help please. turn signals and climate controls don't work
Discussion in 'Technical Chat' started by CraigTRD, Jul 21, 2013.
  1. Jul 21, 2013 at 7:24 AM
    CraigTRD
    CraigTRD [OP] It's been a while
    Craig
    London, Ontario, Canada
    2023 Tacoma TRD Pro 6M
    Will have: 6" FabTech Lift, Custom rear leaf packs. Hockey Stick Canadian Flag Mod.
    I was backing up a trailer (turning around in a laneway) when the cable pulled out of the trailer connector. The air bag light is now on, the turn signals don't work and the climate controls don't work either. I have checked all of the fuses under the lower left dash and under the hood. everything seems fine....
    Anyone have any suggestions? 06 4x4 trd double cab.
    Thanks!
  2. Jul 21, 2013 at 8:04 AM
    CraigTRD
    Craig
    IG1 fuse in the lower left dash fuse panel.
    10A. replaced it and it's all good again.
    it was the only fuse I didnt check the first time going through.
  3. Jul 21, 2013 at 8:09 AM
    NelsonTacoma
    NelsonTacoma This is my derpawayinator!!!!!
    Tucson, AZ
    06 PreRunner TRD Sport 03 4Runner Limited 4wd
    Bilstein 5100's , 6000k HID Hi/Low Kit, Magnaflow Muffler, 1.5 inch AP Wheel Spacers, Mudflap Delete
    That happens alot when hooking up a trailer. I would inspect the wiring to the connector on your hitch just to be safe. Glad you found it!:):)
