Help Please. I cant See if these are Extended Travel or Regular travel.
Discussion in '1st Gen. Tacomas (1995-2004)' started by UnBuz, Mar 18, 2025.
  1. Mar 18, 2025 at 8:07 PM
    UnBuz
    UnBuz [OP] Member
    adrian
    Hello, I was wondering if you guys can help me and see if these are extended travel or not. I saw then on Facebook but i cant seem to find an answer myself and also the seller. Its the only picture he has on the listing so sorry for the bad picture. Also what exactly is the difference between the two(Regular and extended travel).
    Cheers
  2. Mar 19, 2025 at 1:42 PM
    TMFF
    TMFF Well-Known Member
    Tim
    Thornton, CO
    01/02 DCLB
    Stuff and junk and things...
    The only difference from ST to ET is an internal spacer.
    Those are in need of a service anyway so whoever is doing that for you can confirm what spacers are installed and convert to ET if needed.
  3. Mar 19, 2025 at 3:18 PM
    UnBuz
    UnBuz [OP] Member
    adrian
    AHHHH okay thank you so much.
