help please cats cloged
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 2006tacoma, May 6, 2009.
  1. May 6, 2009 at 9:20 PM
    2006tacoma
    2006tacoma [OP] Member
    new mexico
    064x4
    front and rear bumpers rocksliders roll cage fabtec lift 35bfg
    i have an 06 tacoma with clogged cats and idk what to do about it toyota wants 3800 to fix it can i just cut them out and replace the 3 cats with 2 hiflow cats there is an o2 after one cat on the pass. side or will that throw the ecu off ???? any helpfull hints ? or should i just say screw it and buy a programible ecu and twin turbo it
  2. May 6, 2009 at 9:21 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Welcome to TW!
    How do you know the cats are clogged? Truck seems kinda new for that to be the issue.....
  3. May 6, 2009 at 9:25 PM
    brian
    brian Another Traitor
    Elizabeth City, NC
    2017 F-250 Powerstroke
    Can you say DT Long tubes? (assuming it would be the front cat.)
  4. May 6, 2009 at 9:32 PM
    Untamed_SS
    Untamed_SS Stayed Up Too Late
    Adam
    Haughton, Louisiana
    08 Speedway Blue Access Cab
    Alpine iDA-X200 Deck, Rockford P3, Infinity 1600 A Amp, Black Badges, "KnightRider Mod", Back-up lights. Painted Engine Cover. TRD QuickShifter & Shift Knob. MAF Calibrator. Doug Thorley LT Headers. Custom Y-Pipe. Flowmaster 50 series. Satoshi Grill
    Twin Turbo, duh :rolleyes:
  5. May 6, 2009 at 10:02 PM
    2006tacoma
    new mexico
    064x4
    I know they are clogged bacuase the dealership told me they were.
  6. May 6, 2009 at 10:04 PM
    TRD4x4858
    TRD4x4858 Taco Traitor!
    San Diego
    95 Jeep XJ
    BONE STOCK! lol
    Wow that should be covered underal federal emissions warranty, trucks only 3 years old??? hmmm sounds fishy
  7. May 6, 2009 at 10:06 PM
    2006tacoma
    new mexico
    064x4
    They said no warranty since i have a lift. They will not warranty my transfercase either.
  8. May 6, 2009 at 10:09 PM
    Burgman
    Burgman I KEEEEEL YOU
    Stephen
    Ric VA
    08 PreRunner TRD sport Silver
    K&N intake, Boston Acoustic SL 60 6.5 components up front, Rockford Power T16 6.5 in rear, Pioneer P4100 HU, Soon to be Pioneer Prs 4200f
    that makes no sense how would a lift have anything to do with exhaust or emissions
  9. May 6, 2009 at 10:12 PM
    TRD4x4858
    San Diego
    95 Jeep XJ
    BONE STOCK! lol
    I would take it to a different dealer, thats crap, cats should be covered
  10. May 6, 2009 at 10:12 PM
    2006tacoma
    new mexico
    064x4
  11. May 6, 2009 at 10:13 PM
    Burgman
    Stephen
    Ric VA
    if theres another dealer close take it to them b/c the dealer i bought my truck from suck
  12. May 6, 2009 at 10:14 PM
    TRD4x4858
    San Diego
    95 Jeep XJ
    BONE STOCK! lol
    Yes exactly its 8yr 80k miles
  13. May 6, 2009 at 10:14 PM
    bajamoon
    bajamoon Well-Known Member
    STEVE
    Whittier
    a lift would not void the warranty anyways, call the toyota 800 # and tell them what your dealer is telling you.
  14. May 6, 2009 at 10:19 PM
    2006tacoma
    new mexico
    064x4
    Thanks for the feedback guys im gonna call that 800# tomorrow and then take my truck in. Ill let you know how it turns out.
  15. May 7, 2009 at 6:38 AM
    dirthawker1313
    dirthawker1313 Well-Known Member
    the only way they can deny warranty work is if they can prove that your modification caused the problem. this was taken from another board im a member to....
    http://en.wikipedia.org/wiki/Magnuson-Moss_Warranty_Act
    The Magnuson Moss warranty act in short says that a warranty must be clearly written and understandable by an average person. Also any statements that are ambiguous are held agaisnt the drafter of the warranty, NOT the consumer.
    It states that the burdon of proof falls on the manufacturer to prove that something you did DIRECTLY effected the part or parts being warrantied for failure.
    This basically means that they CAN NOT void your entire warranty based on the replacement of any part. They can ONLY void it on parts that are directly affected by the part you replaced.
    A few examples
    If you change your exhaust, and you can show that the air fuel ratio was corrected and/or within a range that would NOT cause a failure the warranty on your motor cannot be voided unless stated so in the warranty. They obviously can void it on any part of the exhaust affected by the parts changed.
    If you change your brake lines, and your motor blows... they can not void the warranty on the motor. Even to the point of changing motor parts. they have to prove it CAUSED the failure. Example being you put an aftermarket slipper clutch in PROPERLY, and the pistons seize. Mechanically one cannot effect the other if installed properly, and thus the only voided part of your bike is the clutch... nothing more.
    KNOW YOUR RIGHTS, and cover your ass. Dont let anyone try to tell you your warranty is voided when you take it in to a dealer, and you know there is no way anything you did caused the failure.
    If they do, and refuse to work on it, escalate the problem to a higher office. It WILL get remedied.
    __________________
  16. May 7, 2009 at 6:55 AM
    luk8272
    luk8272 Poodoo
    Lucas
    Southern Louisiana
    07 Silver4dr. 4x4, V6 Shortbed
    5% Tint, Bug flector, vent Visors, Removed secondary air filter, Rear Spring TSB w/ Wheeler's Add A Leaf HD Pack, Icon 2.0 rear shocks, Toytec 3" lift up front with Total Chaos UCA's, Debadged, Billet Grille,TRD Offroad rims/17x9 Pro comp 6001 rims, Duratracs 265/75/16 or 285/70/17, Fog light anytime mod, Tailgate hose clamp mod, Pro-dry AFE filter. Extended Differential Breather, ABS on/off, 6000k LEDs from CSJumper, heads/fogs, ScanguageII, Devil horns, Devil horns on third brake light, Mounted 60" Highlift, Mounted Tool Box, Wet Okole Front/Rear Seat Covers, TW sticker, Midland Handheld CB,Painted engine cover, Revenge Fab Sliders, ARE Topper, Weather tech Floorliners, Camper shell, ultimate headlight upgrade. URD -3° exhaust cam gears, .5" XTP Intake spacer. Custom dents.
    I call the 800# everytime I get stupid shit from the dealer. Last few times I did it at one of their desk. In which case they know its me and I get much better service when they see me. My truck never goes to the back without me being there.
  17. May 7, 2009 at 10:26 AM
    jonny
    jonny Betty White Edition Heep ZJ
    thats sume fuk top stuff right there man
    how the F would a lift cause your cats to fail?
    i would find another dealership and see what they say. dunno if it was posted before, but how many miles are on the truck?
    what are the symptoms? i would imagine the truck wouldn't/ would run very shitty if ALL the cats were clogged?
    if all else fails, doug thorley long tubes/urd y pipe or cherry bomb, and a magnaflow catback can be had for less than 3800? lol but dont quote me i didnt actually look up all the prices :eek:
    >john
