Help - Power Windows Stopped Working
Discussion in '1st Gen. Tacomas (1995-2004)' started by WolfeTaco, Nov 14, 2009.
  1. Nov 14, 2009 at 12:40 PM
    WolfeTaco
    WolfeTaco [OP] Baja Time
    Ojai, CA
    02' PreRunner TRD - Silver
    AFE Cold Air Intake, DTLT Ceramic Headers, Jardine Cat-Back, TRD S/C, URD fuel system upgrades (injectors & pump), URD pulley... soon to be tuned!
    Hey everybody! So, yesterday everything was working fine.... today I'm parking my truck and cracking the windows to vent (because its still warm here) and... for some reason ONLY my drivers side power window will work when I push the button. The other 3 (4dr) will not move if i try to do it from the drivers control panel OR from their own.
    I looked at the fuse boxes under the dash and under the hood but don't see anything for the pwr windows specifically.... and all the other accessories are working just fine so i don't think it is the accessories fuse. This is a 2002 PreRunner 4dr
    Anyone else ever have this problem? Point me in the right direction? Thanks!
  2. Nov 14, 2009 at 12:44 PM
    beastlytaco
    beastlytaco Well-Known Member
    Ian
    08 Access Cab SR5
    fuse, motor, wheel bearing in the mechanism...could be several different issues there.
  3. Nov 14, 2009 at 12:45 PM
    tacoterra
    tacoterra Batang SMB
    South NJ
    11 T4runner TE
    check if you have the power window lock/unlock button.You might have activated it w/o noticing.
  4. Nov 14, 2009 at 2:44 PM
    WolfeTaco
    Ojai, CA
    OK problem solved! Thanks
    The window lock button was the first thing I checked... apparently something got lodged underneath and caused it to stay stuck down even when I pushed the button to see if that was the issue.
    Thanks again for your help!
  5. Nov 14, 2009 at 3:07 PM
    tacoterra
    South NJ
    11 T4runner TE
    Glad to help.:thumbsup:
