Help please, shock tower nuts unremovable!!
Discussion in 'Suspension' started by bellero, Nov 18, 2012.
  1. Nov 18, 2012 at 1:09 PM
    bellero
    bellero [OP] Well-Known Member
    Wainwright, Alberta
    Tacoma 2003
    I installed the diff drop kit today and was hoping to install the Toytec Coilover as well but I can't remove the 3 small nuts on top of the shock tower!! I already partially stripped one, also tryed to heat them up with a torch but they won't come out! What to do?
    How bad is it to have the diff drop kit installed with a stock suspension?
  2. Nov 18, 2012 at 1:11 PM
    92LandCruiser
    92LandCruiser Well-Known Member
    Nevada
    80 series Land Cruiser
    Cummins, tons, 40s
    PB blaster, CRC freeze off.
    nut splitter?
  3. Nov 18, 2012 at 1:32 PM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    Angle grinder or dremel, either one will make short work of those nuts with a cut-off wheel.
  4. Nov 18, 2012 at 1:32 PM
    92LandCruiser
    Nevada
    Cummins, tons, 40s
    I'd be surprised if you could get at those nuts with either.
  5. Nov 18, 2012 at 1:35 PM
    Pugga
    Massachusetts
    You can get in there with a dremel, at least enough to score the nut so it'll break when you put a wrench or vise grips on them.
  6. Nov 18, 2012 at 2:11 PM
    bellero
    Wainwright, Alberta
    Tacoma 2003
    Thanks guys, just got some PB blaster and a nut splitter just in case.
  7. Nov 18, 2012 at 3:39 PM
    bellero
    Wainwright, Alberta
    Tacoma 2003
    Stupid question: Is it possible that these nuts be welded on top of the shock tower? I've tried everything and still can't remove them?
    It seems to me like there's a weld pass around the bottom of each nuts!
  8. Nov 18, 2012 at 3:43 PM
    Leggo
    Leggo slow is smooth, and smooth is fast.
    Newton,Ma.
    10 TRD Sport AC 4x4 MGM
    Kenwood HU,Infinity Kappa speakers (x4), Infinity reference tweeters(x2),10" Kicker sub, Box by Subthump, Infinty Five channel amp,DVD anytime bypass, DTRL Mod, Xtang trifecta, Fogs anytime Mod, Bed Mat,Westin running boards, Console vault, Maglite mod, Weathertechs,Autopage remote starter, Power tailgate lock, HID Bi Zenon, Hella Supertones,Rain guards,Rear leaf TSB,Steering shaft TSB, Fisher Homesteader plow, 886 reverse lights mod, Redline Hood struts, Hankook Dynapro ATM LT265/70R17, power sliding rear window, Auto dimming/on anytime Bed lights, Blue Sea fuse panel & 100amp Breaker, de- badged,Rear headrest's removed, imMrYo mirror relocation,Homeroshi grill
    no, just the base of the nut.
  9. Nov 18, 2012 at 3:44 PM
    ajohnson
    ajohnson Glamour Shot
    Andy
    Charlotte, NC
    07 DCLB TRD Sport Prerunner 4x4
    Things and stuff and such
    They aren't welded, they are flange nuts.
    Keep soaking them in PB blaster for atleast an entire day.
  10. Nov 18, 2012 at 3:46 PM
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    ...too much shit to list.
    Now that they are soaked with PB...box wrench and a hammer.
    Place box wrench on nut and hold and whack the shit out of it with your favorite ford tool.
  11. Nov 18, 2012 at 3:47 PM
    bellero
    Wainwright, Alberta
    Tacoma 2003
    Thanks, so basically what I'm thinking is a weld is in fact only the nut's flange?
  12. Nov 18, 2012 at 3:48 PM
    Leggo
    Newton,Ma.
    I slam an impact socket on there with a hammer that fits really tight and put an impact gun on it from there. After if it don't work, I cut them off entirely with a cutoff wheel of some kind and then replace the top plate with new.
  13. Nov 18, 2012 at 3:49 PM
    Pugga
    Massachusetts
    Correct
  14. Nov 18, 2012 at 3:49 PM
    bellero
    Wainwright, Alberta
    Tacoma 2003
    You beat me to it, that's what I just realized, flange nuts! I'm flabbergasted by my dumbness!!
  15. Nov 18, 2012 at 3:49 PM
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    Please do tell how you fit an impact in the wheel well above the coil bucket?
    Did you cut a hole in the core support and go through the engine bay?
  16. Nov 18, 2012 at 3:50 PM
    xJuice
    xJuice My spoon is too Big!
    Josh
    N. Texas
    19 Tundra MGM
    TRD Front & Rear Sway Bar, TRD Pro LED Headlights, Undercover SE, Rear diff. Relocate, console organizer, debadged, color matched handles, mirror caps, and grill
    maybe an impact ratchet instead of a gun...
  17. Nov 18, 2012 at 3:51 PM
    Krazie Sj
    Krazie Sj Resident Jackass
    Power Serge
    LV-426 (Acheron)
    07 TRD Off Road 4x4
    Borla Catback Exhaust, Snorkel, 33s on either 16's or 18's, ARB Bumper, All Pro LT w/Walker Evan Shocks front and back, All Pro expedition leaf pack, 10,000lb Superwinch, Intake Manifold Spacer, Bed Rack with ARB RTT, Rotopack and Hi Lift mounted, Husky Liner mats and an air freshener from 1995.
    Been there man. You got my sympathies. A nut splitter at the very least will open it up enough that a wrench can take it off finally. However have your spares ready to go before you have at them.
  18. Nov 18, 2012 at 3:55 PM
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    Doubtful. I dunno what air ratchet he may have, but my air ratchet only puts out 70 ft-lbs max torque.
  19. Nov 18, 2012 at 3:58 PM
    Leggo
    Newton,Ma.
    Yah, I never did this to this truck before. Cars in the past I have done have easy access to the nuts from under the hood. I guess if you cannot get straight down on them, I cut them thru with a sawsall or something. I also own a nice pair of curved jaw channel lock pliers that would make short work of these nuts. Snap-On sells some good stuff.
  20. Nov 18, 2012 at 4:02 PM
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    :rolleyes:
    There's 3.5" of space between the coil bucket and the core support and almost no rotational area due to the fact the coil bucket tapers upwards. Channel locks aren't gonna do squat here.
