Help projector light adjustment
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Petey Bear, Feb 20, 2025.
  1. Feb 20, 2025 at 11:52 AM
    Petey Bear
    Petey Bear [OP] Member
    brian
    09 Tacoma Red access cab 6spd manual
    URD Long tube headers, clutch masters clutch and sleeve and bearing. Ripp coil packs. cia, cerma engine treatment(amazing beyond words). Pulstar plasma plugs
    So I bought some new lights from EBAY, square insert with halo daytime running light. The blasted things will not adjust.
    My highs are my lows, and my lows are my highs, but I plugged them straight up. The highs are double horizoned when shining, are bright, but two different horizons, the bottom horizon is really bright, but the top horizon is dimmer, but there is a blue jagged line creating the two horizons or light variances.
    The low beams are close together, but are on the high setting, and they shoot way out, but not close enough to the truck on the road while driving. I really thought these would be plug and play.
    If I adjust the lows, the highs get messed up, and if I adjust the highs the lows get messed up. They are just like the factory with the upper and lower 4 adjustments. I even did tacomaholics video and everything and it didn't work.
    My turn signals are really fast now but all lights are working including hazards.
    Should I have my buddy, who also tried to adjust them and came up with the same result, should we adjust the top and bottom adjusters @ the same time? They are really bad and dangerous especially on back country roads.......BAAAAD!
  2. Feb 20, 2025 at 12:21 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Sounds like a great upgrade :burp:
  3. Feb 20, 2025 at 12:26 PM
    T4R_hereforbearings
    T4R_hereforbearings Dale Doback, M.D.
    WA
    08 4Runner
    I’ve bolted some stuff to it *lists cool stuff here*
  4. Feb 20, 2025 at 12:33 PM
    vssman
    vssman Rocket Engineer
    Paul
    Naugatuck, CT
    2013 SR5 double cab
    I hate to say it but you wasted your money on junk eBay headlights. The way to improve lighting is in the link that’s posted above.
    T4R_hereforbearings likes this.
  5. Feb 20, 2025 at 12:47 PM
    Petey Bear
    brian
    Yeah, I looked @ that afterwards. You confirmed it..........thanks
