrd
    Corpus Christi TX
    Also compatibility with the steering wheel controls? I may try the speakers first (front door) with stock deck and see how that sounds.
  5. May 31, 2009 at 7:43 PM
    GoBlueFan
    GoBlueFan Well-Known Member
    Jon
    Bossier City, LA
    08 SR5 PreRunner
    Step bars, billet grill with custom TOYOTA, MB Quart RSI 216 components, Hifonics ZXi 4410, RAAMmat deadened doors/back wall/roof covered with ensolite , 24" Magnaflow muffler, hand polished stock exhaust tip, tinted, OEM TRD Bilstiens all around with 1/4" spacers up front to level it out. Sport wheels added.
    You'll be wanting a 4 ohm sub (or a dual 2 ohm sub). Reason being, that punch amp will not do 2 ohm mono.
    Sub wise, you will basically be looking at a price point on which one to buy. Seems most of them (there are several) are decent and your enclosure will make a larger difference in performance than brand.
  6. May 31, 2009 at 8:03 PM
    itsmyturn
    itsmyturn Well-Known Member
    Victorville, CA
    08 dbl cab TRD sport
    afe Pro-Dry S dropin, Readylift leveling kit, TRD skid plate, Alpine CDA-9887, 6K D2S HID
    for the specs you posted on the amp, i would look for a sub that has a high efficiency rating. a sealed enclosure will lower that rating. and you will need a 4 ohm load for that amp. most any 10 in sub under 5.25 inches will fit, although mrmarv has gotten other sub to fit.
  7. May 31, 2009 at 8:04 PM
    itsmyturn
    Victorville, CA
    if you want the best ipod controls, check out alpine. and you'll need a PAC adapter for the steering wheel controls
  8. May 31, 2009 at 8:23 PM
    bradu81
    N. California
    Silver Dbl Cab 4x4
    thanks for the info. I don't have the steering wheel controls so thats not an issue.
    I will definitely look at the alpines...
    Excuse some more newb questions...
    the specs on the sub say bridged output at 4ohms=150x1...since i am only running one sub i can bridge this amplifier and put all the power behind it..yes?
    in regards to 2, 4, dual 2 ohm subwoofers..what is the difference b/w 4 and 2 duals? some of the subs that i am looking at say dual voice @ 2 ohms...would you want to run one of those or would you purchase a 4 ohm subwoofer?
    thanks
  9. May 31, 2009 at 8:37 PM
    itsmyturn
    Victorville, CA
    yes you can bridge the amp to put all the power behind your sub.
    dual voice subs give you different wiring options to get the most power from your amp. in your case that amp is rated like most amps-2 ohm stereo, 4 ohm bridged. since you want to bridge the amp you will need a sub that shows the amp a 4 ohm load. either a single voice coil 4 ohm sub, or a dual voice coil 2 ohm sub wired in parallel. for simplicity you could go with a single 4 ohm voice coil. if for any reason though you upgrade your amp and not the sub, your new amp should put out max power at 4 ohms. hope this helps.:D
  10. May 31, 2009 at 10:08 PM
    bradu81
    N. California
    Silver Dbl Cab 4x4
  11. Jun 1, 2009 at 5:30 AM
    GoBlueFan
    Jon
    Bossier City, LA
    08 SR5 PreRunner
    If you are set on RF than yes that will work. You will wire the voice coils on that particular sub in series in order to achieve that 4 ohm load.
  12. Jun 1, 2009 at 5:32 AM
    GoBlueFan
    Jon
    Bossier City, LA
    08 SR5 PreRunner
    You would wire that in SERIES to get that 4 ohm load. Parallel will halve the ohm load. In this case you'd end up with a 1 ohm load, not a good thing for this punch 75. :gossip:
  13. Jun 1, 2009 at 8:53 AM
    bradu81
    N. California
    Silver Dbl Cab 4x4
    Thnks goblue...not set on any particular brand but i found it at my local shop for 90 bucks....anything that you would recommend for under 200?
  14. Jun 1, 2009 at 9:17 AM
    GoBlueFan
    Jon
    Bossier City, LA
    08 SR5 PreRunner
    Heck, for $90 bucks you can't complain at all. If you like it, get it.
    When you buy any speaker it's a personal choice for the most part. I plan on putting a MBQuart shallow-mount sub in mine. No real reason other than to match the components in the doors for continuity. I've had other systems mis-matched and were just fine. I tend to follow the KISS principle of Keep It Simple Stupid.
    Go with what you like...stick with a reputable brand...and shop for the best price on it once you decide what you want. Your install is what will make or break your sound quality in your system.
  15. Jun 1, 2009 at 7:38 PM
    Jimirich
    Jimirich Well-Known Member
    Hawaii
    08 4x4 Dbl cab shorty O.R. pkg
    DTRL, Debadged, Donkey tethered in the bed that rips 142 db farts so I can piss off the neighbors and rattle the windows on my house when I'm parked in front.
