Help please, shock tower nuts unremovable!!
Discussion in 'Suspension' started by bellero, Nov 18, 2012.
  1. Nov 18, 2012 at 4:05 PM
    Leggo
    Leggo slow is smooth, and smooth is fast.
    Newton,Ma.
    10 TRD Sport AC 4x4 MGM
    Kenwood HU,Infinity Kappa speakers (x4), Infinity reference tweeters(x2),10" Kicker sub, Box by Subthump, Infinty Five channel amp,DVD anytime bypass, DTRL Mod, Xtang trifecta, Fogs anytime Mod, Bed Mat,Westin running boards, Console vault, Maglite mod, Weathertechs,Autopage remote starter, Power tailgate lock, HID Bi Zenon, Hella Supertones,Rain guards,Rear leaf TSB,Steering shaft TSB, Fisher Homesteader plow, 886 reverse lights mod, Redline Hood struts, Hankook Dynapro ATM LT265/70R17, power sliding rear window, Auto dimming/on anytime Bed lights, Blue Sea fuse panel & 100amp Breaker, de- badged,Rear headrest's removed, imMrYo mirror relocation,Homeroshi grill
    Blue wrench or Sawzall then.
  2. Nov 18, 2012 at 11:30 PM
    92LandCruiser
    92LandCruiser Well-Known Member
    Nevada
    80 series Land Cruiser
    Cummins, tons, 40s
    Seriously try the crc freeze off. I haven't gotten to really use it yet. It smells cool though. I would do that and then try the Jberry hammer/wrench method.
  3. Nov 25, 2012 at 10:22 AM
    bellero
    bellero [OP] Well-Known Member
    Wainwright, Alberta
    Tacoma 2003
    I finally removed the top three bolts ON ONE SIDE!! I had to cut them with the dremel and I had to cut thru the top plate a bit to remove the flange.
    Guess what now, the lower shock bolt won't come out!! I removed the nut and washer and it won't bulge. I banged so hard on it that the two tabs holding the shock to the lower arm are starting to bend!!
    I'm very close to abandon the friggin project!!
  4. Nov 25, 2012 at 10:28 AM
    anthony250f
    anthony250f Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    Damn...does your truck live in salt water...?
  5. Nov 25, 2012 at 10:29 AM
    bellero
    Wainwright, Alberta
    Tacoma 2003
    No Worse, it's called Canada!
  6. Nov 25, 2012 at 1:27 PM
    Leggo
    Newton,Ma.
    Blue wrench FTW
  7. Feb 19, 2014 at 9:18 AM
    NerdAlert
    NerdAlert Well-Known Member
    ‘17 TRD Sport DCSB 6MT
    I'm reviving this thread because I took this advice to use a nut splitter on my stipped and seized top nut.
    DO NOT use a nut splitter on the top nut. The nut is made of aluminum (softish metal) and therefore is not brittle, so instead of cracking in half, the nut splitter imply compresses the nut further towards the threads. It won't split, it will actually get tighter.
    Took me a couple hours trying many different things to get the nut off afterwards. Eventually what worked was a drill, which was removing material from the nut.
