help please
Discussion in '1st Gen. Tacomas (1995-2004)' started by jesus, Jul 14, 2011.
  1. Jul 14, 2011 at 11:42 PM
    jesus
    jesus [OP] Well-Known Member
    jesus
    bakersfield
    K&N ram intake & doug exs.
    ok here the deal I have a code p0171
    and I'v e rear a bunsh of thread on here but my question is this I just had a new cat magnaflow bolt on and here the part I need your input on should it look like this......
    should the washer be in the betewen the way it was put in... I dont recall the oem being like that...
  2. Jul 14, 2011 at 11:50 PM
    TnRedNeck721
    TnRedNeck721 GO VOLS!
    Zach
    TN
    07 TRD off road 4WD
    bump. hope someone comes along that knows. i don’t.
  3. Jul 14, 2011 at 11:56 PM
    jesus
    jesus
    bakersfield
    that bro...
  4. Jul 14, 2011 at 11:58 PM
    Gincoma
    Gincoma Special Edition Member
    Salt Lake City UT
    RIPieces 2005 Tacoma, adios 2011 :'(
    Factory Monster Truck Package with reverse gear.
    Where are the load springs that go on?
  5. Jul 15, 2011 at 12:08 AM
    TnRedNeck721
    Zach
    TN
    07 TRD off road 4WD
    NP man. anything to help a fellow TW brother out.
  6. Jul 15, 2011 at 12:08 AM
    jesus
    jesus
    bakersfield
    say what????:confused::confused::confused::confused::confused::confused:
    what springs???? do you mean the hangers or am I really lookiny for a spring??
  7. Jul 15, 2011 at 12:12 AM
    4WD
    4WD cRaZy oLdmAn
    Doug
    Lakeside, Ca / Gardnerville, Nevada
    2004 DC TRD 4x
    Grey wire MOD, deck plate, diff breather MOD, 2nd gen. OME 883# on Tundra 5100's, OMD custom 3" leafsprings, rear shock relocation, Ivan Stewart TRD rims w/285/75/16's, '02 bumper MOD, Famous Fabrications sliders , LED interior/exterior lights, bed bar, Custom tube bumper, Old school KC day lighters,Red Ring 8" HID flood, Kenwood vhf 2M.. umm some other shit I'm forgetting right now
    No way should that washer be there, it belongs next to the head of the bolt or the nut on the other end, (likely) but not between the flanged ends, thats the part your trying to seal...
  8. Jul 15, 2011 at 12:16 AM
    jesus
    jesus
    bakersfield
    that what I thought and I think that maybe setting the code I'm taking it to a shop to check it out cuz if I recall right the oem had the gap...
  9. Jul 15, 2011 at 7:15 AM
    jesus
    jesus
    bakersfield
    Bump still need input
  10. Jul 15, 2011 at 7:41 AM
    fingers1126
    fingers1126 Well-Known Member
    Fall River, Ma
    2010 Tacoma AC 4x4 4.0
    they put the washer in between the flange to help stop from bending too much when tighting. unlike the oem cat cast material after market are cheap soft steel bend easy.... you have too watch out some high flow cats will throw engine light on ....... improper backflow. but the washer are in fact good to have there....
  11. Jul 15, 2011 at 7:54 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    There shouldnt be any washers there. The nuts get torqued to 35 ft.-lbs.. They may have re used the gasket too, which would cause a leak.
  12. Jul 15, 2011 at 7:55 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    To add.....that code is mostly indicative of a dirty MAF.....
  13. Jul 15, 2011 at 7:58 AM
    rcbs204
    rcbs204 Well-Known Member Vendor
    indicative, what a great word, that should be the word of the day!! :D
  14. Jul 15, 2011 at 8:16 AM
    jesus
    jesus
    bakersfield
    Really I can't see how the gap would help
  15. Jul 15, 2011 at 8:18 AM
    jesus
    jesus
    bakersfield
    Thanks chris I really couldn't believe it would help I'll take them out Nd see what happens and clean the mag and to be sure thats the sensor on the intake right after the air filter ....right
  16. Jul 15, 2011 at 8:25 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Yeah...Use electronic contact cleaner.
  17. Jul 15, 2011 at 3:14 PM
    jesus
    jesus
    bakersfield
    K all clean ... I did the maf , the tube on the k&n intake and clean the flapped both sides of the throald (sorry for the missed spelling )..... Replaced the fuel filter removed washes and placed them on the outside ...but didn't do much for spacing no hising so must not be leaking ...... Now what??????? Oh yea going to run it for a bit then I'll post update
