Help PLEASE: Running Board Removal
Discussion in '1st Gen. Tacomas (1995-2004)' started by blairrad, Nov 22, 2016.
  1. Nov 22, 2016 at 12:44 PM
    blairrad
    blairrad [OP] Yoter
    Missouri
    I've googled and searched this forum up and down and I cannot find any help for this.
    I cannot remove the running board, the bolts just spin. Why were these made so different from the 4runner? I don't want to cut them off because I can't sell them.
    How have you guys gotten yours off? Please help.
    (04 Tacoma TRD double cab 4x4)
  2. Nov 22, 2016 at 1:41 PM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    Where are they bolted to??
    Was it a welded nut that is now broke loose
    How good are you with a 4" grinder with a cutting disc ??
    You might be able to cut the heads off the bolts
    Tatts521 likes this.
  3. Nov 22, 2016 at 2:40 PM
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    which bolts? all of them?
    Either there's a nut on the other side you're missing (just put a wrench on it), or there's a welded nut that's broken off, or the threads are stripped. If you can't reach that welded nut, you're kind of hosed, so in either case you're going to need to do some cutting. If you're careful, you should be able to cut the bolts off without damaging the mounts or the running boards.
  4. Nov 22, 2016 at 2:47 PM
    Tatts521
    Tatts521 Well-Known Member
    New Jersey, Jersey Shore
    2012 tacoma-04cbr1000rr-22ktm890duke R-19 wr450f-98rm250
    Angle grinder for days bruh.
  5. Nov 22, 2016 at 2:49 PM
    Coot83
    Coot83 DORKEL NATION
    Scottsdale, Az
    2012 Baja TX
    TC 3.5 LT, RCV axles, Demello sliders, BD light bar/fogs, LP6, DMZ rear, SOS skids, custom bumper, King 16" triples, Locked-on hydro rear bumps...
    Are there any possible cavaties where a hidden nut for these bolts might reside? I think my older taco had fixed nuts for the bolts for my old running boards, but I could be mistaken.
    Coot
  6. Nov 22, 2016 at 3:34 PM
    blairrad
    blairrad [OP] Yoter
    Missouri
    The end of the bolt with the nut is inside the rocker panel.
    They're bolted strangely, and I don't own an angle grinder...I'll see if a friend has one.
  7. Nov 22, 2016 at 4:20 PM
    chaosrob
    chaosrob Well-Known Member
    If it's in the rocker will removing the interior panel give you access?
  8. Nov 23, 2016 at 8:10 PM
    blairrad
    blairrad [OP] Yoter
    Missouri
    Hell I'll try.
  9. Nov 23, 2016 at 11:28 PM
    BartMaster1234
    Tyler
    Pittsburgh, Pennsylvania
    Flux Capacitor
    I've had screws/bolts on different things get stripped (either because of too much torque, or the wrong size bolt) and I always removed it by applying downwards pressure. This has almost always been on a much smaller scale, but it might work with larghe bolts. Try somehow applying downwards pressure with a wrench or pliers.
  10. Nov 23, 2016 at 11:35 PM
    blairrad
    blairrad [OP] Yoter
    Missouri
    Thanks for the tip. I'm gonna give it another go in the morning.
  11. Nov 24, 2016 at 8:44 AM
    blairrad
    blairrad [OP] Yoter
    Missouri
    After lot of sweat, blood, and copious amounts of swear words, they're off.
    djgynee likes this.
  12. Nov 24, 2016 at 10:49 AM
    BartMaster1234
    Tyler
    Flux Capacitor
    What ended up being the issue? How'd you manage?
  13. Nov 24, 2016 at 11:09 AM
    blairrad
    blairrad [OP] Yoter
    Missouri
    Very stubborn bolts. For some reason, the other end of the bolt was inside the rocker. So, you'd loosen it but it'd just spin. I put a screw driver under the nut and gave it pressure, that helped.
  14. Nov 24, 2016 at 11:11 AM
    BartMaster1234
    Tyler
    Flux Capacitor
    Yup! I knew it would help.
    I work on a lot of computers/electronics and the number of times I've used the wrong sized screw in a hole is innumerable. The "pull up on the screw while un-screwing" method has always been a lifesaver.
    blairrad[QUOTED][OP] likes this.
  15. Nov 24, 2016 at 11:12 AM
    Blais03
    Blais03 Guess I'll bring a spare wheel bearing...
    Nick
    Easthampton MA
    '08 Reg. Cab 4WD + '06 Reg. Cab 2WD
    4 inch cut off wheel would be best for that I think
  16. Nov 24, 2016 at 11:14 AM
    BartMaster1234
    Tyler
    Flux Capacitor
    Nah man just bring out the acetylene torch. Have a fire extinguisher handy in case you blow your truck up.
  17. Nov 24, 2016 at 11:16 AM
    Blais03
    Nick
    Easthampton MA
    Well when you have a 18 year old truck that's fine and all :laser:
  18. Nov 24, 2016 at 11:18 AM
    awfilms
    awfilms Well-Known Member
    06 Tacoma TRD 4x4
    It's like 4 bolts. Can't be that hard to figure out. If you can't, Cut them off and tell your buyer to buy some bolts at the hardware store LOL.
    Good to hear you got them off.
  19. Nov 24, 2016 at 11:24 AM
    blairrad
    blairrad [OP] Yoter
    Missouri
    Oh I snapped a few bolts and chucked the rest out of victory as soon as I got them off.
    Finally! Tacoma looks better now
    djgynee likes this.
