help please!!! tire light came on
Discussion in 'New Members' started by Asdfghjkl123, Dec 8, 2016.
  1. Dec 8, 2016 at 5:19 PM
    Asdfghjkl123
    Asdfghjkl123 [OP] 2010tacomadoublecabv6
    california
    2010 Tacoma double cab v6 sr5
    Oem
    so i have a 2010 tacoma double cab base v6 with 245 tires. i went to the gas station to add some air and i put 35 on all but the recommended is 29 and 32 in front and back. Did i put too much air because i couldnt remember how much air my mechanic used to put or is it my spare tire? the light is still on. do i need to reset it because i remember when the light came on, i added air and it went away
    scottalot likes this.
  2. Dec 8, 2016 at 5:23 PM
    At The Helm
    At The Helm ATH Fab Vendor
    Morgan
    Gardnerville, NV
    2015 AC 4x4 TRD OR & 2019 T4R
    Kings, TC UCAS, SCS SR8's, ATH bumpers
    There should be a tpms reset button under the steering wheel.
  3. Dec 8, 2016 at 5:23 PM
    Asdfghjkl123
    california
    Oem
    @scottalot damn i think i used put 32 all around... i feel 35 was too much
  4. Dec 8, 2016 at 5:25 PM
    GHOST SHIP
    GHOST SHIP hates you.
    GHOST
    You might try resetting before panicking. Not sure which years Toyota added the TPMS sensor to the spare, but it wouldn't be too hard for you to drop it and check for the hell of it. Normally they reset periodically so the light might not go away instantly, but perhaps after a 10 min drive or so. I'm on a 5 tire rotation and sometimes don't carry the spare with me (so i'll have only 3 sensors with the truck). After leaving my driveway, sometimes it'll take 20-30 minutes before the light turns on (the truck realizes one of the sensors is missing).
  5. Dec 8, 2016 at 5:28 PM
    Skrain
    Skrain Time is an illusion. Lunchtime doubly so.
    Monticello, Ky
    2009 F.J. Cruiser
    Westin 9 LED Driving Lights.
    I know my 06 has a TPMS on the spare...
  6. Dec 8, 2016 at 5:28 PM
    GHOST SHIP
    GHOST
    Also from 32-35, the sensors are still within their acceptable range of operation so resetting should turn the light off if everything is working as it should... I'd say after ruling out the spare TPMS as the culprit, resetting the sensors and making sure you have no leaks (wait overnight and check pressure again), then we can faithfully assume you have a bad sensor.
  7. Dec 8, 2016 at 5:30 PM
    GHOST SHIP
    GHOST
    I've had a 14 and 15 and neither had TPMS on the spare, but I know for the '12-15 facelift trucks they took a bunch of stuff away from us that was standard before.
  8. Dec 8, 2016 at 5:33 PM
    Asdfghjkl123
    california
    Oem
    thanks for the response guys appreciate it. and @scottalot i know 3 lbs isnt alot but i think it maybe the reason the light is still other than that probably the spare. Should i just reset the light or try putting some air in the spare tomorrow? what you guys think?
  9. Dec 8, 2016 at 5:36 PM
    Asdfghjkl123
    california
    Oem
    also guys sorry for all the questions when the tpms light comes one do you always need to reset the light or should it just go away after you put the recommended amount or whatever?
  10. Dec 8, 2016 at 5:38 PM
    Asdfghjkl123
    california
    Oem
    @scottalot i would say maybe less than or close to a mile
  11. Dec 8, 2016 at 5:42 PM
    Tacoma 14
    Tacoma 14 dclb brm lb
    Va
    2014 tacoma
    If its not your spare tire being low you have lost a battery in one of the tires more than likely.
  12. Dec 8, 2016 at 5:43 PM
    Asdfghjkl123
    california
    Oem
    @scottalot thanks ill give it a go tomorrow and see whats up. Next time i will just do 32 all around when i put air. i feel like recommend air pressure on the side of the door is too low, feels pretty bumpy when driving. but thanks
  13. Dec 8, 2016 at 5:46 PM
    Asdfghjkl123
    california
    Oem
    i have a feeling it maybe the spare tire havent put air in there for quiet awhile and i park my car outside and here in cali its been getting pretty cold and raining if that hasnt anything to do with my tires losing air or whatever.
  14. Dec 8, 2016 at 5:49 PM
    Asdfghjkl123
    california
    Oem
    @scottalot jealous you have a 2015 offroad 4x4 doublecab.... I should have waited i bought my 2010 sr5 double cab over priced sad face....
  15. Dec 8, 2016 at 5:52 PM
    Asdfghjkl123
    california
    Oem
  16. Dec 9, 2016 at 5:28 PM
    TacoJuan
    TacoJuan Well-Known Member
    Hanover, PA
    2015 Black Tacoma TRD OR
    I disabled my tpms light and never have to worry about that annoying thing again. Recently got new wheels and tires, had them put regular valve stems on there, saved a bunch of money too. Those tpms sensors are a crock, there's more problems there than just your sensors if you can't tell that your tire is flat
