Help!! Problem with my Xenon HIDs
Discussion in 'Lighting' started by jlvhrse, Jul 14, 2010.
  1. Jul 14, 2010 at 11:11 AM
    jlvhrse
    jlvhrse [OP] Well-Known Member
    Jen
    SoCal SGV
    2009 TRD Sport 4X4 Long Bed
    LSK front and rear LT and stuff
    Sooo I just traded my old stock wheels for Xenon digital balast HIDs (headlights and fog lights) from a local tacoma owner (not on TW)...
    So here is the issue. When driving home last night my driver side headlight did not come on! The two fogs and passanger side lights were working fine.. So just taking a shot in the dark I turned my headlights completely off and then back on.. When I did that it came on.. Any ideas on why it didnt come on the first time?
    I hope I don't have to replace it already, I have only had them for a week but I got them used.
    Thank you TW!
  2. Jul 14, 2010 at 11:14 AM
    CopDoctor
    CopDoctor Well-Known Member
    Colorado Springs, CO
    08 335i
    BMS Intake, JB4 chip, Plastidip everywhere
    bad ballast or weak wiring. did you get a wire harness with it? to test swap the ballasts and see if the other side does the same thing.
  3. Jul 14, 2010 at 11:16 AM
    jlvhrse
    Jen
    SoCal SGV
    That's a good suggestion but whats the ballast? Is that the metal box that came with it? LOL I have not really messed with them because he put them in for me and I have NO experience with things like this. Also, I have had them for about a week or two and this is my first time experiencing this issue, so there is no telling when it will and won't happen, if it ever happens again....
  4. Jul 14, 2010 at 11:20 AM
    DeeKay21
    DeeKay21 Lieutenant Dan.
    Nevada/Utah
    06' TRD Sport 4x4
    X2. Yeah jen, first make sure all your connections are nice and tight. Then try swapping ballasts and lastly, try to even swap the bulbs with each other and see if the problem continues. Other then that, I'm not sure what could be wrong with them. I'm 90% sure its the HID's issues and not the truck itself.:cool:
  5. Jul 14, 2010 at 11:22 AM
    jlvhrse
    Jen
    SoCal SGV
    Yeah I sincerely doubt that it's the truck... I have never had the problem before. The only thing is it has only happened once out of the 40+ times I have turned them on.. Also I don't really know what I am looking at.. I am sure I can figure it out myself. From now on I will just have to make sure that both come on before I drive off..
    This blows. I don't even have the guys number anymore becuause I broke my phone!!! I will have to see if it will turn on again.. :mad:
  6. Jul 14, 2010 at 11:22 AM
    CopDoctor
    08 335i
  7. Jul 14, 2010 at 11:24 AM
    jlvhrse
    Jen
    SoCal SGV
    I don't have the high and low beam options though.. I don't think mine looks like that.. I will look at it when I get off work and maybe take some pictures to show you guys if I can't find anything loose or w/e.. (hopefully it will stop raining by the time I get off...)
  8. Jul 14, 2010 at 11:24 AM
    DeeKay21
    Nevada/Utah
    06' TRD Sport 4x4
    Yeah its not hard, you will be able to figure it out. ANd yes, just make sure they both come on whenever you use them.:eek:
  9. Jul 14, 2010 at 11:24 AM
    Chachie
    Chachie Well-Known Member
    Justin
    Nor Cal
    '06 TRD OR, 4x4, Auto, 6" Fabtech, 35's
    Locker mod, Anytime fog mod, always 400w mod.
    Were they turning on when you were starting the truck? Mine did that once and it was from an amperage drop when starting the truck. Has never done it again.
  10. Jul 14, 2010 at 11:27 AM
    CopDoctor
    08 335i
    you still want a harness, here's a low beam harness
    http://www.theretrofitsource.com/pr...id=80&osCsid=3da59fa2a7b6cc2e76cb692836c8c9dd
  11. Jul 14, 2010 at 11:28 AM
    jlvhrse
    Jen
    SoCal SGV
    Thanks danny... I wan't to go look at them now! Dern work :mad:
    Yeah they have turned on fine when starting the truck, the will be dim for a second (when cranking the engine) but then get bright once the truck is running.. I was not concerned with that.. They have also come on fine every time I turned them on seperately (with or without truck running).. Until last night, all of a sudden the driver side headlight decided not to work.. I am hoping something is just loose, it's strange that all I had to do was turn them off and back on to get it to work..
  12. Jul 14, 2010 at 11:30 AM
    jlvhrse
    Jen
    SoCal SGV
  13. Jul 14, 2010 at 11:32 AM
    CopDoctor
    08 335i
    lol i'm going to sound like a broken record..harness!! it bypasses your stock wiring which in some cases isn't well off enough to handle HIDs. your stock wiring turns on the relay and the relay is what connects the battery to your HIDs
    http://www.ddmtuning.com/Products/HID-Kit-Wiring-Harness
  14. Jul 14, 2010 at 11:34 AM
    jlvhrse
    Jen
    SoCal SGV
  15. Jul 14, 2010 at 11:35 AM
    CopDoctor
    08 335i
    yea sorry lol too many posts all at once!! let us know IMMEDIATELY upon testing :)
  16. Jul 14, 2010 at 11:36 AM
    jlvhrse
    Jen
    SoCal SGV
    Hahaha will do. For now Ill check for loose connections and see if I have one of those nifty "harness" thingys.. if not I will be ordering one (or two.. or four? whatever.. lol) :D
    Thank you!!!!
  17. Jul 15, 2010 at 8:22 AM
    jlvhrse
    Jen
    SoCal SGV
    Well, I didn't see anything loose.. Getting the harnesses ASAP.. and my truck just failed inspection for my HIDs.. what a headache!!!
  18. Jul 15, 2010 at 8:51 AM
    DeeKay21
    Nevada/Utah
    06' TRD Sport 4x4
    Hmmmm? So it didnt have a wiring harness? And what did you have your truck inspected for?
  19. Jul 15, 2010 at 9:00 AM
    Menametony
    Menametony Well-Known Member
    Tony
    Oahu
    09 Black 4x4 DC Offroad
    Flow Master 40 Series, TRD CAI, Kings 2.5 remote res front and back, All Pro Front bumper, All Pro Skid Plate, PIAA 4" 510 XT SMR, TC UCA's, 265/75/16 WildPeak AT3 on ATX Artillery, LightForce 240 Blitz HID's, WeatherTech Vents and FloorMats, Cobra 19 CB & PA, Maglite mod both driver and passenger, safari snorkel, TRD supercharger, warn 10k winch, PRINSU CabRack, Cali Raised 42" Light Bar, OEM bed mat, softtopper. WeatherTech Mudflaps On order dissent bed rack and retrofits.
    huh? because it didnt come on it failed? or was it because you had HIDs? i passed with flying colors with my HIDs... hmmm i guess it didnt turn on
  20. Jul 15, 2010 at 10:59 AM
    jlvhrse
    Jen
    SoCal SGV
    State inspection
    No, there was only what came with the plug and play kit.
    It failed because the lights are not DOT approved / are not in the correct housing.. basically because of the HIDs not because they didn't work. I also took it to the stealership because I get free inspections I should have known better.
