(Help Please) Taco Lean?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by D_Tran11, Jun 7, 2017.
  1. Jun 8, 2017 at 10:45 AM
    MattCowsmasher
    MattCowsmasher ( -_・)ᡕᠵ᠊ᡃ່࡚ࠢ࠘⸝່ࠡࠣ᠊߯᠆ࠣ࠘ᡁࠣ࠘᠊᠊ࠢ࠘
    Temple, Tx
    O3 Rubicon wrangler
    Take a big girl on a date an have her ride in the back.
    300AACTaco likes this.
  2. Jun 8, 2017 at 10:49 AM
    300AACTaco
    300AACTaco Well-Known Member
    Alaska
    Black '15 DCSB TRD Off Road 4x4
    ARB Old Man Emu 90000s and 60091s OME 886s, Trim Packer, Icon Tubular Uniball UCAs, CMC, Invisible Sway Bar, Dakar Rear Leaf Packs, Timbren Rear Bumpstops, All Pro U-bolt flip up kit, Method Race Wheels NV 16X8 4.5BS, Cooper ST Maxx LT285/75/16, DEPO Black Tail Lights, Weathertech Floormats, Cascadia Vehicle Tents Mt. Shasta in Earth Tone Green, Custom Green Tree Fabrication Bed Rack, N-Fab Spare Tire Bed Mount
    When Toyota built these things did they just measure using their hands? Guesstimate lol
  3. Jun 8, 2017 at 10:49 AM
    300AACTaco
    Alaska
    There you go, they need love too
  4. Jun 8, 2017 at 10:57 AM
    Muddinfun
    Muddinfun Well-Known Member
    Do your own frame measurements. Park the truck on perfectly flat concrete. Start with a tape measure and a clipboard. Start at 1 end of the truck and take height measurements from the frame to the ground on each side. Write down your measurements in a left column and a right column. Work your way to the other end. When you're done, compare your results. If at some point in the list, the L vs. R difference changes, the frame is twisted. Another area to look is the gap between the cab and the bed. It should be the same top to bottom and the same L vs. R. Also when you look down the side, the bed should match up with the cab the same on both sides.
    Doogz likes this.
