Help please: Thinking Twice About My OTT Tune
Discussion in '3rd Gen. Tacomas (2016-2023)' started by traylor1, May 14, 2025.
  1. May 14, 2025 at 8:58 AM
    traylor1
    traylor1 [OP] Member
    Hey folks,
    Looking for some input from anyone who's run the OTT tune on their Tacoma.
    I've got a 2021 Tacoma and had my local tuner install the middle-level OTT tune a couple months ago. At first, it felt awesome — shifts were smoother, RPMs weren’t flaring up like they used to, and overall it just drove better.
    But after about a week or two, things started to change.
    • Acceleration just didn’t feel right. The truck began hesitating when taking off from a stop
    • Shifting from 1st to 2nd became rough
    I took it back to the shop last weekend and they decided to remove the tune, thinking maybe it was something that Toyota should look at under the drivetrain warranty. But, after they removed the tune, the truck drove better than it did even before the tune. Acceleration was smooth once again, and it just felt “right” for the first time. Even my wife — who’s been complaining about how the truck shifts since the day I bought it — said it finally feels normal.
    That said, I’m still noticing that the shift points seem a little high. It's not bad, but it's there.
    The shop offered to try a lower-level tune this week to see if it behaves better, but now I’m second-guessing everything. I already paid $500 for the original tune, and part of me is wondering if I should even mess with it anymore. It's driving better than it ever has right now, even though it isn't perfect.
    So my questions:
    • Anyone else have this kind of experience with the OTT tune?
    • Will going down a level help smooth things out?
    • Or should I just leave it stock now that it’s finally behaving?
    I appreciate any feedback!
    Tcoma16 likes this.
  2. May 14, 2025 at 9:03 AM
    stav
    stav Active Member
    Mikey
    Illinois
    22' Toyota Tacoma Limited Nightshade
    OEM TRD Lift Kit, Grille, Intake Exhaust, Shift Knob
    If the dealer sees that the ECU has been flashed because of tune install, you can kiss that powertrain warranty goodbye
    whoareyou133 likes this.
  3. May 14, 2025 at 9:20 AM
    PhoS
    PhoS Proffauxssional
    PNW
    08 FJ Cruiser
    Contains MSG
    What fuel are you using?
    whoareyou133 and Rednecktacoma22 like this.
  4. May 14, 2025 at 9:27 AM
    Koolbreeze7
    Koolbreeze7 GRILL MAN
    Jon
    Jersey
    2017 TRD Sport 4x4 DCLB Black, Trail Limo. RIP- 2009, 2000, 91,89,87 trucks
    Rigid pod fogs, SpartanX stealth grill and hood LED's, 17" SEMA's on 275/70/17 Falken Wildpeak AT3W's, Fox 2.0 on all corners , TRD CAI, LEER 100XQ Blacked out, w/ Thule racks, and Cargo slider Flow master American Thunder "dual" exhaust, remote start, tint, TRD Pro grill and TRD shadow graphics, Alcan custom 8 leaf Spring Pack
  5. May 14, 2025 at 9:30 AM
    musicisevil
    musicisevil Lesser-Known Jack Wagon
    Alaska
    2019 TRD Sport
    There haven’t been any instances of this happening shared here. The only issue was failing emissions tests prior to OTT getting certified or whatever.
    This doesn’t mean what you are saying isn’t true, just that no one has experienced this and shared it on the forum.
  6. May 14, 2025 at 9:35 AM
    OldSchlPunk
    OldSchlPunk A legend in my own mind!
    Rich
    East Central Wisco
    '17 OffRoad Silver Sky Metallic
    Small lift, slightly oversized tires, well...
    My guess is the changes you're seeing is the trans re-learning after the flash. It's possible the first flash didn't 'take'. I've read a few cases where a vehicle had to be re-flashed.
  7. May 14, 2025 at 9:35 AM
    Vlady
    Vlady Well-Known Member
    Issy, WA
    2017 White SR5 DCSB V6 4x4
    A couple of things.
    Dealer does not hook a scanner willy-nilly without securing a payment from you. You need to sign on the line and agree to pay diag fees to get a scanner connected.
    Secondly, there is no a "flash" counter. There is Distance since last battery disconnect value that gets reset after a flash and a battery cable disconnect. If things get escalated, you tell them the story of replacing a bulb.
    There are calibration ID and Calibration verification number. Most tunes retain Calibration number, but verification number is changing.
    If you go back to OEM Calibration, Verification number reverts back to OEM.
    Even if Toyota plugs the scanner, they need to go to a different section of the diag app to dig the information on Verification number. Most Toyota techs don't go to that section of the app.
  8. May 14, 2025 at 9:58 AM
    STEELeR43
    STEELeR43 Well-Known Member
    Hawaii
    2023 Tacoma TRD 4x4 6MT
    3" Icon Lift, SPC UCA, B&M Sport Shifter, OTT Tune
    You shifting from 1st to 2nd became rough, what is rough? Also, you have manual transmission? I have manual 3rd gen no problem with OTT.
    tcaustin and Rednecktacoma22 like this.
  9. May 14, 2025 at 10:35 AM
    Mas Olas
    Mas Olas Well-Known Member
    Woody
    10 miles north or 400 miles south of the border.
    2020 Blacked-Out White DCLB TRD OffRoad 4x4
    Have them put you on the minimum agro pedal response. Love my tune!
  10. May 14, 2025 at 10:54 AM
    Rednecktacoma22
    Rednecktacoma22 Well-Known Member
    Logan, UT
    22 TRD OR 6MT
    3rd gen MT with an OTT tune chiming in as well. While OP didn't directly come out and say it was an AT, this alludes to it being an AT and not an MT; "That said, I’m still noticing that the shift points seem a little high."
    I am fortunate enough to have been tuned by the famous Justin himself, and he recommended the Mild tune to me after some discussion. I loved it so much I wanted it more but have come to love the Mild setting on the manual.
  11. May 14, 2025 at 2:42 PM
    traylor1
    Yes it is an AT. I am considering the mild. I will know more this Saturday when I go back.
  12. May 14, 2025 at 2:52 PM
    na8rboy
    na8rboy 18 DCLB Sport Cement
    WI
    18 DCLB SPORT CEMENT
    The mild/medium was sweet spot for me in OTT. Remember it will still learn your driving habits, with or without tune.
  13. May 14, 2025 at 2:59 PM
    2021SR5V64WD
    2021SR5V64WD Well-Known Member
    2021 SR5 V6 4WD ACCESS CAB
    I kinda trust Toyota Engineers with multiple advanced degrees to know better than
    I ever will how their product should behave.
    t0p_d0g likes this.
  14. May 14, 2025 at 3:04 PM
    Gen3TacomaOBX
    Gen3TacomaOBX Well-Known Member
    S
    2018 Tacoma DCSB SR 4x4
    Bilstein 6112 front / 5100 rear (extended) shocks, Headstrong AAL, Firestone airbags, 4.88 gears, OME Carrier bearing drop kit, Aluminum 1/4" skids (engine to transfer). Custom sliders (1.75" HREW tube w/ 3/16" base plates). Custom front bumper and high clearance rear bumper (1/4" steel plate, 1.75" tube.) Apex 5500 winch w/synthetic line (36lbs) and required accessories for an underpowered winch (snatch blocks and extra line.) Tekonsha P3 brake controller, remote start, any-time-backup camera w/ front facing camera, Leer 100R shell (w/e-track single slot tie-down mounts for removable Yakima EasyTop.) Cat shields by CaliRaised. Husky liners, window tint, heated seat (passenger only.) Relentless bed rail brackets with QuickFists (shovel/axe/fire extinguisher.) Hondo Garage Un-holey vent mount. Anytime rear with front facing camera. Billet front seat risers. Viair 88p. 265/75r16 Goodyear Ultra-terrain tires.
    OP, you said it's driving better.. then my recommendation is just leave it alone.
    I paid ~$700 for an OVTune many years ago and quickly went back to stock just months later due to jumpy acceleration.
  15. May 14, 2025 at 3:53 PM
    t0p_d0g
    t0p_d0g 私はタコマが大好きです
    2023 TRD SPORT 4X4 DCSB CSM, 2004 TRD OR DCSB IRP
    OP, leave well enough alone….
    kahanabob likes this.
  16. May 14, 2025 at 4:03 PM
    chstaco
    chstaco Well-Known Member
    SC
    2020 Tacoma
    After applying the factory tsb flashes for trans tuning on my AT 2020, I always thought my truck shifts fine.
    I think there's too much credit given on the aftermarket tunes via the owners butt-o-meter. I wonder how many people would have been happy just having the factory flashes updated.
    t0p_d0g likes this.
  17. May 14, 2025 at 4:14 PM
    Canadian Caber
    Canadian Caber R.I.P Layne Staley 67-2002
    Les
    B.C. Canada, eh
    2020 TRD Sport DCLB 4X4 Super White
    OP, re-flashing may solve your issue. Love the OTT tune. It’s not perfect but a huge improvement over stock. Been running it for almost one year. No issues.
    musicisevil and mootiger49 like this.
  18. May 14, 2025 at 4:30 PM
    PhoS
    PNW
    08 FJ Cruiser
    Contains MSG
  19. May 14, 2025 at 4:37 PM
    TacoTime55
    TacoTime55 TT59
    Ed
    Delaware
    2021 Midnight Black TRD Sport AT/DCSB
    TRD Lift,OTT Tune, LED HLs,TRDSkid, TalonCAT
    I've got some questions...
    Are you the original owner of said 2021?
    How many current miles are on your truck?
    Reason I ask, the ECU/ECM recognizes the driving habits from the moment it leaves the dealership with less than 10 miles. (Something I read/learned since being on TW/Sep2021)
    These factors I believe effect the way the OTT Tune reacts to driver input.
    Of course, this is theory but I drove my truck like a grandma the first year of ownership and had OTT installed in May 2022.
    I eventually had one more update after the first...then my third update is the current and most satisfying tune:
    Mild Drive/Spicy ECT
    I've had no issues as you describe...but I did have a hot throttle/pedal with my initial tune.
    I dialed it down a notch and liked the Mild tune...and have stayed with it since.
    STEELeR43 and Rednecktacoma22 like this.
  20. May 14, 2025 at 4:43 PM
    Rednecktacoma22
    Logan, UT
    22 TRD OR 6MT
    Well... if it was "just" the engineers involved in bringing a car to market... maybe. EPA restrictions requiring adherance have taken an already mild drive train and put it in the doghouse.
    That being said, my OTT tune on my truck didn't seem to perform as smoothly on 85 & 87 octane (elevation octanes for 87 and 89) gas. No hiccups on 91 (93) since I switched.
    MagicToolbox and 44-16 Taco like this.
