Help....popping sound while braking
Discussion in '2nd Gen. Tacomas (2005-2015)' started by USAFmotorhead, Apr 7, 2012.
  1. Apr 7, 2012 at 7:22 AM
    USAFmotorhead
    USAFmotorhead [OP] New Member
    Justin
    Belleville, IL
    09 Sport 4X4
    Leveling kit
    Reciently noticed a popping, or clanking noise when I first apply my brakes, sounds like somehting may be loose with the brake line....Any suggestions or anyone have similar problems? My Taco has 35,000 miles on it. Also anyone have the ticking noise coming from under the glove box when you turn on the heat/air? I've had it for awhile and im fed up with it.
  2. Apr 7, 2012 at 9:33 AM
    charles08tacoma
    charles08tacoma Well-Known Member
    Santa Cruz, CA
    08 Prerunner SR-5 Access Cab
    White Snug Top shell
    Brake noise common. Most likely front brake pads rattling around in the caliper. Mine does it first time I apply the brakes going forward & backward. Seems to be a common nuisance.
  3. Apr 7, 2012 at 10:56 AM
    BTO
    BTO Well-Known Member
    California
    '07 Silver PR DC AT SR5 TP LSD
    Bilstein 5100s front, Adjustable Ranchos rear.
    +1 Exactly.
  4. Apr 7, 2012 at 12:26 PM
    dYL0n
    dYL0n أنا لست الإسلامي
    Dyl0n
    New Orleans, LA
    17TRDORDCSBQSJBLKBRO2SPECU1.04
    1.04. Kbro2s. ICONS.
    Read the manual. It means you need new brake pads.
  5. Apr 7, 2012 at 12:31 PM
    fixer5000
    fixer5000 the logical one
    massachusetts
    2018 4runner limited in nautical blue
    theres a tsb for your fan motor ticking. you have 1000 miles left to get it taken care of...dont wait too long
