Help picking tires for my suspension setup
Discussion in 'Wheels & Tires' started by ratcityrain, Nov 20, 2019.
  1. Nov 20, 2019 at 8:21 PM
    ratcityrain
    ratcityrain [OP] Well-Known Member
    Seattle, WA
    2017 Double Cab Off Road
    OEM Running boards |oemassive headlights | winjet tail lights | led lighting | hid headlight & fogs | oem tri-fold Bed cover | Custom dual JL Audio 10tw3-d4 sub box and custom amp rack | black off road wheels | painted oem grille | jbl door speakers |
    Hello. When it comes to wheels and tires I get lost trying to find a setup that works and fits.
    On my 3rd gen I installed 6112/5160 with ome medium duty leaf pack. In addition I have installed the JBA uca's.
    I need to replace my tires soon and I was planning to keep the stock off road wheels.
    My original plan was to go with a 285/75/16, but I fear I will have to cut and chop too much to avoid rubbing.
    I was thinking of going with 255/85/16, but according to JBA they won't fit and that I need to go with 31.7 or smaller tire. JBA recommends 265/75R16 ton factory wheels. If I want to keep stock wheels, can I run a spacer to make it work? If so, how do I determine what size spacer to go with?
    Otherwise, JBA recommends with a 255/85/16 that I go with a 16 x 8 wheel, -12mm offset. I have my eye on Ray 10's for that, but I found some Level 8 MK6 I like, but they only in a -10mm offset. Can I use a -10mm and still get away with it?
    Thanks for all the help
  2. Nov 20, 2019 at 8:56 PM
    Hooper89
    Hooper89 Well-Known Member
    2016 White TRD Sport
    there's a huge thread on here of people using 265/75r16 on the factory wheels. it's a popular size so you'll have tons of choices that aren't stupid expensive like other up sizes.
  3. Nov 20, 2019 at 9:12 PM
    Ccrames2018
    Ccrames2018 Jack of some trades.
    Caden
    Nor Cal
    07 AC 4x4 V6 6MT
    -Bilstein 5100s @1.75" -16x8 SCS Ray10s with 305/70R16 General Grabber AT -CMC -URD Short Throw Shifter -Bed stiffeners -Bed mat -Aftermarket head unit -AFE Rebel exhaust -ME-SO Customs dome/map lights -Window tint with eyebrow -OEM LED 2015 tail lights -GTR Lighting headlight bulbs -Husky floor liners -Camper shell -Sumo Springs -Air intake -Aftermarket Volkswagen key fob -Aftermarket A/C knobs -Aftermarket LED license plate lights -Console organizer -JBA High Caster UCAs
    I'm not sure why they wouldn't work, I have JBAs as well... Maybe the JBAs stick out farther than the stock arms. I'm on 305/70R16s with -12 offset Ray10s though.
    If you decide to go with spacers the only two brands I trust are Spidertrax and Bora. Don't skimp on wheel spacers unless you want your wheel coming off on the freeway haha. Also, I used red loctite to make sure mine stayed on when I had 1" Bora spacers.
    As far as the -10 offset, as long as you're still looking at a 16x8 wheel it will make no difference. That's only a 2mm difference between the two wheels, so get what you like! The best offset for our trucks though seems to be 0 offset, and probably what I'd go with if you aren't hard set on SCS wheels. Less rubbing = less trimming, and possibly not hitting the cab mount.
    Good luck with the search!
  4. Nov 21, 2019 at 8:32 AM
    Hooper89
    My 2cents; If you want an aftermarket wheel for looks then get the TRD 17" they will use your lug nuts and sensors plus they have a bit of offset so you can run upsized tires. For offroading stick with the stocks using a good 265/75r16 tire like a ko2. That way you can get an idea if you want larger tires more lift mud tires all of that stuff...
  5. Nov 21, 2019 at 8:45 AM
    MDFM31
    MDFM31 Well-Known Member
    Chester Co, PA
    16 DCSBOR
    FYI an 8" wide wheel will be outside the specs for a 255 tire, IIRC, but I'm sure lots of people do it. I have yet to find aftermarket 16x7 wheels for our trucks. I will be keeping my stockers regardless of which tire I ever have. On my 2006 sport, I went to 17x9s with 265/70's then to 17x8s countersteers (4.1bs, -10 offset) and had to trim the fender flares to clear the 31.7's. That's why I don't care for non-factory wheels anymore.
  6. Nov 24, 2019 at 1:30 PM
    loganfong7
    loganfong7 New Member
    2005 tacoma LT
    Im looking at the countersteers type x (17x8s -10 offset) how did they fit did they rub alot? Did you have any lift on your tacoma when you had them on?
  7. Nov 24, 2019 at 3:12 PM
    MDFM31
    Chester Co, PA
    16 DCSBOR
    I had 5100's at about 2.25" lift. I had to remove the front mudflaps and trim a lot of the fender flare out.
