HELP!!! pulling my hair out on brake caliper rebuild
Discussion in '2nd Gen. Tacomas (2005-2015)' started by mikkydee, Feb 13, 2024.
  1. Feb 14, 2024 at 2:35 PM
    TacoTuesday1
    SD CA
    rebuild kits typically come with a packet of clear red seal grease.
    There is similar stuff such as Castrol red rubber grease
    the point of it is:
    1. eases install of a seal, so it doesn't tear
    2. helps hydrate, or keep the seal hydrated, by providing a protective layer, to protect it from brake fluid and water
    it may even be possible to coat the piston, helping it slide in.
    rebuild kit instructions with the watery red grease typically say to soak the seal, which I've done inside a plastic disposable cup.
    as opposed to other greases, like run of the mill brown/orange metal bearing grease, would not be good for this, as it's petroleum-based and would eat/dissolve/destroy rubber.
  2. Feb 14, 2024 at 2:39 PM
    w8tdstrgecube
    w8tdstrgecube Well-Known Member
    Brian
    Wisconsin
    2004 Gold Regular Cab 2.7L Manual 4x4
    Last set of reman calipers I bought one was BENT. How even do you bend a caliper? So yeah, this.
    TireFire likes this.
  3. Feb 14, 2024 at 6:49 PM
    Rob MacRuger
    Rob MacRuger Well-Known Member
    2006 4X4 SR5 4.0
    I never found it. I just used info like bolt size.
    I can mail the one washer I have. I’m in Tampa Bay, should be anywhere in Florida in a couple days. Pm me.
    The one I have is unused.
  4. Feb 19, 2024 at 12:43 PM
    Rob MacRuger
    2006 4X4 SR5 4.0
  5. Feb 20, 2024 at 9:37 PM
    mikkydee
    mikkydee [OP] My Taco 2007 DCLB 4x4 Man Truck
    Doyle
    Florida
    2007 Silver DCLB Tacoma, 4X4, 4.0 Liter, 6" lift, 20" rims, 34" tires
    6" lift, 20 " inch rims, 34" tires, billet grill, aftermarket fender flares, custom rear bumper, DVd player with backup camera, all LED lights
    Thanks for the offer bro, but I went ahead and ordered an after market kit from rock auto that included them.
  6. Feb 20, 2024 at 9:40 PM
    mikkydee
    Doyle
    Florida
